Market Fix (All APPS - Uploaded File)
    Originally posted by lthornto View Post
    When I tried the download from Southern Telecom, it had "0" file size. I was able to install Shawns ROM and everything is workign fine.
    Have you tried downloading again? Sometimes if the download gets corrupted it will show a file size of zero. Happened to me once. I just downloaded again.
      Originally posted by LiquidLimez View Post
      Hello Peoples,
      I have succeeded to mod out the market and tweak the build prop for video a bit.
      No more missing apps in the market WE Now Have FULL MARKET
      I have packed this file up as a script and will upload tonight.
      This includes a full working market w/ all apps I promise!!!!!
      PMID701c and the PMID701i
      I know everyone loves my scripts (LOL)
      Just making it easier. For others I'll give a description.
      Thanks LiquidLimez for this works great
      Sent from my Polaroid PMID701i using Xparent ICS Blue Tapatalk 2
        thanks, good job
        Got my wife a PTAB702C, (looks like newer model, same specs but adds front camera) at BigLots today, I ran this with no problems, downloaded Angry Birds, probably won't see it again until she wants to do something else on it.
          The new one looks like they deleted the video out port and added a small camera so I guess it depends on which feature is more important to you. I like the video out myself but some could care less and might like a camera better. It seems they are selling all versions till the early ones sell out so you can maybe take your pick if they have all versions in stock at your store.
          Kinda hoping they keep adding better features for around the same price point as I'm using my 701i with video out a lot just to pre check my e mails and play games and look things up without wandering in here and firing up the beast.
            PMID702C and MArketFIx
            I tried to install this from the runme.bat file and it keeps telling me device not found. I have USB debugging enabled on the tablet. also followed the instructions in the readme file.
            Need help! lol
              Need help! lol
              Hello!
              Sounds like you MAY NOT have ADB Windows drivers loaded for the tablet. That can be tricky to pull off sometimes, especially on Windows 7 64-bit machines.
              I picked up a 702c or two, but haven't had time to install the Google apps yet. If you haven't figured it out for yourself soon, I'll give it a shot, and post how I did it...
              73 DE N4RPS
              Rob
                I finally had enough trying to get an old version of Google Market uninstalled, so i reflashed the tablet with Livesuite ver 1.07 (downloaded PMID702C_Firmware_4.0.zip from southerntelecom.com). It wasn't a COMPLETELY smooth process, but it did remove the old market installation i had that wouldn't work.
                I then reinstalled it from the gapps-2.3.4.zip file downloaded from this forum, and that installed Market fine, but its the old version of Market. I thought it would upgrade automatically to Google Play, but it hasn't. I downloaded Android_Market_v3.2.0.apk, and tried to install that but I got the msg I was getting before:
                "Application not installed - an existing package by the same name with a conflicting signature is already installed"
                I set the permissions on it in root explorer as explained elsewhere in this thread first, so I am still at a loss figuring out how to get upgraded to Google Play.
                  I'm not sure why you are having issues..unless it's a hardware/firmware issue between the 701C and the 702C that's causing it. I know on my 701C I followed the directions in the official 701C thread to install the market with updated Google Play and it worked fine. Market did eventually update to the new market. Did you reboot? Sometimes I've had the market not update until I reboot.
                  Secondly, have you tried installing LiquidLimez's market fix from this thread? I think I've read from others on here that it works fine on the 702C. That will give you the updated market and will also unlock many more apps in the market for your tablet.
                  Since you have experience flashing firmware I'd go ahead and give it a go. Worse case scenario is probably just that it doesn't work and you have to reflash the stock firmware again.
                  I'd do a format and flash of the stock firmware and then install the LiquidLimez market fix...but that's just my .02
                    LiquidLimez: This post was so helpful to me that I signed up to freaktab just to thank you.
                    As a side note, after installing your market, I was able to install Google play 3.7.13 over it and it seems to be working great.
                    Tom
                      Originally posted by N4RPS View Post
                      Hello!
                      73 DE N4RPS
                      Rob
                      I have Win 7 x64 & haven't had any problems. I posted a thread a while ago with 'generic' drivers that worked for me (including x64)...
                      https://public.bay.livefilestore.com...ion.png?psid=1
                        Seems to break calendar function
                        I've installed a couple of times now, once setting up the google account before installing the market app and once after installing the market. Both times were on clean flashes of the factory rom.
                        The issue is that the calendar now fails to sync. Going into "Settings > Accounts & sync" it displays the message "sync is currently experiencing problems. It will be back shortly". The calendar sync worked fine before installing market, and is still working fine on my phone.
                        I have the PMID701i 13 unit.
                        Any suggestions are appreciated.
                        BTW..this thread should really be a sticky
                          Calendar Broken
                          I've experianced the same thing. Load this script to "Fix the Market" and you break your calendar.
                          I've had to go back to stock Polaroid rom to get the calendar to work again....
                          Anyone able to correct this in this "fix?"
                          Radian
                            since updating to the latest BusyBox & SuperUser it seems that I lost availability of a lot of apps from Google Play is there update to fix this or do I need to revert back to iniitial instalatîon to get these back?
                            Sent from my Polaroid PMID701i using Xparent ICS Tapatalk 2
                              Radian
                              I reinstalled the calendar sync apk from happened and it fixed the calendar.
                              Sent from my Polaroid PMID701i using Tapatalk 2
                                Polaroid PMID702C Success
                                Hello Peoples,
                                So I just followed the Read Me text file and have had complete success. All the buttons, bothe the physical home and touch array seem to function. Not certian about the calendar right now but will check it out soon.
                                Thanks LiquidLimez..
