Measy U4K and B4K upgrade to 4.2.2 with CS918S firmware
    Originally posted by darrellr View Post
    Re wifi spec can you read off chip name from your photo?
    I Will look and upload the pics tommorow.
    Btw how did you add the forum to tapatalk... I didnt show up when I searched for it
      have uploaded them, quality is not that great, but i only had my cellphone (huawei Y-300 5mp camera) to take the pictures.
      in see a realteak chip not sure if it's that from what i've read it should be a WAPI(Ralink8188)
      antutu reports 1280x720 but i don't have a full hd tv so i had selected 1280x720 don't know if this has an impact
        haven't been messing with the phoenixsuit stuff ... turned my measy box device in a server environment, hooked up an external hd and am running following servers on it:
        ssh (from android)
        ftp (from android)
        webcam (from android)
        webserver with php (from android)
        am using this app (payed version) for it : https://play.google.com/store/apps/d...erversultimate
        vnc (but it's slow since it's using screenshot method, when i acces /dev/graphics/fb0 i only get to see bootscreen :/ don't know why) amd using this payed app for it : https://play.google.com/store/apps/d...lite.vncserver (the framebuffer problem is probably related to the firmware i think)
        i also installed linux deploy (https://play.google.com/store/apps/d...ik.linuxdeploy) and debian wheezy with lxde is running straight from my android where a vnc server is running from the vnc connection here is fast and works great, i'm even amazed how well this runs on the device.
        All my servers are remotly accesable and i have on my router NO-IP dns updater thingie running..
        I'm quite happy now
          How to root device after 4.2.2 update?
          Hi all,
          I've managed to upgrade the B4K device with the zeros + phoenixCard method.
          Since built in camera realy sucks, nor working anymore.
          Can anyone suggest how i can use external usb webcam?
          Currently the built-in camera takes over all the time. How can i disable it?
          Also, how can i root this device after the upgrade? Old method not working anymore.
          I was using shutdown+restart app, but now none work. Does anyone knows how i can shutdown/restart this device without getting up from my chair?
          Thanks yeall.
          Tzvika
            Originally posted by tzvika1 View Post
            Hi all,
            Thanks yeall.
            Tzvika
            you did use the B4K rom right and not the rom from the 1st post ??? cause i have no problems whatso ever with my camera, wifi everything still works, so that's why i'm askin which rom you had put on it .. (if you put that cs rom on it reflash it using the correct B4K ROM for the device https://dl.dropboxusercontent.com/u/...7%E7%BA%A7.zip )
            about root i used this :
            Store photos and docs online. Access them from any PC, Mac or phone. Create and work together on Word, Excel or PowerPoint documents.
            it was for an onda device but works on my measy b4k roms without a problem.
            about the camera, you'll probably need to find a program that lets you specify the device node like /dev/video1 or something, at least i think cam's show up as a video device.
            you can check with busybox lsusb or something in that trend. If you can get the device to pick it up you can use it (given the modules are availble or built in the kernel) so better to use something generic
            edit: about the shutdown apps, first get root, the original rom had root access and some of those apps require root so try after you had gotten root, chances are you previous program might work again (given you let it get root)
              How to root? How to disable built-in camera so i can use my usb webcam?
              1. I have used original B4K ROM, which i got from Measy support and posted here.
              2. When i connect my webcam, it gets recognized but all apps use the built in camera instead.
              I wish to disable the built in cam so it wont take over everytime.
              I'm not linuxoid, so /dev/video1 doesnt say much to me...
              3. there are plenty of apps that require root to shutdown. But i don't know how to root 4.2.2
              The onda root file worked for me with 4.1, but doesnt work anymore with 4.2.2
              Basicaly i need instructions for noobs:
              How to root?
                Hmm i don't really understand how it's possible that it works with me but not with you, since i used the exact same rom as well as method to root. It's kinda weird that while we have same devices / installed same rom / used same root method that it works with me but not with you.
                What does it say / what error ? how do you know it did not work ? (the root access) does it give you an error message or does it tell you it can't update when you select that zip file ? (you have to use the update program then local update and select the zip file from sd card)
                about camera's can't really help, never tried it myselve, but the apps will never work if the usb device doesn't get recognized. If it does what about those apps that some kind of switch to front / back cam.
                i have a few old webcams laying around could try it out once to see if i can get it working.
