Hi! I have the exact same problem.. (althou it boots with _target_2.1)..
I still use the Claro and it works good... but cant do stability or test in antutu (hangs on 21%)
Cheers
------ KERNEL LOG (dmesg) ------ <3>[ 6.305325] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2... <3>[ 6.305490] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1... <3>[ 6.305649] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0... <3>[ 6.305674] ov5640 write reg(0x3008, val:0x80) failed, try to write again! <3>[ 6.305842] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2... <3>[ 6.306002] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1... <3>[ 6.306162] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0... <3>[ 6.306185] ov5640 write reg(0x3008, val:0x80) failed, try to write again! <3>[ 6.306352] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 2... <3>[ 6.306513] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 1... <3>[ 6.306671] i2c i2c-3: No ack, Maybe slave(addr: 0x3c) not exist or abnormal power-on, retry 0... <3>[ 6.306693] ov5640 write reg(0x3008, val:0x80) failed, try to write again! <3>[ 6.306723] soft reset ov5640 failed <3>[ 6.319048] camera 33-0-ov5640_back: Probe ov5640_back failed <3>[ 6.335459] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 2... <3>[ 6.335616] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 1... <3>[ 6.335771] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 0... <3>[ 6.335792] ov2659 write reg(0x103, val:0x1) failed, try to write again! <3>[ 6.335956] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 2... <3>[ 6.336111] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 1... <3>[ 6.336265] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 0... <3>[ 6.336286] ov2659 write reg(0x103, val:0x1) failed, try to write again! <3>[ 6.336448] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 2... <3>[ 6.336603] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 1... <3>[ 6.336758] i2c i2c-3: No ack, Maybe slave(addr: 0x30) not exist or abnormal power-on, retry 0... <3>[ 6.336779] ov2659 write reg(0x103, val:0x1) failed, try to write again! <3>[ 6.336805] soft reset ov2659 failed <3>[ 6.349059] camera 33-1-ov2659_front: Probe ov2659_front failed
------ SYSTEM LOG (logcat -v threadtime -d *:v) ------ 12-16 12:08:48.681 5876 5892 V CameraHolder: open camera 0 12-16 12:08:48.691 110 450 E CameraService: CameraService::connect X (pid 5876) rejected (invalid cameraId 0). 12-16 12:08:48.701 5876 5892 E CameraHolder: fail to connect Camera 12-16 12:08:48.701 5876 5892 E CameraHolder: java.lang.RuntimeException: Fail to connect to camera service 12-16 12:08:48.701 5876 5892 E CameraHolder: at android.hardware.Camera.native_setup(Native Method) 12-16 12:08:48.701 5876 5892 E CameraHolder: at android.hardware.Camera.<init>(Camera.java:340) 12-16 12:08:48.701 5876 5892 E CameraHolder: at android.hardware.Camera.open(Camera.java:302) 12-16 12:08:48.701 5876 5892 E CameraHolder: at com.android.camera.CameraManager.cameraOpen(CameraManager.java:283) 12-16 12:08:48.701 5876 5892 E CameraHolder: at com.android.camera.CameraHolder.open(CameraHolder.java:210) 12-16 12:08:48.701 5876 5892 E CameraHolder: at com.android.camera.Util.openCamera(Util.java:315) 12-16 12:08:48.701 5876 5892 E CameraHolder: at com.android.camera.PhotoModule$CameraStartUpThread.run(PhotoModule.java:319) 12-16 12:08:48.701 5876 5892 W dalvikvm: threadid=13: thread exiting with uncaught exception (group=0x4103c930) 12-16 12:08:48.701 5876 5892 E AndroidRuntime: FATAL EXCEPTION: Thread-402 12-16 12:08:48.701 5876 5892 E AndroidRuntime: java.lang.RuntimeException: openCamera failed 12-16 12:08:48.701 5876 5892 E AndroidRuntime: at com.android.camera.Util.openCamera(Util.java:320) 12-16 12:08:48.701 5876 5892 E AndroidRuntime: at com.android.camera.PhotoModule$CameraStartUpThread.run(PhotoModule.java:319) 12-16 12:08:48.701 5876 5892 E AndroidRuntime: Caused by: com.android.camera.CameraHardwareException: java.lang.RuntimeException: Fail to connect to camera service 12-16 12:08:48.701 5876 5892 E AndroidRuntime: at com.android.camera.CameraHolder.open(CameraHolder.java:219) 12-16 12:08:48.701 5876 5892 E AndroidRuntime: at com.android.camera.Util.openCamera(Util.java:315) 12-16 12:08:48.701 5876 5892 E AndroidRuntime: ... 1 more 12-16 12:08:48.701 5876 5892 E AndroidRuntime: Caused by: java.lang.RuntimeException: Fail to connect to camera service 12-16 12:08:48.701 5876 5892 E AndroidRuntime: at android.hardware.Camera.native_setup(Native Method) 12-16 12:08:48.701 5876 5892 E AndroidRuntime: at android.hardware.Camera.<init>(Camera.java:340) 12-16 12:08:48.701 5876 5892 E AndroidRuntime: at android.hardware.Camera.open(Camera.java:302) 12-16 12:08:48.701 5876 5892 E AndroidRuntime: at com.android.camera.CameraManager.cameraOpen(CameraManager.java:283) 12-16 12:08:48.701 5876 5892 E AndroidRuntime: at com.android.camera.CameraHolder.open(CameraHolder.java:210) 12-16 12:08:48.701 5876 5892 E AndroidRuntime: ... 2 more
There are currently 1937 users online. 0 members and 1937 guests.
