Help Identifying t-r42 device
    Originally posted by endera View Post
    Thank you.
    This firmware is rooted.
    Do you try it? Does LAN work?
      Originally posted by Frant View Post
      Thank you.
      Yes...
      LAN is working
      WiFi is working
        Yes...
        LAN is working
        WiFi is working
        Has anyone tested VPN on it and is it working ?
          Is there another link as the download is very very slow
            Here is link
            Посмотреть и скачать с Яндекс Диска
              Thank you!
                not very stable
                I have been using this firmware for more than a week. WiFi is not stable and connects always at 65Mbps. Ethernet is not stable as well (but much faster than wifi), and the internet just stops occasionally. It is really hard to turn LAN ON. Most of the time device must be switched OFF and then after cold restart LAN can be switched ON.
                Other problems are with Sound. Very ofter sound output is corrupted and sounds cracking and something like numerous parasite reverb/echoes applied onto the orignal sound and that hears as cracking noise. This is strange because I got same sound problems with the original firmware which device came (DEC/2013) and now there are same issues with this firmware. After few reboots the sound could improve by itself...
                Frant, do you modify the firmware or you could obtain it from the manufacturer?
                  firmware
                    MK918?
                    endera, did you test this? This is for MK918. According to this post CS918B (rk3188_box_szy_x6
                    v1_0 131024) and MK918 are different (they share common hardware, but PCBs are completely different.
                    Check this out:
                    Hi Guys: The reason i write this post is we are seeing so much questions, and problems which customer are faced for the following device: Well, this photo is coming […]
                      firmware
                      pcb different but the same hardware..
                        OK, but do you have any info to share about this firmware. Bugs, stability, real 1080p kernel?, rooted? etc.
                        Do you think someone is going to flash something that is completely not documented.
                          Hello people
                          I'm New Here
                          I just got a cs918 with bluetooth
                          I tried to put some roms and the only one that works properly is all the stock rom
                          someone with this device can tell me what is the best rom for this device?
                          someone managed to put a OC kernel and working properly?
                          greetings to all and thanks
                            I'm holding off until a stable firmware is released
                              Same here.
                              So far the most stable firmware in my experience is: cxy_cs918_BT_box_ap6210_131120_en
                              It has an very stable WIFI/LAN connection, and is not glitchy or anything else.
                              If is not broken don't fix it. Firmware link can be found here:
                              http://pan.baidu.com/s/1gTkTS#dir/pa...1120_CS918_CXY
                              (Use google chrome to translate this page)
                                is this version rooted?
                                Originally posted by albaniansniper View Post
                                Same here.
