NEOMODE HYBRID ROM 1.8 MK802IV UG007B CX-919 MK809III J22 and others with AP6210
Originally posted by neomode View PostThe problem is when you use a patched kernel and the standard Rom then the boot.img will overwrite the kernel.
When you use a custom Rom then it should work.
Neomode
i tried to use sams overclocked gpu with finles 1.6b, yours 1.7 and 1.8. the procedure was to erase idb and flash with the oc kernel from the beginning with parameter file unchecked (because it make a fault at flashing) then i only flash parameter file and every time i get the same 3d score. I never used an official rom. If you could try it for yourself it would be great help for me.
is there any other way to check the gpu after flashing in what frequency is working?do you think that i make something wrong with the flash procedure? everything else is overclocked fine, cpu 1.9 or 1.8, the ram gives me a big boost when i use the 1500 kernel( don' know other way to check if is oced) but at gpu always the same result.
at last i want to say that 1.8 720p,except the launcher that i don't like very much, is the best rom for me till now, quick and with very good wifi signal.
Originally posted by Bertin View PostProcedure is OK in writing data, but fails immediately in checking data.
Why?
He just got his replacement MK802IV so this is likely to be fixed soon and new links put up.Mk802IV Neomode 1.9a original rom 720p
Originally posted by Magnus33 View PostWild guess i think it has issues with the loader.
However, I suppose that it's only a matter of the verification routine, whilst data have been correctly written.
Originally posted by Bertin View PostI agree with you, probably something like a wrong checksum.
The data seems to be written fine but the check routine is broken so flash ends up failing.
Iam presently using kasty-rkm since its based on the last official release minus the bloat and has 3gb apps with a patched kernel so no video stutter.
Gives me a stable device well we wait to see what neomode cooks up for usMk802IV Neomode 1.9a original rom 720p
Sorry for my stupid question, and yes I think that I can read, BUT!!! do you think this version will run on MK802IV
Basmand
Originally posted by neomode View PostThe Custom Rom for the MK809III is here:
http://www.freaktab.com/showthread.p...II-Version-1-9
For MK802IV - should I use v1.8 or wait v1.9 ?
First post doesn't have links for download. Is v1.8 safe for MK802IV (AP6210) ?
There are currently 6262 users online. 1 members and 6261 guests.
