I will try it and a post back.
UPDATE - T-R42 - wasser firmware - Kikat Android 4.4.2
Hi I just received a new BELL 1000 home DSL modem. Im running the latest firmware on my TR42 B351_V2.0 1080p new. My box will not connect wirelessly to this device. It seems to connect and then when it tries to obtain ipaddress it doesnt complete. Im sure I have the proper network and password. My other devices connect wirelessly. I even reinstalled the old modem and I was able to connect wirelessly. Im currently connected to new modem hard wired.
Does it sound like my new modem is not supported by latest firmware on TR42Last edited by robot20; 07-05-2015, 20:00.
I have buy a EKB311 MK888B CS918 Q7 T-R42 Android box in aliexpress,
http://fr.aliexpress.com/item/New-Bl...001649535.html
But I'm very disappointed for the poor OS integrated in the machine. All programs is installed in the 2G system partition and the simple fact of move them is impossible.
What type of version of this firmware I must install in my machine ?
Thanks to reply meLast edited by Saph; 07-29-2015, 13:51.
If you feel up to it. The first step is to take the rubber pads off the bottom of box. Take screws out. Carefully pull box apart. Printed on PCB will be the version of board (ex mine is B351_V2.0).
From this info and your tv setup (720p or 1080p) this will tell you what files to flash. Download package from beginning of thread, flash drivers for usb port and select the files to flash.
Guest
Hello,
Here for all who need help....
Take the rubber pads off the bottom of box. Take screws out. Carefully pull box apart. You will see whats Printed on PCB Version of Board! Ok, Noted it..
Board (PCB) Version:
When you have a T-R42-V3.5 then flash 1.0.4 KitKat ...New Rev...
When you have a T-R42-Under-V3.5 the flash 1.0.4 KitKat ...Old Rev...
When you have a B351_V2.0 then flash 1.0.4 KitKat ...New Rev...
When you have a B352_V1.X then flash the 1.0.4 KitKat ...Old Rev...
When you have a K-RK3188-V4.3, K-RK3188-V4.2 or K-RK3188-V3.5 then flash the 1.0.4 KitKat ...New Rev...
720p or 1080p Setup? = Not need to show off it ...every kernel here of the Firmware is Universal! By me its worked on both TV's (720p HDMI and 1080p HDMI) (AV Not Tested!)...
Best regards,
jamal2367Last edited by Guest; 08-10-2015, 22:17.
HI can someone pls help me, i am using the android tr42 and i installed one of the wasser firmware from this page i think it was the 0.95. it just came with wasser xbmc and superuser but no launcher. can someone pls tell me or link me to a launcher i can install so i can make xbmc auto load when i start the tr42. thanks
Hi, I've installed 1.0.4_old on my "B351 v1.1 2013/08/30" board .
1. WiFi and BT don't working
2, YouTube application can't play any video (black screen and text).
From the Chrome browser on youtube.com I can see video in windowed mode nolmal, but in full screen mode - with bluish shade (especially visible on skin)
Help me, pls...
I got a Problem with youtube, it says On playback, a problem has occurred. To repeat press button" (translated from German) please help me, i need youtube working. I read and try so much but nothing helps.
Edit: I test all your KitKat Versions and non of them can play YouTube Videos ?? Now i downgraded to JB and install your 1.2.5 Rom and now all works like a charm, no idea why this happening?
Edit 2nd: The Device Spoofing is the Problem, YouTube dont want that or what ? When i spoof my Minix X7 as a Nexus 7, YouTube has the same Problem, so its not the Rom, its YouTube thats sucks in this Case...
Thanks !!!Last edited by TVDroid; 02-07-2016, 12:24.... TVDroid
> > > Devices: Minix Neo X7 & HiSilikon® T-R42 II < < <
Hello! I flashed your firmware version 1.0.4 (Android 4.4.2), the performance of a very good level, thanks for your work!
Not work on my tv-box:
WiFi & BT
My Device:
cs918 (t-r42, ekb311b)
Version PCB RK3188_BOX_v3.0
On my box chips:
WiFi & BT (MT7601 & MT6622)
LAN (RLT8201)
I'd like to work WiFi and BT !
Code:root@manta:/ # dmesg <6>[ 0.000000] Initializing cgroup subsys cpu <5>[ 0.000000] Linux version 3.0.36+ ([email protected]) (gcc version 4.7 (GCC) ) #61 SMP PREEMPT Sat Jul 12 21:43:21 CEST 2014 <4>[ 0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d <4>[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache <4>[ 0.000000] Machine: RK30board <4>[ 0.000000] ddr size = 2048 M, set ion_reserve_size size to 125829120 <6>[ 0.000000] memory reserve: Memory(base:0x98800000 size:120M) reserved for <ion> <6>[ 0.000000] memory reserve: Memory(base:0x97000000 size:24M) reserved for <fb0 buf> <6>[ 0.000000] memory reserve: Total reserved 144M <4>[ 0.000000] Memory policy: ECC disabled, Data cache writeback <6>[ 0.000000] bootconsole [earlycon0] enabled <4>[ 0.000000] CPU SRAM: copied sram code from c0edd000 to fef00100 - fef02098 <4>[ 0.000000] CPU SRAM: copied sram data from c0edef98 to fef02098 - fef029c8 <4>[ 0.000000] sram_log: @ 0q @ P 1 / ! aB@ 2 `" 2q : 4q <4>[ 0.000000] CLKDATA_MSG: pll_flag = 0x00 <4>[ 0.000000] hzb test rmii clk get form clkin <3>[ 0.000000] CLKDATA_ERR: can't get a available nume and deno <3>[ 0.000000] CLKDATA_ERR: clk_frac_div can't get rate=48000000,uart0_frac_div <6>[ 0.000000] L310 cache controller enabled <6>[ 0.000000] l2x0: 16 ways, CACHE_ID 0x4100c0c8, AUX_CTRL 0x76050001, Cache size: 524288 B <4>[ 0.000000] DDR DEBUG: version 1.00 20131106 <4>[ 0.000000] DDR DEBUG: DDR3 Device <4>[ 0.000000] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=2 Total Capability=2048MB <4>[ 0.000000] DDR DEBUG: init success!!! freq=220MHz <4>[ 0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x24, DGSL=0 extra clock, DGPS=180 <4>[ 0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x24, DGSL=0 extra clock, DGPS=180 <4>[ 0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x24, DGSL=0 extra clock, DGPS=180 <4>[ 0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x24, DGSL=0 extra clock, DGPS=180 <4>[ 0.000000] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 <4>[ 0.000000] DDR DEBUG: DRV Pull-Up=0xb, DRV Pull-Dwn=0xb <4>[ 0.000000] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 <4>[ 0.000000] Boot mode: REBOOT (6) flag: NORMAL (0xc3524200) <7>[ 0.000000] On node 0 totalpages: 487424 <7>[ 0.000000] free_area_init_node: node 0, pgdat c0eda6c0, node_mem_map c2150000 <7>[ 0.000000] Normal zone: 976 pages used for memmap <7>[ 0.000000] Normal zone: 0 pages reserved <7>[ 0.000000] Normal zone: 123952 pages, LIFO batch:31 <7>[ 0.000000] HighMem zone: 3120 pages used for memmap <7>[ 0.000000] HighMem zone: 359376 pages, LIFO batch:31 <6>[ 0.000000] PERCPU: Embedded 7 pages/cpu @c315d000 s7040 r8192 d13440 u32768 <7>[ 0.000000] pcpu-alloc: s7040 r8192 d13440 u32768 alloc=8*4096 <7>[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 <4>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 483328 <5>[ 0.000000] Kernel command line: console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00150000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x00006000@0x00004000(kernel),0x00006000@0x0000a000(boot),0x00010000@0x00010000(recovery),0x00020000@0x00020000(backup),0x00040000@0x00040000(cache),0x00002000@0x00080000(metadata),0x00002000@0x00082000(kpanic),0x00180000@0x00084000(system),-@0x00204000(userdata) bootver=2014-03-03#2.13 firmware_ver=4.4.2 <6>[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) <6>[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) <6>[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) <6>[ 0.000000] allocated 8388608 bytes of page_cgroup <6>[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups <6>[ 0.000000] Memory: 880MB 1024MB = 1904MB total <5>[ 0.000000] Memory: 1901108k/1901108k available, 196044k reserved, 1449984K highmem <5>[ 0.000000] Virtual kernel memory layout: <5>[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) <5>[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) <5>[ 0.000000] DMA : 0xff600000 - 0xffe00000 ( 8 MB) <5>[ 0.000000] vmalloc : 0xdf000000 - 0xfe800000 ( 504 MB) <5>[ 0.000000] lowmem : 0xc0000000 - 0xde800000 ( 488 MB) <5>[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) <5>[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) <5>[ 0.000000] .init : 0xc0408000 - 0xc062f000 (2204 kB) <5>[ 0.000000] .text : 0xc062f000 - 0xc0e52df4 (8336 kB) <5>[ 0.000000] .data : 0xc0e54000 - 0xc0edc4e8 ( 546 kB) <5>[ 0.000000] .bss : 0xc0ee0024 - 0xc19912a8 (10949 kB) <6>[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 <6>[ 0.000000] Preemptible hierarchical RCU implementation. <6>[ 0.000000] NR_IRQS:352 <4>[ 0.000000] rk30_gpio_init: 128 gpio irqs in 4 banks <6>[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms <4>[ 0.000000] rk_timer: version 1.3 <6>[ 0.003750] Calibrating delay loop (skipped) preset value.. 