(JustXBMC.Apk) For Me, (LibMedia.so Hack Ready), Which XBMC Are You Using Via Your CR11S/CS968
Playing media from local 2TB WD HD
Originally posted by Tech1 View Post
Originally posted by toose View PostHi Tech 1, custom codecs have been installed, default XBMC uninstalled with justXBMC.apk installed. I'm playing media from local external HD connected to USB on CR11S. Problem persists when attempting to play via MXplayer. Is the MXplayer support not designed to work with local external USB HD?
USB connection
Originally posted by Tech1 View PostDid you connect it via the Explore SATA Settings or Network Places ...?
I tested setting up a UPnP connection with my PC and the external(MXplayer) worked.
To confirm, is there anyway I can get MXplayer to work with locally connected USB?
Originally posted by toose View PostDo you mean how did I connect the USB? I connected directly to CR11S USB port. Within XBMC I set up a file location by browsing root file system/mnt/usb_storage/USB_DISK0/Movies. Is this what you mean?
MXplayer with local content
Originally posted by Tech1 View PostTo confirm, is there anyway I can get MXplayer to work with locally connected USB? Now that I don't know ...! Their has to be a way for it to work ...!
This works, but the xbmc version is not as stable as justxbmc.apk
I tried using the playercorefactory.xml with post#1 version of justxbmc.apk. When I click and hold on movie title to bring up 'Play using...' it brings up a long list of media players, the default being MXPlayerFree. I tested MoboPlayer and MXplayerFree, neither worked. DVDPlayer(XBMC Player) did work.
Again, this did work on XBMC version from makesmarttv.net forum.
On an unrelated note, if anyone is having difficulty bringing up the 'Play Using' option and they are using the standard CR11S remote, it is probably the remote which is the issue - it seems the remote can't perform a hold-click function. You may need an alternative input device like a mouse.
Originally posted by toose View PostThere is this solution that works with an older version of XBMC which I think resansid was referring to in an earlier post - http://makesmarttv.net/external-play...mpromise/#8230
Originally posted by Tech1 View PostIf you use a UPNP/DLNA path, the MX Player might work ...!
I tried this and failed, haha, I get the message 'Unable to connect... could not retrieve directory information...'
Do I need to point to the device first in my path or am I not understanding your suggestion?
Originally posted by toose View PostHow would I do that? Would I set up a new network location with UPnP server protocol and server address something like - upnp://mnt/usb_storage/USB_DISK0/udisk0/Movies
Want More Of The Most Popular Plugins, Repositories Zip Files
If you want more of the most popular XBMC add-ons, plugins, (FREE CABLE, *MASH UP,YIFY MOVIES, SPORTS DEVIL, ICE FILMS. 1CHANNEL, TUBEPLUS, USTVNOW, TGUN and MORE ) repositories zip files, then go HERE https://plus.google.com/communities/...20500984874818 ... Just look in the bottom right hand column in the blue links section (XBMC Plugins/Repositories Zip Files), click on the link, (*Mash UP:Rated The #1 Plugin Zip File For XBMC) ....Last edited by Tech1; 26 December 2013, 11:56.
Hi Tech1, After much tinkering and trying various roms I found that only dts passthrough is working. AC3 or DD5.1 is not working. either playing something with dd 5.1 local file or xbmc same issue. It took me a few tries to realize that it is only aC3 format i am having problem with. I have decided to settle with your latest cloudnetgo modified patched rom. There might be two reasons for this and one is that patched libmedia has something with ac3 format that my box doesnt like. Who can help me with the libmedia file that may look into this issue? Other than this issue and the player selection the ROM is pretty good.Last edited by resansid; 25 December 2013, 11:57.
@tech1,
is it possible to set justxbmc to play by mxplayer by default ?. I know long click on the file name brings option to play via different player, but i would like to set by default to mxplayer.
I tried the xda rom CS968 Exclusive MODDED ROM EQS-v2.0M 1080p, looks good, hv u checked the xposed framewrk and gravitybox and app window module ?. Its not wrking for me. Does it wrk for you.
How abt these modules working on ur patched rom ? have u tried ?
Originally posted by resansid View PostHi Tech1, After much tinkering and trying various roms I found that only dts passthrough is working. AC3 or DD5.1 is not working. either playing something with dd 5.1 local file or xbmc same issue. It took me a few tries to realize that it is only aC3 format i am having problem with. I have decided to settle with your latest cloudnetgo modified patched rom. There might be two reasons for this and one is that patched libmedia has something with ac3 format that my box doesnt like. Who can help me with the libmedia file that may look into this issue? Other than this issue and the player selection the ROM is pretty good.
Cloud ergo version
Originally posted by Tech1 View PostWho gave you the info to copy the playercorefactory.xml to the JustXBMC ... Where did this come from ...? I don't know about the Libmedia.so hack in the 20131019 ROM build ... Install the new custom codecs for the MX Player also ... Delete the pre-installed XBMC ...Set the audio settings in android and justxbmc .... I'm testing right now the new Cloudnetgo 2mp 1080p ROM dated 20131205 .... I might upload this ROM today with the Libmedia.so hack and pre-rooted ....
First of all, thanks for your contributions. After, about a bazillion installs of various favors of xbmc, xbmcv4 was able to call up MX player. However, on my CR11S 5M box, I still cannot get my bluray iso's on my smb shares to play in XBMC. Can you please point me in the right direction? You caught my attention on your last post about the CR11S...I have the 5 Dec ROM as well, but no luck so far...
Many thanks in advance,
Can
There are currently 2046 users online. 1 members and 2045 guests.
