(JustXBMC.Apk) For Me, (LibMedia.so Hack Ready), Which XBMC Are You Using Via Your CR11S/CS968
Originally posted by Tech1 View PostTry it to play your media files via a UPNP/DLNA path, select MX Player, let me know what happen ....
I'm not sure what else I can do to get another UPNP share here locally.
CN
Originally posted by Cheesenacho View PostIncredibly, almost unbelievable...when I connected a spare drive to my Netgear WNDR4500 and shared the directory, it wouldn't list .iso files. It could see everything else, but not the .iso...
CN
use mx player by default fix
i found this file in /data/data/tv.ouya.xbmc/cache/apk/assets
I changed the DVDplayer to MXPlayer and by default now all files are played by mxplayer.
Code:
<playercorefactory> <players> <player name="MXPlayer" type="ExternalPlayer" audio="true" video="true"> <filename>am</filename> <args> start --user 0 -n com.mxtech.videoplayer.ad/.ActivityScreen -d {1}</args> <hidexbmc>true</hidexbmc> <hideconsole>true</hideconsole> </player> </players> <rules name="system rules"> <rule name="rtv" protocols="rtv" player="DVDPlayer" /> <rule name="hdhomerun/myth/mms/udp" protocols="hdhomerun|myth|cmyth|mms|mmsh|udp" player="DVDPlayer" /> <rule name="lastfm/shout" protocols="lastfm|shout" player="PAPlayer" /> <rule name="rtsp" protocols="rtsp" filetypes="!(rm|ra)" player="PAPlayer" /> <rule name="streams" internetstream="true"> <rule name="aacp/sdp" mimetypes="audio/aacp|application/sdp" player="DVDPlayer" /> <rule name="mp2" mimetypes="application/octet-stream" filetypes="mp2" player="PAPlayer" /> </rule> <rule name="dvd" dvd="true" player="DVDPlayer" /> <rule name="dvdimage" dvdimage="true" player="DVDPlayer" /> <rule name="sdp/asf" filetypes="sdp|asf" player="DVDPlayer" /> <rule name="nsv" filetypes="nsv" player="DVDPlayer" /> <rule name="dgb" filetypes="*.mp4" player="DVDPlayer"/> <rule name="radio" filetypes="pvr" filename=".*/radio/.*" player="DVDPlayer" /> </rules> </playercorefactory>
Originally posted by hanu_blr View Posti found this file in /data/data/tv.ouya.xbmc/cache/apk/assets
Code:
Awesome
Code:
Cannot Find Path (/data/data/tv.ouya.xbmc/cache/apk/assets)
Originally posted by hanu_blr View Postyes using justxbmcv4 apk. it wrks for me.
@tech1,
i did NOT do any decompilining of justxbmcv4.apk. I installed it, then with root explorer, i browsed to this path /data/data/tv.ouya.xbmc/cache/apk/assets and changed the strings.
Ok, on ur computer, open the apk with winrar/7zip, then browse to justXBMCv4.apk\assets\system, there u will see playercorefactory.xml, u can change it there, but am not sure if u hv to sign the apk again.
Awesome
Ok, on ur computer, open the apk with winrar/7zip, then browse to justXBMCv4.apk\assets\system, there u will see playercorefactory.xml, u can change it there, but am not sure if u hv to sign the apk again.Last edited by Tech1; 10 January 2014, 16:19.
(NEWLY RELEASED) JustXBMC_MXPlayerDeFaultX265_HanuBlr_Hack.apk
You can now get the (NEWLY RELEASED) JustXBMC_MXPlayerDeFaultX265_HanuBlr_Hack.apk HERE http://www.freaktab.com/showthread.p...nuBlr_Hack-Apk ....
1080p Playback Problems
If you are having problems with 1080p playback, then you might want to check this out http://www.freaktab.com/showthread.p...-With-The-XBMC ...
Maybe not what you want to hear, but i've given up on xbmc on rk3188. My 5 year old atom does a lot better then the rk3188 for now.
But i've finally found a setup that I like. I've started using mizuu as the frontend (2$ in play store), it gets the same info as xbmc and keeps my library without hassle.
I use subsdownloader for subs (you can select it as a video player and it wil feed the subs to mxplayer). Auto download feature doesn't work for now, but I contacted the dev and he says he will fix it.
mxplayer for actually playing the videos.
when subsdownloader is fixed i'll have a seamless setup that works great.
Maybe it's an option for some of you too.
I've been using xbmc for linux for 8 years now (well, even since the beta's on xbox when it was still xbox media center.), but I also really like my android box and using an airmouse. Using the setup I describe I am finally getting close to the xbmc setup I am used to (because really, xbmc on rk3188 is rubbish).
Originally posted by milenko79 View PostMaybe not what you want to hear, but i've given up on xbmc on rk3188. My 5 year old atom does a lot better then the rk3188 for now.
There are currently 2089 users online. 1 members and 2088 guests.