1583.48 BogoMIPS (lpj=7917420) <6>[ 0.012878] pid_max: default: 32768 minimum: 301 <6>[ 0.018149] Security Framework initialized <6>[ 0.022789] Mount-cache hash table entries: 512 <6>[ 0.028399] Initializing cgroup subsys debug <6>[ 0.033171] Initializing cgroup subsys cpuacct <6>[ 0.038147] Initializing cgroup subsys memory <6>[ 0.043029] Initializing cgroup subsys freezer <6>[ 0.048004] CPU: Testing write buffer coherency: ok <4>[ 0.134389] CPU1: Booted secondary processor <4>[ 0.174377] CPU2: Booted secondary processor <4>[ 0.214377] CPU3: Booted secondary processor <6>[ 0.214422] Brought up 4 CPUs <6>[ 0.232026] SMP: Total of 4 processors activated (6333.93 BogoMIPS). <6>[ 0.239440] devtmpfs: initialized <6>[ 0.249300] NET: Registered protocol family 16 <6>[ 0.254382] last_log: 0xde100000 map to 0xdf004000 and copy to 0xc0ee41a0 (version 2.1) <4>[ 0.279859] DVFS MSG: AVS Value(index=0): 163 162 163 163 162 162 163 162 162 163 <6>[ 0.298913] lcdc0 is used as external display device contoller! <6>[ 0.305552] lcdc1 is used as primary display device controller! <6>[ 0.412377] rk29sdk_wifi_bt_gpio_control_init: init finished <6>[ 0.420034] console [ttyFIQ0] enabled, bootconsole disabled <6>[ 0.429204] Registered FIQ tty driver de035cc0 <6>[ 0.429835] Loaded driver for PL330 DMAC-1 rk29-pl330 <6>[ 0.429881] DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12 <6>[ 0.430069] Loaded driver for PL330 DMAC-2 rk29-pl330 <6>[ 0.430115] DBUFF-64x8bytes Num_Chans-7 Num_Peri-20 Num_Events-14 <6>[ 0.461908] bio: create slab <bio-0> at 0 <5>[ 0.466367] SCSI subsystem initialized <6>[ 0.466582] usbcore: registered new interface driver usbfs <6>[ 0.466699] usbcore: registered new interface driver hub <6>[ 0.480951] usbcore: registered new device driver usb <6>[ 0.481231] rk30_i2c rk30_i2c.0: i2c-0: RK30 I2C adapter <6>[ 0.481491] rk30_i2c rk30_i2c.1: i2c-1: RK30 I2C adapter <6>[ 0.481687] rk30_i2c rk30_i2c.2: i2c-2: RK30 I2C adapter <6>[ 0.481839] rk30_i2c rk30_i2c.3: i2c-3: RK30 I2C adapter <6>[ 0.482129] rk30_i2c rk30_i2c.4: i2c-4: RK30 I2C adapter <6>[ 0.512546] rk30-adc rk30-adc: rk30 adc: driver initialized <6>[ 0.512655] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics <6>[ 0.512879] rk29-wdt rk29-wdt.0: starting watchdog timer <6>[ 0.513140] Advanced Linux Sound Architecture Driver Version 1.0.24. <6>[ 0.513602] Bluetooth: Core ver 2.16 <6>[ 0.513701] NET: Registered protocol family 31 <6>[ 0.513743] Bluetooth: HCI device and connection manager initialized <6>[ 0.513798] Bluetooth: HCI socket layer initialized <6>[ 0.513844] Bluetooth: L2CAP socket layer initialized <6>[ 0.513901] Bluetooth: SCO socket layer initialized <4>[ 0.515010] rk fb probe ok! <4>[ 0.519757] act8846_set_init,line=17 <4>[ 0.519794] act8846_set_init:g_pmic_type=3 <4>[ 0.521499] act8846_set_init act_dcdc1 =1200000mV end <4>[ 0.523294] act8846_set_init vdd_core =1000000mV end <4>[ 0.525086] act8846_set_init vdd_cpu =1000000mV end <4>[ 0.526877] act8846_set_init act_dcdc4 =3300000mV end <4>[ 0.528068] act8846_set_init act_ldo1 =1000000mV end <4>[ 0.529157] act8846_set_init act_ldo2 =1200000mV end <4>[ 0.530244] act8846_set_init act_ldo3 =1800000mV end <4>[ 0.531332] act8846_set_init act_ldo4 =3300000mV end <4>[ 0.532420] act8846_set_init act_ldo5 =3300000mV end <4>[ 0.533510] act8846_set_init act_ldo6 =3300000mV end <4>[ 0.534600] act8846_set_init act_ldo7 =1800000mV end <4>[ 0.535690] act8846_set_init act_ldo8 =2800000mV end <4>[ 0.535742] act8846_set_init,line=78 END <4>[ 0.535817] i2c-core: driver [act8846] using legacy suspend method <4>[ 0.535869] i2c-core: driver [act8846] using legacy resume method <4>[ 0.535951] rk1000_control_probe <4>[ 0.560903] rk1000_control_probe ok <6>[ 0.560989] Switching to clocksource rk_timer <6>[ 0.563652] Switched to NOHz mode on CPU #0 <6>[ 0.564427] Switched to NOHz mode on CPU #2 <6>[ 0.564442] Switched to NOHz mode on CPU #3 <6>[ 0.564456] Switched to NOHz mode on CPU #1 <4>[ 0.568765] lcdc1:reg_phy_base = 0x1010e000,reg_vir_base:0xdf0ac000 <4>[ 0.568866] fb0:win0 <4>[ 0.568872] fb1:win1 <4>[ 0.568877] fb2:win2 <4>[ 0.568980] rk3188 lcdc1 clk enable... <4>[ 0.594116] rk3188 lcdc1 clk disable... <4>[ 0.670673] fb0:phy:97000000>>vir:e0000000>>len:0x1800000 <4>[ 0.670975] rk_fb_register>>>>>fb0 <4>[ 0.671371] rk_fb_register>>>>>fb1 <4>[ 0.704206] rk3188 lcdc1 probe ok! <4>[ 0.704310] lcdc0:reg_phy_base = 0x1010c000,reg_vir_base:0xdf0c0000 <4>[ 0.704393] fb0:win0 <4>[ 0.704399] fb1:win1 <4>[ 0.704404] fb2:win2 <4>[ 0.704510] rk3188 lcdc0 clk enable... <4>[ 0.729604] rk3188 lcdc0 clk disable... <4>[ 0.729647] fb2:phy:97000000>>vir:e0000000>>len:0x1800000 <4>[ 0.729912] rk_fb_register>>>>>fb2 <4>[ 0.730264] rk_fb_register>>>>>fb3 <4>[ 0.730298] rk3188 lcdc0 probe ok! <6>[ 0.731487] cfg80211: Calling CRDA to update world regulatory domain <6>[ 0.791294] IT66121 probe success. <6>[ 0.794698] NET: Registered protocol family 2 <6>[ 0.794859] IP route cache hash table entries: 16384 (order: 4, 65536 bytes) <6>[ 0.795230] TCP established hash table entries: 65536 (order: 7, 524288 bytes) <6>[ 0.796258] TCP bind hash table entries: 65536 (order: 7, 786432 bytes) <6>[ 0.797722] TCP: Hash tables configured (established 65536 bind 65536)<6>[ 0.797776] TCP reno registered <6>[ 0.797810] UDP hash table entries: 256 (order: 1, 8192 bytes) <6>[ 0.797874] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) <6>[ 