Sent from my XT925 using Tapatalk
NEOMODE HYBRID ROM 1.8 MK802IV UG007B CX-919 MK809III J22 and others with AP6210
Re: NEOMODE HYBRID ROM 1.8 MK802IV UG007B CX-919 MK809III J22 and others with AP6210
Originally posted by basmand View Post
Sent from my XT925 using TapatalkPlease post your h/w & s/w as signature to help community with troubleshooting problems.
Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
Originally posted by mechaone View PostYou can wire in a fused usb 5v constant feed, but be warned; keeping the device on indefinitely will slow drain your 12v battery over a few days time. TV sticks pull current constantly, as they do not have a charge circuit to regulate. That being said, you can expect far higher drain over the long run, vs leaving a cell phone or even a tablet on charge.
Basmand
AW: NEOMODE HYBRID ROM 1.8 MK802IV UG007B CX-919 MK809III J22 and others with AP6210
I think the Stick goes off or Sleep when there is no HDMI Connected.
This means when you should down your Car the TFT get off.
Then the Stick think I can sleep.
Neomode
Originally posted by neomode View PostI think the Stick goes off or Sleep when there is no HDMI Connected.
Neomode
Do you know how that I can fix it, is there some kind of app that can keep it alive so stick think it is on
Basmand
Originally posted by basmand View PostHi I have constant power on now!!, but I can see that stick still on power when I turn of my car!! When I start again Stick Boot again, I thing there is some kind of power settings in Rom that we cant access?
Basmand
Originally posted by mechaone View PostSorry. Trying to figure out the issue. So you want the stick to always stay on, but go into sleep mode when the display shuts down with the ignition? Is the stick still running when you get in your car, and reboots when you start the car?
Hi
Yes stick always on and newer newer go's to sleep, be course when turning radio on it at once do Bluetooth connection for touch screen and HDMI connection for video, and if stick not ready It fails and I have do it manually. To do the work between stick and APPRADIO I am using an app called ARUnchained from XDA
BasmandLast edited by basmand; 07 December 2013, 21:01.
Good morning to all.
Hi neomode,
I don`t know if you received your new mk802iv.
If you did i want you to answer if you have any news about the problem i was telling you, about the oc for the gpu.
Did you found anything?Because i tried every possible oced gpu kernel and none is working for my stick (only for the gpu).
Thanks in advance, and i must tell that i appreciate your total effort!!
mk802iv old wifi
anybody got a link for NEOMODE HYBRID ROM 1.8 MK802IV old wifi. all the 1s ive seen are for the new wifi
Originally posted by waddell81 View Postanybody got a link for NEOMODE HYBRID ROM 1.8 MK802IV old wifi. all the 1s ive seen are for the new wifiFreakbox V1 F/W 1.0.6
Asus Zenfone 2 ZE551ML Stock (rooted)
Samsung Galaxy Tab 3 7.0 Nolekat 2.2 custom ROM
Asus TF300T Cyanogenmod 11 Snapshot M12
Archos 35 Home Connect Stock 2.3.4
There are currently 6214 users online. 1 members and 6213 guests.
