Pipo M9 Pro - Finless 1.4 ROM
hey guys. i need some help here. im having some issues with the auto rotate. apparently my tablet cant rotate unless its being forced by an app. my findings online has shown that it might be a g sensor issue. however, im unable to solve this problem even by downloading calibration apps. any ideas guys? i have flashed from riley to finless to kasty to see if i can remedy the issue.
Originally posted by mrleezh View Postnope. stock. i always use the stock. tested and proven its not just home screen. on temple run 2 tutorial i cant seem to even get the guy to run to the side.
My suggestion would be wait for the new rom Finless is going to release. Not because there is a known isuse but rather my suggestion would first be to wipe / format and reflash.
When you do reflash make sure to test rotation first thing before any other apps are installed.
Originally posted by mrleezh View Posti have reflashed many roms many times. wiped alot of times. i even tried stock. anyway. i shall give my tablet a rest for today. hopefully it understand the pain of its owner. haha.
I guess the best you can do is find a widget that will easily allow you to rotate back and forth.
Download an APP that tests your hardware (I forget the name but there are many free ones). You can see how your rotation sensor is working or not as well as compass etc.
I'm currently leaving the tablet for charging so it's not with me. But searching on the web it seems some phones do face this problem also. All they need to do is calibrate it with the phones internal system and all is well. For tablets I did see a asus transformer having this issue also. But then he also solved it with some app which does calibration. I did try the app but nope. No go. I shall go sleep and hope tomorrow all will be well.
BUG FOUND in my 1.4 ROM
Guys and Gals...... Turns out while making my 1.5 ROM I found that my bootwifi and boot3g were not working correctly! In my scripts I made a fatal mistake in my final ROM. It worked for me while testing which is why I reported such good battery savings! BUT in my final ROM it did not change anything.
Also init.d was not working!
NO WONDER some are not seeing the power savings turning off 3G for 3G owners that don't use 3G or even some wifi users not seeing it.
My mistake folks!
1.5 will fix this. Forget my 1.4 ROM and I am going to pull it anyway when I release 1.5
I know this sounds odd but
Originally posted by mrleezh View Posthey guys. i need some help here. im having some issues with the auto rotate. apparently my tablet cant rotate unless its being forced by an app. my findings online has shown that it might be a g sensor issue. however, im unable to solve this problem even by downloading calibration apps. any ideas guys? i have flashed from riley to finless to kasty to see if i can remedy the issue.
I had coneection/antenna/wifi problems and rotation problems when I first received the M9 Pro, then I flashed the Riley Rom and it solved all the issues I had with these problems. It all works as good as it needs to for me now.
Originally posted by Finless View PostAlso init.d was not working!
Originally posted by Finless View PostNO WONDER some are not seeing the power savings turning off 3G for 3G owners that don't use 3G or even some wifi users not seeing it.
There are currently 3032 users online. 1 members and 3031 guests.