0.798196] NET: Registered protocol family 1 <6>[ 0.846231] RPC: Registered named UNIX socket transport module. <6>[ 0.846286] RPC: Registered udp transport module. <6>[ 0.846336] RPC: Registered tcp transport module. <6>[ 0.846376] RPC: Registered tcp NFSv4.1 backchannel transport module. <6>[ 0.846595] Unpacking initramfs... <6>[ 0.919086] Freeing initrd memory: 1344K <6>[ 0.919216] PMU: registered new PMU device of type 0 <4>[ 0.919346] efuse_version_val: efuse version = 51 <4>[ 0.919391] DVFS MSG: core: dvfs_adjust_table_lmtvolt get leakage_level = 3000 <4>[ 0.919459] efuse_version_val: efuse version = 51 <4>[ 0.919539] DVFS MSG: aclk_gpu: dvfs_adjust_table_lmtvolt get leakage_level = 3000 <4>[ 0.952282] rk3188 cpufreq version 2.2, suspend freq 816 MHz <4>[ 0.952620] vpu: power on <6>[ 0.952690] VPU_SERVICE: checking hw id 4831 <4>[ 0.965271] vpu: power off...done <6>[ 0.965333] VPU_SERVICE: init success <6>[ 0.965702] audit: initializing netlink socket (disabled) <5>[ 0.965778] type=2000 audit(0.900:1): initialized <4>[ 0.968295] highmem bounce pool size: 64 pages <6>[ 0.968476] ashmem: initialized <6>[ 0.995296] nfs4filelayout_init: NFSv4 File Layout Driver Registering... <6>[ 0.995687] NTFS driver 2.1.30 [Flags: R/W]. <6>[ 0.995920] fuse init (API version 7.16) <6>[ 1.011083] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252) <6>[ 1.011147] io scheduler noop registered <6>[ 1.011187] io scheduler deadline registered <6>[ 1.011275] io scheduler cfq registered (default) <6>[ 1.031556] rga: Driver loaded succesfully <4>[ 1.031695] rk3188 lcdc0 clk enable... <4>[ 1.031737] lcdc0: dclk:148500000>>fps:60 <6>[ 1.031774] rk30-lcdc rk30-lcdc.0: rk3188_load_screen for lcdc0 ok! <6>[ 1.032241] rk1000_tv ver 2.0 probe ok <4>[ 1.032340] ******** Show Sink Info ******** <4>[ 1.032375] Support video mode: <4>[ 1.032402] 1920x1080p@60Hz. <4>[ 1.032426] 1920x1080p@50Hz. <4>[ 1.032449] 1920x1080p@24Hz. <4>[ 1.032472] 1280x720p@60Hz. <4>[ 1.032495] 1280x720p@50Hz. <4>[ 1.032518] 720x576p@50Hz. <4>[ 1.032540] 720x480p@60Hz. <4>[ 1.032563] Support audio type: LPCM <4>[ 1.032591] Support audio sample rate: <4>[ 1.032620] 32000 <4>[ 1.032636] 44100 <4>[ 1.032653] 48000 <4>[ 1.032670] Support audio word lenght: <4>[ 1.032699] 16bit <4>[ 1.032715] 20bit <4>[ 1.032731] 24bit <4>[ 1.032748] ******** Show Sink Info ******** <4>[ 1.032789] rk3188 lcdc1 clk enable... <4>[ 1.032830] lcdc1: dclk:148500000>>fps:60 <6>[ 1.032864] rk30-lcdc rk30-lcdc.1: rk3188_load_screen for lcdc1 ok! <6>[ 1.032915] lcdc1 wakeup from standby! <6>[ 1.032947] lcdc1 win0 open,atv layer:1 <6>[ 1.032988] lcdc1 win1 closed,atv layer:1 <4>[ 1.033222] rk_serial.c v1.6 2013-12-23 <6>[ 1.033331] rk_serial.0: ttyS0 at MMIO 0x10124000 (irq = 66) is a rk29_serial.0 <6>[ 1.033534] rk_serial rk_serial.0: membase 0xdf0c8000 <6>[ 1.033615] rk_serial.3: ttyS3 at MMIO 0x20068000 (irq = 69) is a rk29_serial.3 <6>[ 1.033813] rk_serial rk_serial.3: membase 0xdf0d0000 <6>[ 1.034053] Rockchip ion module(version: 1.0) is successfully loaded <6>[ 1.036473] loop: module loaded <6>[ 1.036532] Android kernel panic handler initialized (bind=kpanic) <6>[ 1.037721] rk29 vmac rk29 vmac.0: ARC VMAC at 0x10204000 irq 51 0e:67:9b:ec:8d:9b <6>[ 1.037814] PPP generic driver version 2.4.2 <6>[ 1.038019] PPP Deflate Compression module registered <6>[ 1.038060] PPP BSD Compression module registered <6>[ 1.199921] PPP MPPE Compression module registered <6>[ 1.199963] NET: Registered protocol family 24 <6>[ 1.200003] tun: Universal TUN/TAP device driver, 1.6 <6>[ 1.200035] tun: (C) 1999-2004 Max Krasnyansky <[email protected]> <4>[ 1.200199] Rockchip WiFi SYS interface (V1.00) ... <6>[ 1.200267] Initializing USB Mass Storage driver... <6>[ 1.200350] usbcore: registered new interface driver usb-storage <6>[ 1.200393] USB Mass Storage support registered. <6>[ 1.200515] usbcore: registered new interface driver usbserial <6>[ 1.200573] USB Serial support registered for generic <6>[ 1.200632] usbcore: registered new interface driver usbserial_generic<6>[ 1.200676] usbserial: USB Serial Driver core <6>[ 1.200724] USB Serial support registered for GSM modem (1-port) <6>[ 1.200791] usbcore: registered new interface driver option <6>[ 1.200830] option: v0.7.2:USB Driver for GSM modems <6>[ 1.200881] USB Serial support registered for usi-modem <6>[ 1.200944] usbcore: registered new interface driver usi-modem <6>[ 1.422929] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode <6>[ 1.422982] usb20_otg usb20_otg: DWC OTG Controller <6>[ 1.423120] usb20_otg usb20_otg: new USB bus registered, assigned bus number 1 <6>[ 1.423200] usb20_otg usb20_otg: irq 48, io mem 0x00000000 <6>[ 1.423265] DWC_OTG: Init: Port Power? op_state=1 <6>[ 1.423300] DWC_OTG: