.gif)
Market Fix (All APPS - Uploaded File)
Originally posted by LiquidLimez View PostHas been tested on one 701c indeed worked ! However if someone wants to be guinea pig I will welcome it!! Until i make a new script specific to C
So far it looks like everything works...except there is a weird little glitch whenever I go to download something from the Play store.
You know the message you get about the permissions the app requires just before you start the download? The one with the blue "accept and download" button? That popup/screen for me glitches. Whenever I find an app/game and tap download that screen will flash and then disappera. It will show that message quickly and then it looks like it disappears/minimizes. You can generally make it reappear by tapping the area where it should be and then you can quickly find and tap the "accept and download" button before it disappears again. I have no idea why it's doing it. It could be a combination of the fact that I'm running the ICS script for the 701C and THEN i tried this market fix. I'm not sure.
It's still very usable and other than that it looks like it works just fine. I can definitely find apps that were missing before.
Originally posted by SingleDad View PostThis is working on my 701C running Shawn's ICS rom image for the 701C.
Sent from my Transformer TF101 using Tapatalk 2
Thank You
But I will do what I can!!
Enjoy
I just ran this and am stuck in a bootlopp :-( I have a stock 701-c.... Can't get livesuite to work, although adb works fine... Livesuite keeps saying device not found.... Im on 64 bit win7, so the drivers included with livesuite wont work... I used superoneclick to force a driver on, and ive had another 701-c that ive connected and tinkered with a bit... It's recognized as an adb interface device when plugged in in flash mode... any ideas?
If there are no 64bit drivers for livesuite then try installing VirtualBox and run Windows XP or win732 in a VM. VirtualBox allows you to attach USB devices and use 32bit drivers in the VM.
Just an idea and I use this myself when 64 bit drivers wont work.
FYI, don't use Windows VM (WindowsXP mode) as that VM is not as robust at handling unknown USB devices.
Originally posted by corki2 View PostPerfect. Thank you!
Now google market/play works a bit better - new Play icon.
Antutu is also about 100 pts higher at over 3235 after taking a hit from the slower 32g class 4 sdcard now being used instead of internal memory (changed vold.fstab file).
Still certain files not accessible with this P6210 like google soundback although talkback installs. Google sound/speak feature for search is neat. Also microphone pickup seems clearer.
Originally posted by avgary View PostThanks. Interesting that it changes screen size to 800 x 444 (not 480) and the device is now a samsung phone along with other cpu changes - seems OK but I am not an expert at this stuff.
Originally posted by ratjr15 View Posttried using a friends vista 32 bit machine as well with no luck... was able to install the drivers that came with livesuit this time, but still keep getting "not found device" errors when i hit system update after selecting img
There are currently 2204 users online. 1 members and 2203 guests.
