(JustXBMC.Apk) For Me, (LibMedia.so Hack Ready), Which XBMC Are You Using Via Your CR11S/CS968
Originally posted by resansid View Post
Detail Audio Settings
Originally posted by Tech1 View PostSir, I'm sorry you are have problems, but you are going about this wrong ... First of all, I never ever told anybody the MX Player was pre-installed in the ROM ... Next thing the XBMC version that's preinstalled in the ROM came from Cloudnetgo it's very old, therefore it's best to delete it ... The MX player must be installed from the Google play store ... Using the JustXBMC.apk in post # 1 above to envoke the drop menu, you must press/hold the cursor on a "Movie Title", just like in the photo above .... Digital audio Settings must be set in two places, in the main Settings area for your Android TV box and for the justXBMC in the audio Settings area ... I have no problems playing DTS audio, works like a charm ... If you continue to have problem please get back with me ASAP ...
Regarding the MX player selection I will try again tonight with the original remote by holding the cursor and see what happens.
As for the Audio settings here is what I have done in detail so please correct me if I missed anything.
Android Settings: Under Sound:
i hv sound input device = rk29rk1000, checked by default, cant uncheck this.
sound output device =
rk29_rk1000,
rockship-spdif,
rk29_rk1000 &
rockchip-spdif,
rockchip-spdif passthrough,
rk29_rk1000 passthrough
Here I am selecting the rockchip-spdif passthrough
Under XBMC settings: System
Audio Output: optical/Coax
Speaker Configuration: 5.1
DTS capable and Dolby Digital AC3 capable: Checked
Audio Output Device: Android, Audiotrack
Passthrough Output device: Libmedia hack by Stafstrom enabled
Under Video Player settings while playing a movie
Audio Output: Optical/Coax
I have these settings as above in 3 different places. Am I missing something else here.
Is there any other place where I have select digital sound. Kindly advise.
Thanks again for your help.
Originally posted by Tech1 View PostInstall the new link MX player ONLY ...! Yes, it has the Libmedia.so hack, it has the 1080p kernel too ... I'm using the 1080p ROM on my CS986, I think it the best of all the ROMs for the CS968, including the custom ROM ...
1) are u using the cloudnet rom which has 1080p (CR11S_cloudnetgo_ap6210_1080p_20131019_update.img ) which is for 2mp model ?
2. Does this rom have by default libmedia.so hack ?
3. After deleting the stock xbmc, then install ur justxbmcv4.apk ?
4. Then install mx player from google play stores. (shd i d/l the custom codec too ? )
5. Set the audio settings in android and justxbmc.
6. should i copy playercorefactory.xml to justxbmc data folder ? to get mx player as default player ?
2. This ROM claims to have the libmedia.so hack built in as confirmed by Tech1.
3. Yes
4. Yes. I installed the mx player armv7 codec.
5. This is where I am having issues. Please see my posts and Tech 1's above. No 5.1 success yet on optical.
6. Not needed as per Tech1. When we hold the cursor it should give us slection to use External MXPlayer. Though I am tempted to still hack it so mx player becomes the default player for xbmc. But I have to resolve the 5.1 sound passthrough issue first.
My device is only 1 day old & havent tried the camera yet. If you have any further tips on optical setup please help me.
Originally posted by Tech1 View PostWho gave you the info to copy the playercorefactory.xml to the JustXBMC ... Where did this come from ...? I don't know about the Libmedia.so hack in the 20131019 ROM build ... Install the new custom codecs for the MX Player also ... Delete the pre-installed XBMC ...Set the audio settings in android and justxbmc .... I'm testing right now the new Cloudnetgo 2mp 1080p ROM dated 20131205 .... I might upload this ROM today with the Libmedia.so hack and pre-rooted ....
Originally posted by resansid View PostHi Tech1, Thanks for good work and I am looking forward to your updated rom. Is it possible you can make mx player as the default player on xbmc? If you plan on loading xbmc to your rom it will be good for all users. Regarding playercore it has successfully replaced default xbmc player to mx player as default in Frodo 12.2 in the past, means it can also be achieved with Justxbmc. I have used xbmc with my MK808B with his setup and have always played content from mx player by default. This was achieved by modifying the playercorefactory.xml, thats how I got this info. As for audio part I hope the libmedia.so fix in your new rom fixes my issue.
My test, so far
Performance:
720p = Perfect.
1080p = Much better than original XBMC but NOT perfect, audio gets desyncronized and lost frames (affects subs)
Overall:
Less crashes, more fast and has SuperRepo! but not all the plugins works as I spect.
The "Select Player" option (MX or Default) is not working, perhaps and old justXBMC or my ignorance
My opinion:
It´s a really good start.
Originally posted by adionesis View PostMy test, so far
Performance:
720p = Perfect.
Overall:
My opinion:
Performance:
720p = Perfect.
Overall:
My opinion:
Originally posted by resansid View PostThanks for confirming I thought I am the only one who couldnt see the player selection issue. As for 1080p files skipping frames I noticed it a little bit but I attributed that to lack of hardware acceleration in other players. But overall I think we have to wait for further improvements before we will be fully satisfied with this device.
Originally posted by Tech1 View PostI just tested the MX player/Default player drop menu and it's working ... I don't have any skipped frames with the MX Player ... Now I am using the newly released 1080p 2mp stock ROM 20131205 ...
Btw: XM Player plays my Camcorder files (AVC-1080p-25mbps) but skipping frames and stop working, I think is the hardware of the device is not enough for this kind of format.
Originally posted by adionesis View PostI Just test the justXBMC with the stock ROM, XM player works perfect in 1080p, I was talking about the justXBMC default player.
Originally posted by Tech1 View PostAre you using the HW decoding settings, and the codecs for the MX Player (Neon) at the Play Store, plus the newly released custom codecs ...?
TV01 (cs968)
Just received my TV01 (cs968) from greekbuying yesterday. I am also having trouble getting surround sound of of hdmi to receiver from Justxbmc. I have been using my T428 with finless rom 1.8 (neo x7) and Justxmbc. That set up worked perfectly for me, no problem at all with 5.1 dolby passthrough. I installed justxbmc v4 on my new TV01, but can't get the passthrough from it. I do get hdmi passthrough using the stock player and mx player, playing from my Synology NAS. Btw, Synology has some great apps for android. Thier video app plays just fine with either player with hdmi passthrough. The original firmware was awfull, kept rebooting every five minutes, so I have tried almost every rom you guys have posted here. The only decent one I have found is TVDroid_v.0.2_htc_t018_ap6210_20131203_PRE_ROOTED NEXUS7.img. Everything seems to work with this rom, except the xbmc hdmi passthrough. Of course it is a pain to have to keep changing the sound output everytime this things reboots. And it does reboot quite often, but not as bad as the original roms.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 1848 users online. 1 members and 1847 guests.