Init: Power Port (0) <6>[ 1.423385] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 <6>[ 1.423437] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 <6>[ 1.423490] usb usb1: Product: DWC OTG Controller <6>[ 1.423526] usb usb1: Manufacturer: Linux 3.0.36+ dwc_otg_hcd <6>[ 1.423567] usb usb1: SerialNumber: usb20_otg <6>[ 1.423884] hub 1-0:1.0: USB hub found <6>[ 1.423921] hub 1-0:1.0: 1 port detected <6>[ 1.426523] DWC_OTG: host20_driver_probe host2.0 reg addr: 0x101c0000 remap:0xdf180000 <6>[ 1.637175] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode <6>[ 1.637223] usb20_host usb20_host: DWC OTG Controller <6>[ 1.637292] usb20_host usb20_host: new USB bus registered, assigned bus number 2 <6>[ 1.637365] usb20_host usb20_host: irq 49, io mem 0x00000000 <6>[ 1.637443] DWC_OTG: Init: Port Power? op_state=1 <6>[ 1.637479] DWC_OTG: Init: Power Port (0) <6>[ 1.637550] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 <6>[ 1.637602] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 <6>[ 1.637655] usb usb2: Product: DWC OTG Controller <6>[ 1.637691] usb usb2: Manufacturer: Linux 3.0.36+ host20_hcd <6>[ 1.637731] usb usb2: SerialNumber: usb20_host <6>[ 1.638021] hub 2-0:1.0: USB hub found <6>[ 1.638056] hub 2-0:1.0: 1 port detected <4>[ 1.638432] DWC_OTG: Mode Mismatch Interrupt: currently in Host mode <6>[ 1.711672] android_usb gadget: Mass Storage Function, version: 2009/09/11 <6>[ 1.711740] android_usb gadget: Number of LUNs=2 <6>[ 1.711794] lun0: LUN: removable file: (no medium) <6>[ 1.711841] lun1: LUN: removable file: (no medium) <6>[ 1.712165] android_usb gadget: android_usb ready <6>[ 1.712433] input: rk29-keypad as /devices/platform/rk29-keypad/input/input0 <6>[ 1.712752] usbcore: registered new interface driver xpad <4>[ 1.713058] remotectl probe j=0x0 <4>[ 1.713095] remotectl probe j=0x1 <4>[ 1.713128] remotectl probe j=0x2 <4>[ 1.713161] remotectl probe j=0x3 <4>[ 1.713193] remotectl probe j=0x4 <4>[ 1.713225] remotectl probe j=0x5 <4>[ 1.713258] remotectl probe j=0x6 <6>[ 1.713437] input: rkxx-remotectl as /devices/platform/rkxx-remotectl/input/input1 <6>[ 1.718220] using rtc device, rtc_hym8563, for alarms <6>[ 1.718298] rtc_hym8563 1-0051: rtc core: registered rtc_hym8563 as rtc0 <6>[ 1.718399] i2c /dev entries driver <6>[ 1.719135] lirc_dev: IR Remote Control driver registered, major 250 <6>[ 1.719197] IR NEC protocol handler initialized <6>[ 1.719239] IR RC5(x) protocol handler initialized <6>[ 1.719283] IR RC6 protocol handler initialized <6>[ 1.719325] IR JVC protocol handler initialized <6>[ 1.719367] IR Sony protocol handler initialized <6>[ 1.719410] IR RC5 (streamzap) protocol handler initialized <6>[ 1.719461] IR LIRC bridge handler initialized <6>[ 1.719501] Linux video capture interface: v2.00 <6>[ 1.719627] usbcore: registered new interface driver uvcvideo <6>[ 1.719679] USB Video Class driver (v1.1.0) <4>[ 1.719767] def_ref_volt: 1800mV, curr_ref_volt: 1800mV <6>[ 1.720681] device-mapper: uevent: version 1.0.3 <6>[ 1.721035] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: [email protected] <6>[ 1.721456] Bluetooth: HCI UART driver ver 2.2 <6>[ 1.721507] Bluetooth: HCI H4 protocol initialized <6>[ 1.721552] Bluetooth: HCILL protocol initialized <6>[ 1.721596] rtk_btusb: Realtek Bluetooth USB driver ver 0.9 <6>[ 1.721724] usbcore: registered new interface driver rtk_btusb <6>[ 1.721833] cpuidle: using governor ladder <6>[ 1.721875] cpuidle: using governor menu <6>[ 1.767504] <6>[ 1.767508] drivers/mmc/core/core.c...2015.. ===== mmc_rescan Begin....[mmc0] <4>[ 1.767579] <4>[ 1.767583] ================= <4>[ 1.767588] sdmmc_rescan..2022.. ====find no SDMMC host. [mmc0] <6>[ 1.767685] .Line4005..The End of SDMMC-probe Ver.6.07 The last modify date is 2013-12-20. [sd_mmc] <6>[ 1.767904] <6>[ 1.767907] drivers/mmc/core/core.c...2015.. ===== mmc_rescan Begin....[mmc1] <6>[ 1.767984] .Line4005..The End of SDMMC-probe Ver.6.07 The last modify date is 2013-12-20. [sdio] <7>[ 1.768162] Registered led device: ledR <7>[ 1.768218] Registered led device: ledW <7>[ 1.768274] Registered led device: it66121 <7>[ 1.768327] Registered led device: cvbs <6>[ 1.769779] usbcore: registered new interface driver usbhid <6>[ 1.769825] usbhid: USB HID core driver <6>[ 1.770194] logger: created 256K log 'log_main' <6>[ 1.770289] logger: created 256K log 'log_events' <6>[ 1.770384] logger: created 256K log 'log_radio' <6>[ 1.770475] logger: created 256K log 'log_system' <6>[ 1.770858] zram: Created 1 device(s) ... <4>[ 1.771443] i2c-core: driver [RK1000_CODEC] using legacy suspend method <4>[ 1.771498] i2c-core: driver [RK1000_CODEC] using legacy resume method<6>[ 1.791869] rk29_sdmmc_change_clk_div..1681.. newDiv=42, newCLK=294Khz [sdio] <4>[ 1.926223] register rk1000 codec earlysuspend ok <3>[ 1.926271] RK1000_CODEC 4-0060: Failed to add route Left DAC->Left Mixer <6>[ 1.932941] asoc: rk1000_codec <-> rk29_i2s.1 mapping ok <6>[ 1.933293] ALSA device list: <6>[ 1.933316] #0: RK29_RK1000 <6>[ 1.933446] GACT probability NOT on <6>[ 1.933484] Mirror/redirect action on <6>[ 1.933513] u32 classifier <6>[ 1.933532] Actions configured <6>[ 1.933560] Netfilter messages via NETLINK v0.30. <6>[ 1.933636] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) <6>[ 1.934021] ctnetlink v0.93: registering with nfnetlink. <6>[ 1.934093] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 <6>[ 1.934146] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. <6>[ 1.934467] xt_time: kernel timezone is -0000 <6>[ 1.934661] ip_tables: (C) 2000-2006 Netfilter Core Team <6>[ 1.934843] arp_tables: (C) 2002 David S. Miller <6>[ 1.934921] TCP cubic registered <6>[ 1.934946] Initializing XFRM netlink socket <6>[ 1.935345] NET: Registered protocol family 10 <6>[ 1.936054] Mobile IPv6 <6>[ 1.936095] ip6_tables: (C) 2000-2006 Netfilter Core Team <6>[ 1.936259] IPv6 over IPv4 tunneling driver <6>[ 1.936902] NET: Registered protocol family 17 <6>[ 1.936959] NET: Registered protocol family 15 <6>[ 1.951151] usb 1-1: new high speed USB device number 2 using usb20_otg <6>[ 2.081170] Bluetooth: RFCOMM TTY layer initialized <6>[ 2.081215] Bluetooth: RFCOMM socket layer initialized <6>[ 2.081253] Bluetooth: RFCOMM ver 1.11 <6>[ 2.081283] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 <6>[ 2.081327] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 <6>[ 2.081580] NET: Registered protocol family 35 <6>[ 2.081720] [BT_RFKILL]: Enter rfkill_rk_init <6>[ 2.081940] [BT_RFKILL]: Request irq for bt wakeup host <6>[ 2.081992] [BT_RFKILL]: ** disable irq <6>[ 2.111067] [BT_RFKILL]: bt shut off power <6>[ 2.141125] [BT_RFKILL]: bt_default device registered. <5>[ 2.141210] Registering the dns_resolver key type <4>[ 2.141266] pmic set pm_suspend_volt: <6>[ 2.141304] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 <5>[ 2.141372] Registering SWP/SWPB emulation handler <4>[ 2.141550] usb detect inited by board_usb_detect_init, disable detect by bvalid irq <6>[ 2.141907] ddrfreq: verion 3.2 20131126 <6>[ 2.141939] ddrfreq: fix cpu pause bug <6>[ 2.141968] ddrfreq: normal 720MHz video 0MHz video_low 0MHz dualview 0MHz idle 0MHz suspend 0MHz reboot 220MHz <6>[ 2.142799] ddrfreq: change freq to 720 MHz when normal <4>[ 2.143110] <4>[ 2.143118] ======================================================= <4>[ 2.143141] ==== Launching Wi-Fi driver! (Powered by Rockchip) ==== <4>[ 2.143163] ======================================================= <4>[ 2.143185] Realtek 8723AU USB WiFi driver (Powered by Rockchip,Ver 2.20.WFD) init. <4>[ 2.143214] wifi_deactivate_usb <6>[ 2.143227] rk29sdk_wifi_power: 0 <6>[ 2.184089] usb 1-1: New USB device found, idVendor=0ac8, idProduct=3420 <6>[ 2.184122] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 <6>[ 2.184151] usb 1-1: Product: A4TECH USB2.0 PC Camera <6>[ 2.184172] usb 1-1: Manufacturer: A4TECH Corp. <6>[ 2.185191] uvcvideo: Found UVC 1.00 device A4TECH USB2.0 PC Camera (0ac8:3420) <6>[ 2.186965] input: A4TECH USB2.0 PC Camera as /devices/platform/usb20_otg/usb1/1-1/1-1:1.0/input/input2 <6>[ 2.345754] wifi shut off power <6>[ 2.371136] usb 2-1: new high speed USB device number 2 using usb20_host <4>[ 2.581184] wifi_activate_usb <6>[ 2.581244] rk29sdk_wifi_power: 1 <6>[ 2.582767] usb 2-1: New USB device found, idVendor=05e3, idProduct=0608 <6>[ 2.582882] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 <6>[ 2.582967] usb 2-1: Product: USB2.0 Hub <6>[ 2.584114] hub 2-1:1.0: USB hub found <6>[ 2.584494] hub 2-1:1.0: 4 ports detected <6>[ 2.837355] wifi turn on power <6>[ 2.861287] usb 2-1.1: new high speed USB device number 3 using usb20_host <4>[ 2.941295] rtl8723as-vau driver version=v4.1.8_9660.20131126_BTCOEX20130528_ver3.3 <6>[ 2.941903] usbcore: registered new interface driver rtl8723au <6>[ 2.942627] rtc_hym8563 1-0051: setting system clock to 2016-01-06 15:47:19 UTC (1452095239) <6>[ 2.947179] asoc: dit-hifi <-> rk-spdif mapping ok <6>[ 2.952604] usbcore: registered new interface driver snd-usb-audio <6>[ 2.953803] Freeing init memory: 2204K <6>[ 2.972710] usb 2-1.1: New USB device found, idVendor=148f, idProduct=7601 <6>[ 2.972760] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 <6>[ 2.972805] usb 2-1.1: Product: 802.11 n WLAN <6>[ 2.972837] usb 2-1.1: Manufacturer: MediaTek <6>[ 2.972865] usb 2-1.1: SerialNumber: 1.0 <6>[ 3.051439] usb 2-1.2: new high speed USB device number 4 using usb20_host <6>[ 3.151750] usb 2-1.2: New USB device found, idVendor=1a40, idProduct=0101 <6>[ 3.151786] usb 2-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0 <6>[ 3.151826] usb 2-1.2: Product: USB 2.0 Hub <6>[ 3.152189] hub 2-1.2:1.0: USB hub found <6>[ 3.152371] hub 2-1.2:1.0: 4 ports detected <4>[ 3.431978] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead. <6>[ 3.451247] usb 2-1.2.1: new full speed USB device number 5 using usb20_host <6>[ 3.575142] usb 2-1.2.1: New USB device found, idVendor=046d, idProduct=c52f <6>[ 3.575175] usb 2-1.