Cheers
Pipo M6 Pro RileyROM 1.5
SoD
Originally posted by dmr View PostHave anyone SoD on riley's 1.5 firmware, except me.
My stats: 5 SoD in 2 days
If it happens again, I will let you know.
Kernel parameters
Originally posted by Kimmen View PostHave u tweaked the voltage on cpu, gpu, ram or are they default?
Cheers
I only changed the RAM frequency, no changes in voltages by me.
For your info, the script I used is attached with this message.Attached Files
No found RkAndroid rock usb
I have big problems flashing My Pipo m6 Pro. I followed literally yur instructions, but even if I disactivated automatic driver download and installing the drivers in Riley Kit, When I connected for the first time my Pipo Windows 8.1 installed two "rockchip_usb USB device " and if I remove them they reappear again so Finless Rom Flash Tool always says "No found RkAndroid rock usb" I flashed other tablet in the past and this is the first time I have this problem. Can PLEASE someone help me? I have Windows 8.1 64 bit. THANK YOU in advance, a non rooted tablet is quite useless to me...
Originally posted by Pomodoro View PostI have big problems flashing My Pipo m6 Pro. I followed literally yur instructions, but even if I disactivated automatic driver download and installing the drivers in Riley Kit, When I connected for the first time my Pipo Windows 8.1 installed two "rockchip_usb USB device " and if I remove them they reappear again so Finless Rom Flash Tool always says "No found RkAndroid rock usb" I flashed other tablet in the past and this is the first time I have this problem. Can PLEASE someone help me? I have Windows 8.1 64 bit. THANK YOU in advance, a non rooted tablet is quite useless to me...
Help
hopefully it will help.
Bruce
Still having SoD (or so I think). I had to remove the 1.5 and installed the latest stock ROM. All working fine and all day without having to wake up the pad with reset button. Any clue on what is causing it. I like Randy's 1.5, but it doesn't like my tablet. Just in case -> Pipo M6Pro 3g 32gb w 32gb mSD. Newbie, but tech enough to get in enough trouble.
Sent from my M6pro using TapatalkLast edited by gu1llo; 17 December 2013, 17:16.
Originally posted by bigfoot53 View PostTake a look here: http://www.freaktab.com/showthread.p...s-In-Windows-8
Bruce
760MHz maybe a bit too much?
Originally posted by Satbeginner View PostI did my part of reading, and now I 'patched' my first kernel.
It is all based on the PERL script made by phjanderson and the information on frequencies and voltages by giouncino.
It turns out MY sample of the M6Pro seems to work ONLY with higher memory speeds.
Any tweak on the CPU or GPU will cause freezes.
I was able to push my M6Pro to a memory clock of 760Mz, and it appears to run stable. (for now)
Here is the kernel I run at the moment, it gave me an AnTuTu score of 19100.
I don't have any info on battery usage yet.
Please some feedback when using this one.
Un saludo.
I had one (1) freeze while playing a Youtube movie, and I want to have a stable Pipo, so I tuned the memory down just a bit.
Here is my 750MHz RAM kernel and script, based on the 1.5 RileyRom.
Un saludo.
APPS CRASHING...
OK, so I ate the data loss as described previously (had a 1-legged duck moment), but now I have another issue specific to RR v.1.5, several things all of a sudden started misbehaving with the install of RR v.1.5 and reinstall of apps.
I was in an bad accident several months ago, and my first tablet / Android device, and learning it was my recovery project after a surgery, and right when I was ready to depend on my tablet during travel it has put me in a bad situation.
It keeps giving an error Google Text to speech Engine has crashed, and also, 2 apps I need immediately became unusable, saying they are not responding, they are in the app store, HotPads and PadMapper.
I expect other things wil crash also, but this is just preliminary finding and reproduceable.
Both worked perfectly fine in v.1.3a, and if I cannot get them working, I will be forced to regress to v.1.3a.
ALSO, it occurred to me after getting these errors, possibly the issue with not being able to change the backup directory in Titanium Backup in the preferences may be related to the above mentioned error.
It refuses to let me specify any other directory for backup than what it decides, is that right?
Can anyone else verify HotPads and PadMapper (App called Trulia For Rent also does not work) do not work in their install of RR v.1.5? They use location services I think, and it may be related to that I am thinking.
I really need those 2 apps working ASAP, as my intent is to be on the road by end of week, and my desktop system goes down in a couple of days
Randy or someone whom knows, what is the most stable RR release?
I know v.1.3a seemed to work fine for me, and gosh should I have known better than to migrate when I did knowing I had a stable system.
I'll soon be unable to flash my tablet for an unknown period of time...
TIA...
I'm using 1.4.2. This is the most stable to me.
It is also the most similar to 1.5 in terms of performances and functionalities.
For these reasons I'm going to jump 1.5 and wait next release.
You can change directory for Titanium backup moving defalut backupped data on another folder then let TB seach for a backup. It will use your new folder as TB default backup location.if you appreciate my efforts this is the link for any donation:
There are currently 1959 users online. 0 members and 1959 guests.
