NEOMODE HYBRID ROM 1.8 MK802IV UG007B CX-919 MK809III J22 and others with AP6210
Originally posted by djisasi View PostIn my case, I tried to re-run, but it does not work. Several times. To recover it, I have to install an official version.
I have mk809III and I have same problem, error when flashing...now i can't flash any mod rom...i can flash only original rom with Rockchip batch tool 1.7
before i was using it with ROM NEOMODE HYBRID 1.7 and everything work well including wifi nd bluethoot (I have last chip wifi AP6010)
Messed up
I have exactly the same problem...
It seems that ROM is corrupted:
1) No Root - ??
2) RKLoader v1.2 - why not 1.24?
3) package-file - kernel is hashed,
4) parameter - Machine is 3066, not 3188,
I don't know if all above make any sense, but..
I have managed to run it by:
1) Flashing NeoMode v1.0,
2) Reflashing just system.img from v1.8
1) No Root - ??
but why now i can't flash any mod rom????
Re: NEOMODE HYBRID ROM 1.8 MK802IV UG007B CX-919 MK809III J22 and others with AP6210
Originally posted by raplus View PostI have one question. It happens just in every 1080 rom, that sometimes i lose hdmi signal (black screen) for 3 seconds and than it comes back. Is it charger related?
Sent from my XT925 using TapatalkPlease post your h/w & s/w as signature to help community with troubleshooting problems.
Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
Out of curiousity, could the inclusion of a reference to the MK809II in the parameter file be what is gooning the 809III series following flash attempts, or is that moot?
Originally posted by mechaone View PostDefinitely a power supply issue. The factory units have all crapped out on me. My stick no longer gives black outs, random reboots or system freezes since switching to quality usb power supplies. Buy one. Its worth the money
I tried to connect the MK809III but it got stuck to the start jpg so I decided to re-install the original firmaware.
Same story. It got stuck to the Google TV image.
Then I decided to run again the Neomode firmware and it run perfectly, without error.
The MK809III works perfectly except for the Bluetooth which cannot be turned on.
OK let me bring in some Light here.
First I use the Loader 1.2 because it Works i have Tested it on different Devices.
Second the Parameter File says 3066 that is normal because the parameter are the same.
I have Test my Rom with a MK809III Hardware Rev.2.
Today I have got a Hardware Rev.3. And will Test it Asap.
The most issues are coming from the Power Supply please make sure that it Work right.
Neomode
Neomode
Originally posted by raplus View PostThanks for your kind reply. It's strange that this happens only when resolution is set to 1920x1080...i tried to powered it also from TV unit but it's the same. Try over the USB power supply. Should it ne more than 2A?
Anything more than 2.1 A is unnecessary, as a powered USB hub is the next step if you have numerous USB devices.
Originally posted by djisasi View PostI did it, but it did not work. And it is not the first time. I can not install any NEOMODE-version. I have Mk802IV(new version). And always the same. When the program want to check the installed version, I get the error.MY MINI PC: C4,CS918,M8,M8C
There are currently 3007 users online. 1 members and 3006 guests.
