Pipo M6 Pro RileyROM 1.5
    This ROM is based on an official Pipo firmware release dated 12/5/2013.
    All of the essential changes I made in 1.4.2 carried over into this ROM:
    Updated Google Apps
    Auto Install Apps from External SD (see this thread for details)
    As usual this ROM is:
    Rooted
    Debloated
    Init.d Support
    Busybox Support
    English Default
    Working CWM Recovery
    2, 4, 6, 8, or 12gb user app space by changing parameter files
    Boot Animation by Tattman65
    Reboot app by Petrus
    Updated First Time User's Guide (Please read this guide before attempting to install the first time)
    Rockchip driver installer app is now included in the kit
    Download
    v1.5.1 is available at this link:
    Download
    This version is the same as v1.5, except without the Google Apps update, which may have caused problems with Text-To-Speech, and some lockups.
    If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com
    Donate!!! Your donations keep me updated with the latest tablets to test on.
    Randy
    My gratitude
    Just to thank you for your immense and selfless work
      Just Thank You.... as usual!
        Installed your rom and so far no problems
        Thanks Riley, a question, have you removed the option to create users?
          Oops...sorry, I forgot to add that.
          If you really need it just put this line at the bottom of the build.prop:
          fw.max_users=4
          I just added it to the ROM and I'm uploading again. You may notice the link being broken for a little while. When it's back up, it will be fixed.
          Randy
            OK, the link is back up with the multi-user function restored.
            Sorry for the delay.
            Randy
              thx, installed normally
              went do more tests
                Randy, can you add back Normal mode in rom ?
                Do you use any tweaks for 3G (and network) in your rom ?
                  I am a dedicated follower of Fashion (=Riley!)
                  Just installed Riley 1.5, this install went OK with no problems.
                  I really have to buy Titanium now , restoring all the app's manually is getting boring.
                  I assume the working DeepSleep lib is in there as well?
                  Thanks again for the good work!!
                    you can find titanium backup full in other ways...
                    but I suggest you to buy that app!
                    The full version can do a complete restore without tap "accept" for every single app! It's a big improvemet in my opinion.
                    I'm using RileyROM 1.4.2 I'm going to jump this version and wait for the next one (hopefully the first KitKat!!!), because I think the differences between 1.4.2 and 1.5 are invisible or barely visible!
                      gmail not sending messages?
                      Hi all,
                      I just installed the 1.5 rom, and although everything looks ok, I did encounter something weird:
                      It seems that gmail is not sending messages.
                      5
                      I will check everything again, but meanwhile, can somebody check and confirm my finding?
                      Thanks.
                      Update: problem solved!!
                      I think it happened when I restored my backup, including the gmail app.
                      While restoring, I had gmail all ready configured, including the widget.
                      It was receiving mail, but not sending.
                      I stopped gmail and removed the app-data and cleared the cache.
                      After restarting it is working again.
                      Last edited by Satbeginner; 13 December 2013, 14:34. Reason: new information found, problem solved!
                        thanks randy, everything works great
                          thanks; work fine. Could you explain me why some games are not working ?
                            R: Pipo M6 Pro RileyROM 1.5
                            Thanks Randy!
                            Giouncino, can be used the patched kernel from 1.4.2 also with 1.5 ?
                            Inviato dal mio M6pro utilizzando Tapatalk
                              Just updated from 1.3 to this on my Sumvision Cyclone Voyager 2 and it's working great. Some nice new features.
                              Thanks Randy
