I've posted under Finless rom discussion a month ago still got no reply.
Fully working 4.2.2 rom from RIKOMAGIC
Btw link provided in Rikomagic website is not working. http://www.rikomagic.com/en/download/download_18_1.html is forwarding me to http://www.sendspace.com/pro/dl/sxms6w and dl not available at that site. Can someone upload somewhere ?
Originally posted by HaLLoWeD View PostBtw link provided in Rikomagic website is not working. http://www.rikomagic.com/en/download/download_18_1.html is forwarding me to http://www.sendspace.com/pro/dl/sxms6w and dl not available at that site. Can someone upload somewhere ?
Wow! Thanks for pointing out this ROM. I've just flashed it to my Justop K9 (mk809b) and it appears to be working great! The wireless is the best it's been on any ROM, although the ROM doesn't seem quite as speedy as some.
Having wireless working means that I can run the proper iPlayer app - it wouldn't work when connected with the Ethernet adaptor. iPlayer app is a bit blocky, but it has a higher WAF/KAF than using XBMC as I was previously.
Thanks again.
OK, I've had a little play around for a bit with it and it seems to be working OK. 4OD and Demand 5 won't play video (4od doesn't work with rooted devices apparently).
XBMC looks like it is working ok on it thanks to the following brilliant guides:
Update: I created an updated version of this article with a more recent build, you probably want to check it out now: http://makesmarttv.net/external-players-support-mx-player-etc-fix-for-xbmc-on-android-perfect-hd-with-no-compromise/ Important note: The following tutorial should work on any android device. Although we tested on a specific model below, we would love your feedback if it works fine (or not) with your […]
This is a fix for external player support on the latest Android version of XBMC. This fixes the possibility to run MX Player on the latest Gotham build. Not interested in the technical details? Scroll to the bottom of the article for the download link. I’ve mentioned before that one of the great things about […]
So far I've only tested it with the iPlayer plugin, but it does seem to work - AND WIRELESSLY!
Thanks once again to all concerned.
Question
Originally posted by offbeatdave View PostYay! For the first time Pause and Resume is working for me in the iPlayer plugin. Yipee!
What version of xbmc you are using? Did you tried to play some games on this rom? What I can't find out is
this rom rooted at all. And, when you said it is not so smooth, wich rom did you compare with?
Originally posted by goranFilip View Post
What I can't find out is this rom rooted at all.
Shomari are there any advantages comparing with Finless 2.0? What about BT?
EDIT: CWM writes to the boot partition it seems (on this rom) and causes a bootloop when I tried to flash the MX1 CWM from androtab. I found that odd but I guess the devices cause a parameter mismatch.
There are currently 3656 users online. 4 members and 3652 guests.
