Fully working 4.2.2 rom from RIKOMAGIC
Originally posted by offbeatdave View PostANTUTU BENCHMARK:
Antutu Benchmark clocks in at 11565 - whatever that means! I've never used it before so I've no idea how that stacks up.
I saw about the rebooting device when shutdown is initiated and the only time I've seen that on these is with dirty flashes which caused all sorts of unexpected behavior.
Changing HDMI mode from 1920x1080p-60 to 1280x720p-50 increased the Antutu benchmark to 12170.
Is this ROM running a 720 or 1080 kernel? How do you tell?Last edited by offbeatdave; 01-07-2014, 07:01.
Can't tell without looking at the source, but the Rikomagic RK3066 user guide says 720p is the 'real' screen and the 1080p output is upscaled from the 720p kernel.
Antutu can shed some details in the 'Device Info' section as well. Look for the device resolution entry.
That would also explain why the benchmark scores were higher without the extra drain of an upscaled screen.
My eyes can't tell the difference (at distance) so I always run mine at 720p 60.
[QUOTE alexbur;128365]Hi,
I have the following problem with this ROM installed. When I try to shutdown the system, a reboot happens instead of shutdown. There is no such problem with stock ROMs and Finless ROMs. Does anybody have the same problem? How can I fix it?
Thanks[/QUOTE]
Same problem here.
When I press shutdown botton, the device reboot.
Will try to reflash once again.
Sorry for my bad english
Well, I've now reverted to my Feb 19 2013 build of XBMC in this rom. That's version 13.0-alpha1 Git: 20130219-32e99c7 with the advancedsettings.xml file mentioned in my earlier post. The version I was using ended up being stuttery for no good reason.
The only issue I have with this version is that when using the iPlayer plugin, if I stop a stream and then try to restart it, i just get sound and no image (the XBMC theme turns from blue to black).
Originally posted by offbeatdave View PostDid you manage to do this? How did it go?
I switched another to the MK812 ROM (but with same 1608 kernel) and it runs even better. Slight changes to the system.img seem to make all the difference in this case.
Flashing
I haven't toyed with my MX1 in a long while, so I don't really remember how to flash newer ROMs. Also, I am not really sure what ROM I have currently installed. Will it flash if I just put the .img file in the root of the (external) SD card? And, more importantly, will it break anything if it doesn't work?
Originally posted by Aqualung View PostI haven't toyed with my MX1 in a long while, so I don't really remember how to flash newer ROMs. Also, I am not really sure what ROM I have currently installed. Will it flash if I just put the .img file in the root of the (external) SD card? And, more importantly, will it break anything if it doesn't work?
Please ensure you're running at least version 4.2 if you do go this route. Attempting to flash an update.zip from 4.1 to 4.2 will render your stick inoperable until you flash with rk batch tool. That method of upgrade is incompatible between the two versions.
There are currently 2714 users online. 3 members and 2711 guests.