                  OK I'm trying to work out what to do to get working wifi from crossflashing CS818s firmware on Measy U4K
                  I understand that @ADD has done a lot of research already and there is only a single item that needs amending?
                  Originally posted by ADD
                  Your help is so much appreciated. As I said before, i could only modify sys_config.fex. But since i was doing it on win7 machine, the modification couldn't be done in a correct way.
                  A guy from a russian forum has done it for Explay
                  http://4pda.ru/forum/index.php?showtopic=495048&view=findpost&p=2628961 6
                  Donate to Finless
                    It seems that it'll take another while before elektrik comes with his modifcation. He got a faulty unit which he should send back for replacement. Meanwhile I'm going to try the new B4K 4.2 rom on my U4K one of these days. Will report back.
                      I'm using nand zeroing method to xflash. Fingers crossed! [edit - success!]
                      Have downloaded Allwinner kitchen to Linux and looking how to unpack / pack
                      If you can explain what needs doing I'll have a go
                      Donate to Finless
                        I've flashed the CS918S firmware on to the U4K and it seems there are three problems:
                        1. Lots of chinese crap apps!
                        2. Wireless not working
                        3. SD Card not recognising card inserted (FAT32 format)
                        Donate to Finless
                          So @ADD
                          In sys_config.fex the wifi is set to (3)
                          ;wifi configuration
                          ;wifi_sdc_id --- 0- SDC0, 1- SDC1, 2- SDC2, 3- SDC3
                          ;wifi_usbc_id --- 0- USB0, 1- USB1, 2- USB2
                          ;wifi_usbc_type -- 1- EHCI(speed 2.0), 2- OHCI(speed 1.0)
                          ;wifi_mod_sel --- 0- none, 1- ap6181, 2- ap6210(wifi+bt),
                          ; 3 - rtl8723as(wifi+bt), 4- rtl8189es(SM89E00),
                          ; 5 - rtl8192cu, 6 - rtl8188eu, 7 - mt6620,
                          ; 8 - rtl8723au, 9 - ap6330(wifi+bt+fm)
                          [wifi_para]
                          wifi_used = 1
                          wifi_sdc_id = 1
                          wifi_usbc_id = 1
                          wifi_usbc_type = 1
                          wifi_mod_sel = 3
                          wifi_power = "axp22_dldo1"
                          ; 3 - rtl8723as sdio wifi + bt gpio config
                          rtk_rtl8723as_wl_dis = port:PG10<1><default><default><0>
                          rtk_rtl8723as_bt_dis = port:PG11<1><default><default><0>
                          rtk_rtl8723as_wl_host_wake = port:PG12<0><default><default><0>
                          rtk_rtl8723as_bt_host_wake = port:PG17<0><default><default><0>
                          I assume this should make me "good to go". I got Superuser using the onda apk in the post above and zero'd the nand but I get an error message saying "no space on device".
                          Here's my repacked img if you want to be very brave!
                          Donate to Finless
                            So @ADD
                            Nice. will try it out when I unbrick my U4K. By the way, tried B4K upgrade on U4K. They are not cross flashable!!! It's pitty I cannot edit my first post
                            Another good news - I've finally found the reset button on U4K !!!
                              Where where where!
                              Donate to Finless
                                1. Yes
                                2. 720p upscaled to 1080p
                                But it you want to change it to true 1080p you can do it yourself.
                                Android uses frame buffer for video output. The frame buffer is initialised once upon the boot. The initialisation parameters are defined in the sys_config (script.bin) file which is stored in the bootloader. The default values are set to 720p. You just need to change the next parameter (from default 720p (5) to 1080p (10))
                                screen[0]_output_mode =10
                                and
                                screen[1]_output_mode =10
                                (used for tv/hdmi output, 0:480i 1:576i 2:480p 3:576p 4:720p50 5:720p60 6:1080i50 7:1080i60 8:1080p24 9:1080p50 10:1080p60 11: pal 14:ntsc)
                                Note that after the first boot the output will be downscaled to 720p. You will have to change it in android screen settings back to 1080p.
                                if the img file I uploaded last night works for U4K I'll re-edit to add this too.
                                I see that there is an Onda beta KitKat ROM
                                Would be nice to think that it was possible to port but I guess the kernel / boot loader will be too different
                                Donate to Finless
