Fully working 4.2.2 rom from RIKOMAGIC
Originally posted by Shomari View PostI actually have one still running on the rom with the 1608mhz kernel. It runs better and there's never been an issue with heat; I still let it scale to 252 at idle but I run it aggressively with the ondemand governor nonetheless - by way of tweaking the tunables to skew the cpu runtimes towards the higher freqs most of the time.
I switched another to the MK812 ROM (but with same 1608 kernel) and it runs even better. Slight changes to the system.img seem to make all the difference in this case.
Have you tried the G3 iconbit Firmware?
Already clocked at 1608mhz
I can run 1080p Videos in xbmc , no h/w acceleration .
Dont have any Overheating issues either, i have no heatsink
runs smooth tbh.
im still testing out stuff , ill keep you lot updated.
Got MK809II
Originally posted by KVlady View PostI have interesting to test kernel 1608 with this ROM on iMiTo MX2. Can you upload kernal.img on filesharing server? Thanks for proposal.
...here you go - https://mega.co.nz/#!HNhU3DyT!nwZct2...XsvXDarBGWRKR0
Originally posted by Shomari View PostThanks. I haven't tried that one. The ROM I currently use devours video in XBMC nightlies with room to spare. I'm on a 720 kernel since my bedroom TV only runs at 720.
Best of all, wifi signal is downright booming compared to the rikomagic ROM.
What Rom is this?
and link please
i get about 13800 with icobit rom.
Guys, I'd appreciate if you didn't hijack this thread to discuss other ROMs or sticks. Please try to keep this about Imito MX1&2 (or equivalents) on the newest Rikomagic FW. I am honestly having trouble discerning what posts deal with the OP HW and FW, and which ones do not.
Otherwise, my Logitech Pro 9000 webcam works wonderfully on this ROM. Also, just to give you the heads up, TeamViewer's QuickSupport works fine too! If only we could get someone with some Tasker experience to design a Tasker script to allow remote control without requiring local TeamViewer input (i.e. bypass those pesky prompts), that would be even better! Any volunteers?
Originally posted by Aqualung View PostGuys, I'd appreciate if you didn't hijack this thread to discuss other ROMs or sticks. Please try to keep this about Imito MX1&2 (or equivalents) on the newest Rikomagic FW. I am honestly having trouble discerning what posts deal with the OP HW and FW, and which ones do not.
I could see if the thread was being swayed early, but the dialogue has run its course and progressed to another point. Please don't scoff at us for sparingly sharing reference info and comparisons.
Originally posted by KVlady View PostThanx! Today start testing.
Shomari's kernel is 720p kernel, kernel in Rikomagic MK802IIIS8G(B) Android 4.2 Software(131107) - 1080p kernel
Simple change kernel into ROM result in errors and wrong GUI. For correcting situation need edit build.prop and may be some another action.
So I have interesting overclocking FullHD kernel, now I stop testing this 720-kernel.
Small remark about this kernel: I seem, that so many values in table of CPU frequencies is not good (standard - 6 values)
I made modROM based on Rikomagic MK802IIIS8G(B) Android 4.2 Software(131107) with some achievements (CWM, support init.d, udpxy, extended support Mele F10 and so on), and want to solve last task - overclocking CPU on 1608 for improvement FullHD in IPTV and TorrentStream translation.
I testing overclocking kernel from custom w2com for new Rikomagic MK802IIIS, but one problem - this kernel incompatible with WiFi&BT in iMiTo MX1/MX2. The result testing ROM with this kernel - exelent. Antutu - 13000-13500. Stock kernel (1416) - Antutu - 11500-12500.
Originally posted by KVlady View PostSo I have interesting overclocking FullHD kernel, now I stop testing this 720-kernel.
Full HD 1080p version RIKOMAGIC source (flash boot/kernel to your ROM, same procedure as above):
Originally posted by Shomari View PostI apologize. I keep forgetting you guys all have 1080p panels in every room unlike some of us poor saps
https://mega.co.nz/#!Kd42iIhY!IkCXda...c0ucmUP9eiAyD8
O, thanks for link - this is look as needing kernel !
Originally posted by Shomari View PostFull HD 1080p version RIKOMAGIC source (flash boot/kernel to your ROM, same procedure as above):
There are currently 3236 users online. 2 members and 3234 guests.
