Help Identifying t-r42 device
rk3188_box_szy_x6
Ap6210 support
new firmware
https://dl.dropboxusercontent.com/u/...188_x6_4.2.rar
bt worked
wifi worked
lan worked
rooted
Originally posted by endera View PostAp6210 support
new firmware
bt worked
wifi worked
lan worked
rooted
I think that is the most interesting and most stable so far.
My TVBOX is - RK3188_BOX_SZY_X6-
kitkat
CS918 LS_X6_V12 found for this board Kitkata 0_o
Write that everything works except the wi-fi and the drain of the console.
http://vondroid.com/attachments/cyxt...0402-rar.5916/ requires registration to download
Will be right for my audit fees RK3188_BOX_SZY_X6 V1_0 131024? Like all chips are the same.
Originally posted by dowap View PostCS918 LS_X6_V12 found for this board Kitkata 0_o
Ehernet - On
BT-off
Wifi - off
I think It´s the first working kitkat firmware for this board -"RK3188_BOX_SZY_X6 V1_0 131024"
Originally posted by rfsantos View PostYes, it´s confirmed
Ehernet - On
BT-off
Wifi - off
Change the kernel, wifi and bt below works
replace kernel ap6210
http://www.freaktab.com/showthread.p...All-(well-most!)
Excellent
Ehernet - On
BT-off
Wifi - off
And generally behaves Kitkata boxing and does not slow down?
Is there a problem with some sort of applications?
what
BT-off
Wifi - off
I was not critical.
Have you tested it?
Have you tested it?
Originally posted by dowap View PostThank you! And what about the video and how basking chipset?
what
BT-off
Wifi - off
I was not critical.
Thank's.
I´m working with ethernet and till now, I have no doubts that this is a very good firmware for this board
to register to download.Report on the work, put this firmware kitkat 4.4.2. 4.2.2 On the first sensation was familiar and better, root got RootGenius. Temperature and frequency in my board in 1608 mhz, ie kernel already unlocked. Wi-fi and BT does not work, LAN works fine. Noticed one feature a button glows red after flashing always, what it can be connected, I have no idea. Perhaps due to the fact that this is the firmware for any other device. Shutdown and sleep mode is not available, as I have not earned the home button, just back. Antutu 18700 on stock 4.2.2 from fiksennom Frant4 same thing happened. Pleased that runs cooler. Video 30 degrees, HD 40, fulHD as it is not checked, but I think 50 degrees is. Skipping frames with fs Video Systems, torrent tv and other video playback without notice. More experiments are not conducted. Search desire kernel running under my charge Kitkata not test them too and have neither the time nor the desire. Nothing new has been said, and what works hustlers is yes.
As the Americans say - works, do not break.
Overall stock fell back to 4.2.2 (fix by Frant4), without any problems.
p.s. http://www.freaktab.com/showthread.p...Kat-Version%29 and work here and wifi bt, but does not work LAN. Experts tell whether two cores, 2 Kitkata make a hybrid with working WiFi, bt and lan? Or at least WiFi and lan.
Looks like I'm not alone in facing the withdrawal of hibernation.
Originally posted by endera View PostKitKat
and
Kernel
WiFi ok
BT ok
Ethernet ok
Power Led Red
Thank you, have a sleep mode? Will be installed as a time and test.
and
Kernel
WiFi ok
BT ok
Ethernet ok
Power Led Red
It appears the wasser label when turn on the TVBoc, but nothing more.
Do you upgrade also the "parameter", or only the Kernel ?
There are currently 3933 users online. 0 members and 3933 guests.
