Pipo M6 Pro RileyROM 1.5
I've never really noticed any difference.Randy
Originally posted by bigfoot53 View PostWhen I run Puffin Browser it tells me to turn off the force gpu rendering.
Will this cause stability issues with 2d Apps? Or cause more battery usage?
Bruceif you appreciate my efforts this is the link for any donation:
Hi guys, new to freaktab but have been watching in background for a while now.
I bought a sumvision voyager 297 (rebadged M6 pro wifi) flashed rileyrom 1.5 (thank you randy) no problems but now getting random freezes which require a pin reset which is a pain, so having read this thread I was going to flash 1.4.2. Is this the way to go or is there other things I need to try before reflashing ?
P.S The 1.4.2 d/l in archived roms doesn't seem to work is there a mirror somewhere please
Gooner1511
Originally posted by gooner1511 View PostHi guys, new to freaktab but have been watching in background for a while now.
Gooner1511
Cheers
Re: Pipo M6 Pro RileyROM 1.5
Originally posted by MartyK View PostHow are all you guys formatting your micro sd cards to NTFS?
Got my pipo plugged into my windows xp based pc right now and the micro sd card is inserted into the pipo.
when i go to format there is no option for NTFS. Just to reformat as FAT32.
Cheers.
Sent from my SAMSUNG-SGH-I537 using TapatalkRandy
Cheers.
I want to reformat a 16 GB SD card to NTFS so that I can use it to transfer large files (larger than 4 GB) from one computer to another easily, but my computer will only allow FAT variati...
I actually did mine using Linux.
Sent from my M6pro using Tapatalk 4
Our tablets have not a clone of iPad retina display...
Pipo M6pro has EXACTLY the same Part Number:
I removed the battery and the P/N written on display is: KLMPK1564TPZZ , that is the same model used on iPad 3/4...
fantastic!!!!if you appreciate my efforts this is the link for any donation:
Originally posted by poolonik View PostHallo ,I am a new owner of the tablet Pipo m6 pro and I have a question ."Pipo m6 pro wifi" also has sim holder?I ask becouse I have Wifi version, but i see that also has sim slot.I inserted a sim card but nothing is going on .
Thank you .
There are currently 2668 users online. 0 members and 2668 guests.
