The only way I could move it off the main screen was to hover another icon around it and create a folder with it. then I moved the folder to the last screen panel where I don't have to look at it. I'm not interested in using my phone on it.
Only other complaint is everything is way oversized; icons, mouse pointer, system bar...
joaomfds posted how to change the icons with a SU terminal command, "am display-density 180", is what I set it to but I'd still like to find a way to make the pointer and bar smaller.
Can anyone explain why it is that sometimes when clicking the "Turn Off" button the stick reboots instead of turning off? Anyone else experiences this behavior? How can this be fixed please?
...it's a known bug. My question is does it happen from kernel to kernel or just one kernel for you?
I tried the Rikomagic firmware on my MK809-II and it has a great thing that other ones don't have: HDMI passthrough! and it works!
too bad the wifi does not on my device, unlike the Imito versions that work fine instead...
so, I'm looking for a firmware with passthrough option (and possibly 1080p kernel) which works with my wifi! (the chipset is the same so I don't know what is wrong with it, just the R-BOX branded firmwares work perfectly and the Imito by Finless work with a manually edited wifi config file)
Have anybody tried to pair by Bluetooth a phone with the stick?
I have an imito mx1 with this rikomagic ROM and a samsung s3 i9300 under Cm11 and they not pair.
My intention is to use my TV as a2dp player
Is it possible?
This UG007II kitkat rom for mediatek, The wifi does not work.
there are both "Download Download Android KitKat 4.4.2 firmware for MK809 II / UG007II Stick with AP6210 Wi-Fi chip from here, here or here."
---and, by the way, this rom is perfect!!I have the MK809-II 4.2 with MTK and this one boots up, wifi works (didn't try after reboot but I think it won't, anyway I know how to manage) and it has 5.1 passthrough working!!
---update: after reboot, both wifi and ART work
