(JustXBMC.Apk) For Me, (LibMedia.so Hack Ready), Which XBMC Are You Using Via Your CR11S/CS968
quite puzzled myself
Originally posted by Tech1 View PostI'm using this newly released ROM CR11S/CS968 PRE-ROOTED 1080p 2MP Stock ROM LibMedia.so Hack Ready 20131205 ... I have not had any problems with AC3 5.1/7.1 digital audio via my AV receiver via the CS968 or the JustXBMC ... You should not be having any issues, because the audio set for HDMI pass through is basically the same as the Neo X7 ...MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
justxbmc for neo x7
Originally posted by clarkss12 View PostI am scratching my head also. Btw, I purchased this device per your comentaires. I believe you said it was superior to the neo x7. I am not sure if I want to try this latest rom. I beleive one of the roms i tried earlier from this source , the cam and mic did not work.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
downloading now
Originally posted by Tech1 View PostOk, we knew camera did not work in the other ROM, the camera was not suppose to work, that was a 5MP camera ROM on a 2MP device ... I still believe the CR11S is better than the Neo X7, they have the very same ROM built to the "T", but the ROM runs better on the CR11S ... If I were you, I would still test the new 1080p 2MP ROM , you have nothing to lose ... All you want is to make everything work on your Android TV device ... I will tell you this before you try it, it's better than all the previous ROMs, that I have tested ...
....MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
wow
[QUOTE=Tech1;124162we knew camera did not work in the other ROM, the camera was not suppose to work, that was a 5MP camera ROM on a 2MP device ... I still believe the CR11S is better than the Neo X7, they have the very same ROM built to the "T", but the ROM runs better on the CR11S ... If I were you, I would still test the new 1080p 2MP ROM , you have nothing to lose ... All you want is to make everything work on your Android TV device ... I will tell you this before you try it, it's better than all the previous ROMs, that I have tested ...[/QUOTE]
Now, that is what I am talking about. Everything works. All I say is "wow", just awesome.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
As They Say, I Told You So ...(lol)
Originally posted by clarkss12 View PostNow, that is what I am talking about. Everything works. All I say is "wow", just awesome.Last edited by Tech1; 20 December 2013, 06:09.
Option to use mx player will not execute
Originally posted by Tech1 View PostIt's The best ROM, I Have Ever Had On My CR11S and My CS968, Hands Down .... This ROM Is Truly A Awesome 1080p ROM Build And I Told You So ....! Well it's HERE for download http://www.freaktab.com/showthread.p...Ready-20131205 ..... Glad You Like It ...!(lol)
I have the same ROM as you on Cr11s. I have also installed MX player plus neon arm 7 codec. Also the just xbmc apk, when I select 'play using' and choose mxplayer nothing happens??? The menu disappears and it status in my movie folder. Any ideas???
Originally posted by toose View PostI have the same ROM as you on Cr11s. I have also installed MX player plus neon arm 7 codec. Also the just xbmc apk, when I select 'play using' and choose mxplayer nothing happens??? The menu disappears and it status in my movie folder. Any ideas???
NFS/SMB Path For Movie Playback
PLEASE NOTE: The MX Player can only handle the http protocol for network streams, which works like a charm with "lewy's" newly released "JustXBMCV4" ... If you try to stream movies via your local network using a NFS/SMB path, you will get the error message (Can't Play This Video or The MX Player Will Just Disappear When Open ) ... I'm using the free Serviio DLNA/UPNP Server and Plex Server, sweet with "JustXBMCV4" ... DTS, AC3 works smooth as silk ....! This info has been added to post # 1 ...! If you are going to use a NFS/SMB path to access your media files, then you will have to use the JustXBMC default media player ONLY ...Last edited by Tech1; 20 December 2013, 15:59.
Just xbmc hangs
thanksMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Custom Codecs
Originally posted by resansid View PostIs there a link to download the custom codecs for Mx player. If I search in playstore for "custom codecs for mx player" would I be able to find it?
I already have the armv7 and armv6 codecs installed.
Am I missing anything.
Originally posted by Tech1 View PostTheir is a direct link to the custom codecs in the MX Player app itself ... The direct link will take you to XDA-Developers ... In the MX Player Settings go to> Decoder> GENERAL> "Download custom codecs" .... Please uninstall the armv6 codecs ...!
I will uninstall my Justxbmc app and re-download it from this link http://www.mediafire.com/download/54...justXBMCv4.apk ..Lets hope the correct version resolves it.
Will let you know later this evening.
There are currently 1980 users online. 2 members and 1978 guests.
