Help Identifying t-r42 device
cs918_3188_ap6210_20140212_by_Frant
Originally posted by harris View Post
I made modification in this firmware. Link to it https://www.dropbox.com/s/3we99al3ro...2_by_Frant.zip
Modification log:
26.02.2014
1) Kernel vsync fix
2) Added Reboot application v.1.2.1
3) Rooted
4) Tweaked build.prop (present original, see in /system/ )
5) Added overclocked kernels
6) Added loader drivers (for programming mode)
7) Added RKDevelopTool_v1.37 from firmware Wasser 1.2.4 pack (for loading kernels)
8) Added RKbatchTools (for loading image)
Modification log:
26.02.2014
1) Kernel vsync fix
3) Rooted
Tnks....
szy
I did not work in this version
Modification log:
26.02.2014
1) Kernel vsync fix
3) Rooted
rk3188_box_szy_x6
hi frant,
supports ?
Added RKDevelopTool_v1.37 from firmware Wasser 1.2.5 pack (for loading kernels)
Modification log:
26.02.2014
1) Kernel vsync fix
3) Rooted
Originally posted by endera View Post
Originally posted by endera View Posthi frant,
overclok kernel 1.8ghz(kernel_cpu1800h_gpu798h_ddr720.img) does not work. 1608mhz work
szy
Originally posted by Frant View PostSeems, this clocks are very high to your box (stock clocks are CPU 1600, DDR 600). This a most higher aviable clocks for 3 different chips. If one of them can't work on high clock, whole device can't work normal.
rk3188_box_szy_x6
Originally posted by Frant View PostWhat is this a kernel image?
My device(rk3188_box_szy_x6) in the running, but the screen flickers ... 1.9ghz
http://www.freaktab.com/showthread.p...-0-1-9a-1-7%29
If you want to put overclocking kernel with all working features on your device, you can get original kernel from you good working firmware and make overclocking kernels set and try its until to found good working kernel. In my firmware packs I put and original kernel, you can use it.
See original kernel in my firmware packs:
szy_rk3188_box_ap6210_140110_by_Frant.zip
cs918_3188_ap6210_20140212_by_Frant.zip
There are currently 3966 users online. 1 members and 3965 guests.
