UPDATE - T-R42 - wasser firmware - Kikat Android 4.4.2
Best release yet. The only problem I have is that with this version the remote does not entirely work. It wont let me type in a path to go to some where. Is this a problem with firmware or is it a setting in XBMC or a setting somewhere else. I can move forward and d back and mve my pointer around but when I try to type a letter on screen keyboard it doesn't do anything. This is a stock IR remote which came with box.
wifi and bluetooth doesn't work
Hi all,
I have cs918 with BT (inside on the board it says b351_V1.1), flashed the
wasser-firmware-kikat-t-r42-old-1.0.3 rom, the WIFI and the BT doesn't work.
what to do?
any other good rom i can try?
B351 v2.0 board and 720p fail
Hello,
I have a T-R42 B351 v2.0 board and I have installed your Kitkat 4.4.2 1.0.3 old revision firmware.
My tv only supports 720p, I have connected the T-R42 through miniHDMI cable but all I get is a Blue Screen.
What's wrong?
No 720p support in this firmware?
Thanks.
Originally posted by kayak1987 View PostI don't know about the 720/1080p problem but some posts ago someone suggest to flash the "NEW" version on the V2.0 Board.
On my T-R42 v2.0 board this version seems to work well except for the wifi
Try the NEW and let us know if also you have WIFI problems..
Originally posted by robot20 View PostBest release yet. The only problem I have is that with this version the remote does not entirely work. It wont let me type in a path to go to some where. Is this a problem with firmware or is it a setting in XBMC or a setting somewhere else. I can move forward and d back and mve my pointer around but when I try to type a letter on screen keyboard it doesn't do anything. This is a stock IR remote which came with box.
Settings->System->Input devices-> Enable the "Remote control sends keyboard presses" setting.
Further Overclocking possible?
I have a v1.1 board and the 1.0.3 old firmware works very very well - thanks a bunch, wasser! Just in terms of overclocking, I believe I could use a kernel that can push this little T-R42 a bit more.
Using a modified stock 4.2.2 FW I was solid rock at 1,704 Hz CPU speed and it was a bit faster when playing 1080p on xbmc (also AnTuTu score 20K vs 19K now). The default kernel wasser created for his KK rom is max'ed to 1,608 Hz. I wonder if this is a limitation imposed by the KK source code that wasser is using, or just a matter of time before he can work out a stable kernel with additional OC.
I even tried to experiment modifying the kernel.img that comes with wasser's rom using the overclockomatic3188 perl script from phjanderson's rkpatchomatic tool (thread here), and after some modifications to the perl script (as well as commenting out the DDR speed modification code because I do not really need to push DDR further) I was able to generate variations of CPU and GPU kernels which, based on visual inspection of the binary file in an hex editor, seem fine. However when I flashed it back to the device using either RKDevelopTool (just flashing modified kernel.img) or flash_image from within the linux OS, I always get to the same result: device does not boot and goes straight to recovery mode. If anyone has any advice or tip for me to try, please let me know.
Originally posted by JoKeRz View PostI have a v1.1 board and the 1.0.3 old firmware works very very well - thanks a bunch, wasser! Just in terms of overclocking, I believe I could use a kernel that can push this little T-R42 a bit more.
you need a new rkpatchomatic to oc my kernels. You can download it from here.
Originally posted by wasser View Postyou need a new rkpatchomatic to oc my kernels. You can download it from here.
http://www.freaktab.com/showthread.p...d-4-4-2/page12
Cheers!
Originally posted by JoKeRz View PostThanks for the link, wasser. I compared that perl script from that post with the one I modified and they are pretty much the same. So I am not sure why it does not work. I am starting to suspect the problem was either the way I extracted the kernel.img from your package (I used imgRePackerRK) or the way I am trying to flash the modified kernel.img. I will keep trying...
Cheers!
Code:rkcrc -k kernel.img kernel_good.img
Originally posted by JoKeRz View PostThis is a setting in XBMC indeed. I will save you the trouble to look for it:
Other then this work around I was able to stream a 1080 p movie to device and it worked perfectly.
Thanks all for your help especially Wasser.
There are currently 1002 users online. 7 members and 995 guests.
