NEOMODE HYBRID ROM 1.8 MK802IV UG007B CX-919 MK809III J22 and others with AP6210
Originally posted by neomode View PostRight now i making a Rom only for the MK809III. Will release it this Week.
Neomode
I am aware that you are having problems and setbacks to Fix and Finish all the separate versions of the ROM... So I do not want to press you to much!
It is only a suggestion, so you can upload the ROM one by one...
Thanks again for all your efforts and hard work!!
Originally posted by apez View PostGood notice, maybe this could be a cause of black flickers screens in 1080P mode.
Originally posted by packetlos View PostI get it too and I have a 3A power supply, it started with the Rikomagic ROM that was released in July that some of the modified ROM's are based on. Didnt have the issue before with either a 2A or 3A psu.
What rom are you using and for which product ?
Re: NEOMODE HYBRID ROM 1.8 MK802IV UG007B CX-919 MK809III J22 and others with AP6210
Neomode: The 1.8 ROM is working fine w/ Sam's 720 kernels on MK802iv, correct?
Apez: Buy a decent PSU. A good quality unit will not only deliver sufficient current when draw reaches peak but will also provide stable, clean power.
I personally use a single port 2.1A iLuv iAD517, and a dual port 1A + 2.1A Scosche USBH3. They have both surpassed the capabilies of both my factory RKM power supplies, and the two similar 2A units I purchased from Geekbuying. You don't necessarily have to spend a lot of money. Only paid $10cad for the good ones @ a local discount merchant.
Sent from my XT925 using TapatalkPlease post your h/w & s/w as signature to help community with troubleshooting problems.
Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
Originally posted by apez View PostHi, I cannot install the 1.8 into my MK809III, with all cutoms roms I've problem with 1080p , when I set any 1080p mode screen is flickering.
Could you please refer me your installation procedure for 1.8 ?
Thanks in advance
i´ve flashed it now a coupe times. Still same problems.
Now i´m waiting for neomodes 809III Image.
Flashing procedure was the "normal ".
download from this
RKAndroidtool started
aktivated point 1-7
device connected to the TV
turn of the device and unplug all usb connections (from PC and Power)
holding the reset/bootloader button
and plug Power in
still holding vor 3 sek
relealise reset und connect usb to pc
RKA.Tool shows device found
Run
That´s it
download from this
aktivated point 1-7
and plug Power in
Run
That´s it
You too have a MK809III ?
Originally posted by Bertin View PostA stupid question:
how have I to connect mk802IV to PC via USB to install the Neomode ROM? Which usb port must be connected?
Thanks to everybody.
For easy of flashing...
1 - Launch the flash tool without the cable connect to your laptop / PC.
2 - Connect the USB cable to micro USB port on the mini labeled OTG.
3 - Hold the little button in on the mini PC while inserting the USB cable into your laptop / PC.
4 - Release little button after a few seconds once recognised by flash tool.
Sent from my Nexus 4 using Tapatalk
There are currently 3465 users online. 0 members and 3465 guests.
