NEOMODE HYBRID ROM 1.8 MK802IV UG007B CX-919 MK809III J22 and others with AP6210
    Attention for the MK809III User !!
    On the Hardware Revison II my Rom Work.
    On Hardware Revison III it did not Work !!.
    Neomode
      cant install that rom
      hey
      can anyone help me and guid me how to install this rom on my J22?
      i did it and it wont load keeps rebooting, im doing something wrong.
      i took the kernel from here (1080):
      and flashed it from the directory "rockdev"
      using this loader: RK3188Loader(L)_V1.20.bin
      and parameter in the rockdev directory. rest of the files taken from the "image" directory
      please help me im new to this.
      thank you ,
      eddie.
        Neomode
        can you tell me what doesn't work? i don't know if i have rev2 or 3
          Which version should I use to install it? I have mk802IV (8GB). I tried with RK3188Loader(L)_V1.20(it should be the right one for 8GB) and 1.24(for 16GB)
          Originally posted by darekmarta1975 View Post
          yes, you have to change the loader probably like what you were sure was 2.03.
          Run and see how you lader. How do you upload another loader unit can not get up
            Hi neomode, on my mk802iv the 720p that i tested, is working fine. The only thing i would like to ask is, if i can select not to run the tv launcher, because i prefer the android launcher better and how i can choose that?
            I saw that it has too many built in apps that i don`t want to run by default as mail etc.
            Oh and not forget to mention that i had with your custom kernel a 17500 on antutu at 720p.
            Thanks for your great work.
              I could update with 2.03 loader version, but I have a blackscreen. I am seeing rikomagic logo and after 1 secods a black screen? Suggestions?
                For a nother Launcher go to Play Store and Download and Install a Launcher of your Choice.
                Good ones are Apex or Nova Launcher.
                The Apps you mean did not Run by default. The Apps will be Installed by a Script the First Time you run the Rom. All my Apps are Installed as User Apps. This is be done because you can easy remove it over Settings.
                Neomode
                  I would say that Loader is not for your Device.
                  What Serial Number you have pls. ?
                  Neomode
                    Try to flash it with the neomode flash tool that is in the rom. At first put the stick and make the right procedure to have recognised from the pc. Then make erase idb, and after that uncheck the parameter file(this is working for me).Then flash. when it`s finished uncheck all the others and check only the parameter, and flash again. Try and tell me the result.
                    Wish you luck.
                    Last edited by babnik80; 26 November 2013, 21:19. Reason: 1.20loader and 1.37 flash tool
                      Neomode
                      Thanks for the answer Neomode.
                      One last question, can i use overclockomatic with your custom kernel to have it at 1800cpu and 1500ram? and what is you mali overclocked frequncy in the kernel because at antutu i keep getting around 2000 at 3d score, and this was the same with unoverclocked gpu as well.
                      Thanks again.
                        I have "20130804157"
                        Neomode
                          I did it well. Only the 2.03 loader version finished the process.
                          Wish you luck.
                            Nice to hear that.
                            Enjoy!
                              Yes! but after that, I get the black screen that I have talked before. I have managed to re-install a official version. It seems that my stick does no like Neomode Roms....
                              Nice to hear that.
                              Enjoy!
                                where we can found 2.03 loader? it's right for mk809III?
                                and how i can say if my device is II or III rev?
