NEOMODE HYBRID ROM 1.8 MK802IV UG007B CX-919 MK809III J22 and others with AP6210
    anyone?
    i managed to flash only the 720P rom but the screen is flashing goes on and off...
    what to do?
    Originally posted by eddiek. View Post
    hey
    can anyone help me and guid me how to install this rom on my J22?
    i did it and it wont load keeps rebooting, im doing something wrong.
    i took the kernel from here (1080):
    and flashed it from the directory "rockdev"
    using this loader: RK3188Loader(L)_V1.20.bin
    and parameter in the rockdev directory. rest of the files taken from the "image" directory
    please help me im new to this.
    thank you ,
    eddie.
      Managed to load with the 2.03 bootloader but get no video output, just a black screen with the 1080p version.
        AW: NEOMODE HYBRID ROM 1.8 MK802IV UG007B CX-919 MK809III J22 and others with AP6210
        Originally posted by danielsun View Post
        where we can found 2.03 loader? it's right for mk809III?
        and how i can say if my device is II or III rev?
        Right now i can not say. Will open my Rev 3 and Rev 2 and looking for different things.
        The 2.03 Loader Download Link is in the first Post.
        Neomode
        Send from the TARDIS
          anyone can send me 2.03 loader please?
            Please try the Kernel from Sam321.
            For this please search the Forum I am on mobile right now.
            Neomode
              Its linked in the first post.
                It happened the same to me.
                  ok..and how i can see if I have 2 o 3 rev hardware?
                    Where would I find the various parameter files compatible with the mk802iv, etc?
                    Sent from my XT925 using Tapatalk
                    Please post your h/w & s/w as signature to help community with troubleshooting problems.
                    Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
                    uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
                    iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
                    Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
                      Neomode
                      Hi Neomode,
                      I swapped the kernel in 1.8 with Sam's 1080p, I now get video output but the rom is stuck in as boot loop, first the rikomagic logo shows then then android update animation then a reboot and the process starts again.
                        Where did you find the Sam123´s kernel? Can you put the link here? Thx!
                        Hi Neomode,
                          Hi djisasi,
                          Here you go: http://www.freaktab.com/showthread.p...007B-or-cx-919
                            Originally posted by trapexit View Post
                            My MK802IV crashes almost immediately after booting with 1.8. Any suggestions on how to debug?
                            I was able to replicate this by letting Build Prop Editor reboot this rom. Using Ctrl-Alt-Delete to reboot has some weird behaviour too. Upon reboot it hangs. Unplugging power cable fixes all of this.
                            Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
                              In the Finless 1.6b Rom. In the FinlessRom folder. Look for the Parameter named files.
                                nothing...mk809III with NEOMODE 1.8 and 2.03 bootloader flash right but when i connect to tv start image Rikomagic and after android and loop only this two image....nothing load or start...
                                I don't understaind becouse after i have try to flash this 1.8 rom i can't flash other 1.7 version, first 1.7 work right....
