.gif)
I gave you in the ROM the original build.prop. It is called build.orig. All you need to do to make everything Pipo is to rename build.prop to build.old and rename build.orig to build.prop. NO editing required just simple file rename. FYI just changing MODEL can cause other issues! It is best to use the build.orig instead of editing.
I spend a lot of time writing my instructions and giving ability to do things people want. It helps if you read the readme!!!
Sorry to be harsh but sometimes RTFM! You would not have even had to ask about this had you read my readme I spent a lot of time writing.
