Measy U4K and B4K upgrade to 4.2.2 with CS918S firmware
    is it possible to pm me the link for the exact software you used?
    thanks
      Originally posted by ADD View Post
      Yes, you leave it connected with android booted and switch USB debugging on. Then when you install PhoenixSuite it should recongnize your device and install all the necessary drivers. Once done, you launch PhoenixSuite. No need to press anything on B4K, Phoenix will do the rest.
      well so yesterday i was about to do the flshing and my best friend all of a sudden wants to buy my measy b4k in its original state. So I dont think I will be modding. Will keep an open on this foroum incase he wants it modded later on. Thanks for your help and the files.
        Aha-ha, the best way to solve a problem is to get rid of the source of that problem. Good. Hope you'll find a better device that suits your needs. Cheers
          B4K does not have microUSB!
          How am i supposed to flash this without micro usb port?
          I tried goto recovery mode but the enter button on keyboard doesnt work!
          Can someone help??
          Hi everyone!
          Step 2
          Connect Measy to your PC using microUSB. Important: make sure WiFi/BT is switched on.
            Can someone help??
            Just connect usb cable to microusb on measy and another end with normal usb to your pc. Then your measy should boot up.
              b4k
              i have b4k, it does not have micro usb...
              can this be done localy or via network?
              any suggestions?
                any suggestions?
                But you should have one of the USB ports marked as OTG? That's the one to use to connect it to your PC. You don't need the bootloader. Just leave it on when connected to PC.
                  OTG?
                  So basicaly you sayin that i can get usb-male to male cable and flash this device while it's running?
                    That's exactly what I mean.
                      usb cable
                      Well now i just need to wait almost a month for the not standard cable to arrive from dealextreme.
                      Thanx.
                        Thanx.
                        I thought you'd have it in the package with measy, no? Wtf?
                          b4k
                          No man. I don't think measy thought of this..
                          This type of cable (male2 male) is rarely in use by anyone.
                          That's why I have doubts that it will actually work...
                            B4K sucks big time!
                            This "update" seems like a hoax to me because i can't find a way to deploy it on B4K!
                            I have wasted my time and money to obtain USB (male2male) cable, as someone in this forum suggested.
                            When i connect the cable, nothing happens.
                            The pc doesnt recognize usb device. i tried turning on usb debuging, tried with power cord and without one.
                            I'm very annoyed that there's much needed software update out there bt no way to implement it!
                            Damn you measy!
                              Damn you measy!
                              C'mon, take it easy. Let's try to solve it together. See if you have all the drivers installed. Normally, Phoenix should do it. Just chesk in your installed programs on Win7 PC that you have these 3 packages installed.
                              Then make sure that you have connected your measy using OTG port. Also, connect it to the TV to see if it tells you that it's connected in debugging mode.
                              Cheers
                                Thanks for trying to help me.
                                When installing phoenix, i got a popup that these drivers failed to install.
                                Got this popup again when updated to version 1.08.
                                But even without the drivers, when connecting usb device i should hear a sound or something.
                                My TV set is far from my desktop. i can't connect them both at the same time.
                                B4K has 2 standard usb 2.0 ports, is there any way to know which one is OTG? I assume both are or none.
                                There must be a different way to install this on b4k. There's a software update app pre-installed but it's in chinese and it doesn't recognize the img file...
                                Cheers
