NEOMODE HYBRID ROM 1.8 MK802IV UG007B CX-919 MK809III J22 and others with AP6210
    AW: NEOMODE HYBRID ROM 1.8 MK802IV UG007B CX-919 MK809III J22 and others with AP6210
    Yesterday I have make some experiments with this device in version 2 and 3. Right now I have found a Version that works. Will publish asap.
    Neomode
      Neomode
      Hi, Neomode, you're the top!
      In detail, will it be suitable also for MK802IV with AP6210 or only for old equipment?
      Have a nice day.
        Hello,
        Will also work for the MK802IV with AP6210.
        Neomode
          Hello,
          Neomode
          Hi Neomode,
          Since you have mentioned some fixes for others TV Sticks, I would like to know if you have made some improvements or corrections for the CX-919?
          Also would like to know if you have fixed the 1080 Startup-Logo Display (That previously displays totally distorted), and if BT now works?
          Thanks for your help and hope that you have time to upload the new version today!
            Re: NEOMODE HYBRID ROM 1.8 MK802IV UG007B CX-919 MK809III J22 and others with AP6210
            Originally posted by ulises1954 View Post
            Hi Neomode,
            These issues sound kernel related.
            I successfully run custom 1.8Ghz DDR800 kernels on my CX-919's at 720P without any issues.
            While I don't use the Bluetooth, further progress is being made in the Marvin thread.
            Sent from my Nexus 4 using Tapatalk
              fingers crossed this will work on my COSY SWAN S400
              just a proper CWM for the S400 now - and this to work - for my stick to be the coolest it can be.
              Keep up the good work NEO
                Yes I agree, apart of the BlueTooth problem and the horrible KIUI launcher, the 720 version work extremely well with my CX-919 without any lockups... However I have to use the ADW-Launcher and uninstall the Apk-Injector APP.
                Unfortunately the 1080 version always gets stuck in the Startup Logo and not boot...
                I noticed that the original KitKat Android 4.4 Launcher apparently is working very fast with Android 4.2.2:
                Does anyone have had any experiences or has used this KitKat-Launcher with Neomode's ROMs and the CX-919?
                Can this KitKat-Launcher be included in the latest Neomode ROM?
                  a strange thing....
                  ...my OTG port doesn't work... but when I have to change firmware from pc it WORKS!!!! no signal when is attached to my TV... I tried all firmwares.... I don't know exactly when it has begun to do this... but in the beginning 1.8 worked ok till it unmounted sdcard and nand randomly....
                    As I say i make an Update to fix the problem with mk802III.
                    Will include the new Google Launcher.
                    Neomode
                      Update Neomode 1.8
                      Neomode
                      Hi
                      I cant find link to new updated file??
                      Basmand
                        Yes because I am on making it.
                        The new Version of the MK809III has a few problems.
                        When finish hope in weekend I will make a link.
                        Neomode
                          Neomode
                          Hi
                          Thanks for all your work and help, great news, be course I need the Bluetooth to work in order to use my stick with my Pioneer APPRADIO
                          Basmand
                            mk809III hardware version ?
                            what is the difference in the hardware versions of the MK809III?
                            What is V1,V2 & V3 ?
                            Thank you
                            meinbier
                              What kind of Device you have?
                              Neomode
                                Neomode
                                Hi
                                MK802IV with AP6210, when installed 1,8 it disconnects Bluetooth, works for about 10 sec searching for units then turn off newer get "Blue" (ON)
                                Bsmand
