fw LİNK ??
Help Identifying t-r42 device
New stock firmware for
Originally posted by skyking_comms View PostI'd also be interested in the link, but would like the LAN to work
Also, you can try the new universal Wasser firmware 1.2.4.
I can't try this firmwares. Anybody, please, check this firmware on board and write about its.
I can't try this firmwares. Anybody, please, check this firmware on board and write about its.BT does not work with WiFi does not Work (firmware-wasser-1.2.4.zip)
wifi and bluetooth does not work...
Originally posted by Frant View PostThank you, this is not good news, will see more...
Originally posted by endera View Post
I understand, what you can not load firmware, isn't it?
In your photo i see, what point 1 hasn't any color, i think device not connected to system in preloader mode. Before loading firmware, point 1 must be green.
In movie I see, what device not loaded, may be incorrect or failed load firmware.
This device can powered from USB-OTG. For first step, you must disconnect power supply and USB-OTG from PC. Than, put reset button on box, than, connect USB to PC. In sytem must appear PreloaderMTK device (in Device Manager). You can apply power supply or not, try that and that. In RKBatchTool must be green in 1 point. Then trying load stock firmware via Restore button.
If you get error, try RKDevelopTool_v1.37 to clear flash, whitch included in Wasser 1.2.4 firmware pack. Than, repeate all one more time.
Tell me more, what happiens with your box, in this moment I can't tell anymore...
Originally posted by Frant View PostI understand, what you can not load firmware, isn't it?
Thank you.
point 1 must be green.5 seconds...
but the device is shutting the power down after 5 seconds.
There are currently 5021 users online. 1 members and 5020 guests.