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 <6>[ 3.575213] usb 2-1.2.1: Product: USB Receiver <6>[ 3.575230] usb 2-1.2.1: Manufacturer: Logitech <6>[ 3.578608] input: Logitech USB Receiver as /devices/platform/usb20_host/usb2/2-1/2-1.2/2-1.2.1/2-1.2.1:1.0/input/input3 <6>[ 3.578784] generic-usb 0003:046D:C52F.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-usb20_host-1.2.1/input0 <6>[ 3.582285] input: Logitech USB Receiver as /devices/platform/usb20_host/usb2/2-1/2-1.2/2-1.2.1/2-1.2.1:1.1/input/input4 <6>[ 3.582478] generic-usb 0003:046D:C52F.0002: input,hidraw1: USB HID v1.11 Device [Logitech USB Receiver] on usb-usb20_host-1.2.1/input1 <6>[ 3.661115] usb 2-1.2.3: new high speed USB device number 6 using usb20_host <6>[ 3.761870] usb 2-1.2.3: New USB device found, idVendor=1908, idProduct=1320 <6>[ 3.761899] usb 2-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 <6>[ 3.761934] usb 2-1.2.3: Product: Mass storage <6>[ 3.761952] usb 2-1.2.3: Manufacturer: Generic <6>[ 3.761972] usb 2-1.2.3: SerialNumber: SN0088896809 <6>[ 3.762399] scsi0 : usb-storage 2-1.2.3:1.0 <3>[ 3.851275] init: /dev/hw_random not found <6>[ 3.851338] keychord: using input dev rk29-keypad for fevent <6>[ 3.851363] keychord: using input dev rkxx-remotectl for fevent <6>[ 3.851405] keychord: using input dev Logitech USB Receiver for fevent<4>[ 4.234919] gp_rknand_info = : 0xdd8cc800 <4>[ 4.234988] rk30_chip_set:1 <4>[ 4.235078] FtlInit! <4>[ 4.235102] No.1 FLASH ID:98 de 84 93 72 57 <4>[ 4.237943] FTL version: 5.0.12 20140214 <4>[ 4.438178] gBootMedia = 1 gSdmmcFwPartOffset =0! <4>[ 4.438200] rknand_buffer.c version: 4.40 20130830! <5>[ 4.438336] 10 cmdlinepart partitions found on MTD device rk29xxnand <5>[ 4.438362] Creating 10 MTD partitions on "rk29xxnand": <5>[ 4.438384] 0x000000400000-0x000000800000 : "misc" <5>[ 4.439158] 0x000000800000-0x000001400000 : "kernel" <5>[ 4.439793] 0x000001400000-0x000002000000 : "boot" <5>[ 4.440394] 0x000002000000-0x000004000000 : "recovery" <5>[ 4.440989] 0x000004000000-0x000008000000 : "backup" <5>[ 4.441645] 0x000008000000-0x000010000000 : "cache" <5>[ 4.442321] 0x000010000000-0x000010400000 : "metadata" <5>[ 4.442932] 0x000010400000-0x000010800000 : "kpanic" <6>[ 4.444813] apanic: Bound to mtd partition 'kpanic' <6>[ 4.444836] apanic: No panic data available <5>[ 4.444858] 0x000010800000-0x000040800000 : "system" <5>[ 4.445824] 0x000040800000-0x0001e1000000 : "userdata" <3>[ 4.520478] fs_mgr: parse_link_device : path = NULL <3>[ 4.525226] fs_mgr: parse_link_device : path = NULL <3>[ 4.530131] fs_mgr: parse_link_device : path = NULL <3>[ 4.535049] fs_mgr: parse_link_device : path = NULL <3>[ 4.539955] fs_mgr: parse_link_device : path = NULL <3>[ 4.544857] fs_mgr: parse_link_device : path = NULL <3>[ 4.549761] fs_mgr: parse_link_device : path = NULL <3>[ 4.554666] fs_mgr: parse_link_device : path = NULL <6>[ 4.559583] fs_mgr: ---------------resize_fs blk_dev /dev/block/mtd/by-name/system, type ext4 <6>[ 4.568129] fs_mgr: Running /sbin/resize2fs on /dev/block/mtd/by-name/system <6>[ 4.576177] resize2fs: resize2fs 1.41.14 (22-Dec-2010) <6>[ 4.581104] resize2fs: The filesystem is already 196608 blocks long. Nothing to do! <6>[ 4.581143] resize2fs: <6>[ 4.590247] EXT4-fs (mtdblock8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard <7>[ 4.608637] EXT4-fs (mtdblock5): ext4_orphan_cleanup: deleting unreferenced inode 57 <7>[ 4.608699] EXT4-fs (mtdblock5): ext4_orphan_cleanup: deleting unreferenced inode 51 <7>[ 4.608736] EXT4-fs (mtdblock5): ext4_orphan_cleanup: deleting unreferenced inode 50 <7>[ 4.608769] EXT4-fs (mtdblock5): ext4_orphan_cleanup: deleting unreferenced inode 47 <7>[ 4.608802] EXT4-fs (mtdblock5): ext4_orphan_cleanup: deleting unreferenced inode 44 <7>[ 4.608842] EXT4-fs (mtdblock5): ext4_orphan_cleanup: deleting unreferenced inode 40 <7>[ 4.608994] EXT4-fs (mtdblock5): ext4_orphan_cleanup: deleting unreferenced inode 31 <7>[ 4.609030] EXT4-fs (mtdblock5): ext4_orphan_cleanup: deleting unreferenced inode 13 <6>[ 4.609085] EXT4-fs (mtdblock5): 8 orphan inodes deleted <6>[ 4.609107] EXT4-fs (mtdblock5): recovery complete <6>[ 4.611610] EXT4-fs (mtdblock5): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard <4>[ 4.614619] EXT4-fs (mtdblock6): warning: mounting unchecked fs, running e2fsck is recommended <6>[ 4.614792] EXT4-fs (mtdblock6): mounted filesystem without journal. Opts: noauto_da_alloc,discard <7>[ 4.673065] EXT4-fs (mtdblock9): ext4_orphan_cleanup: deleting unreferenced inode 16122 <7>[ 4.673147] EXT4-fs (mtdblock9): ext4_orphan_cleanup: deleting unreferenced inode 16120 <7>[ 4.674769] EXT4-fs (mtdblock9): ext4_orphan_cleanup: deleting unreferenced inode 16118 <7>[ 4.674825] EXT4-fs (mtdblock9): ext4_orphan_cleanup: deleting unreferenced inode 16116 <7>[ 4.674874] EXT4-fs (mtdblock9): ext4_orphan_cleanup: deleting unreferenced inode 16108 <7>[ 4.674923] EXT4-fs (mtdblock9): ext4_orphan_cleanup: deleting unreferenced inode 16111 <7>[ 4.674954] EXT4-fs (mtdblock9): ext4_orphan_cleanup: deleting unreferenced inode 16110 <7>[ 4.675000] EXT4-fs (mtdblock9): ext4_orphan_cleanup: deleting unreferenced inode 16109 <6>[ 4.675133] EXT4-fs (mtdblock9): 8 orphan inodes deleted <6>[ 4.680464] EXT4-fs (mtdblock9): recovery complete <6>[ 4.701007] EXT4-fs (mtdblock9): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard <4>[ 4.721308] UMP: Using OS memory backend, allocation limit: 1073741824<4>[ 4.721357] UMP: UMP device driver -0d88e3e loaded <4>[ 4.757733] Mali: Mali400 inside of rk3188! <4>[ 4.757765] Mali: mali freq table num : 6 <4>[ 4.757783] Mali: mali freq table :Mali: 128,Mali: 198,Mali: 223,Mali: 297,Mali: 297,Mali: 594,Mali: <4>[ 4.757841] Mali: init mali clock success <4>[ 4.758848] Mali: Mali device driver loaded <5>[ 4.762177] scsi 0:0:0:0: Direct-Access Generic Flash Disk 1.68 PQ: 0 ANSI: 2 <4>[ 4.762984] rk30_mirroring: Unknown symbol video_data_to_mirroring (err 0) <4>[ 4.763036] rk30_mirroring: Unknown symbol audio_data_to_mirroring (err 0) <5>[ 4.764004] sd 0:0:0:0: [sda] 131072000 512-byte logical blocks: (67.1 GB/62.5 GiB) <4>[ 4.765031] rk29_ipp: module is from the staging directory, the quality is unknown, you have been warned. <4>[ 4.765809] ipp irq 47 <5>[ 4.766017] sd 0:0:0:0: [sda] Write Protect is off <7>[ 4.766039] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00 <4>[ 4.766359] IPP init, version rk30-ipp 1.003 <3>[ 4.766753] sd 0:0:0:0: [sda] No Caching mode page present <3>[ 4.766775] sd 0:0:0:0: [sda] Assuming drive cache: write through <3>[ 4.769740] sd 0:0:0:0: [sda] No Caching mode page present <3>[ 4.769766] sd 0:0:0:0: [sda] Assuming drive cache: write through <6>[ 4.770512] sda: sda1 <3>[ 4.773619] sd 0:0:0:0: [sda] No Caching mode page present <3>[ 4.773643] sd 0:0:0:0: [sda] Assuming drive cache: write through <5>[ 4.773667] sd 0:0:0:0: [sda] Attached SCSI removable disk <3>[ 4.906014] init: /dev/hw_random not found <6>[ 4.918822] binder: 98:98 transaction failed 29189, size 0-0 <3>[ 4.927858] init: cannot find '/system/vendor/bin/pvrsrvctl', disabling 'pvrsrvctl' <3>[ 4.934440] init: cannot find '/system/bin/rild3', disabling 'ril-daemon3' <3>[ 5.014550] init: cannot find '/system/bin/bplus_helper', disabling 'bplus_helper' <3>[ 5.015375] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}' <3>[ 5.015409] init: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial' <3>[ 5.015612] init: using deprecated syntax for specifying property 'ro.product.usbfactory', use ${name} instead <3>[ 5.091273] init: property 'sys.powerctl' doesn't exist while expanding '${sys.powerctl}' <3>[ 5.091314] init: powerctl: cannot expand '${sys.powerctl}' <3>[ 5.091352] init: property 'sys.sysctl.extra_free_kbytes' doesn't exist while expanding '${sys.sysctl.extra_free_kbytes}' <3>[ 5.091393] init: cannot expand '${sys.sysctl.extra_free_kbytes}' while writing to '/proc/sys/vm/extra_free_kbytes' <3>[ 5.091670] android_usb: already disabled <6>[ 5.091848] mtp_bind_config <6>[ 5.133841] adb_open <6>[ 5.226779] warning: `su' uses 32-bit capabilities (legacy support in use) <3>[ 5.284962] init: untracked pid 130 exited <3>[ 5.285015] init: untracked pid 131 exited <3>[ 5.287705] init: untracked pid 134 exited <3>[ 5.298780] init: untracked pid 135 exited <6>[ 5.338116] EXT4-fs (mtdblock8): re-mounted. Opts: (null) <6>[ 5.338469] EXT4-fs (mtdblock8): re-mounted. Opts: (null) <6>[ 5.339676] EXT4-fs (mtdblock8): re-mounted. Opts: (null) <4>[ 5.356713] RKNAND_GET_DRM_KEY <4>[ 5.356738] return ret = 0 <3>[ 5.647924] fs_mgr: parse_link_device : path = NULL <3>[ 5.647990] fs_mgr: parse_link_device : path = NULL <3>[ 5.648035] fs_mgr: parse_link_device : path = NULL <3>[ 5.648087] fs_mgr: parse_link_device : path = NULL <3>[ 5.648128] fs_mgr: parse_link_device : path = NULL <3>[ 5.648164] fs_mgr: parse_link_device : path = NULL <3>[ 5.648207] fs_mgr: parse_link_device : path = NULL <3>[ 5.648259] fs_mgr: parse_link_device : path = NULL <6>[ 5.648470] .204.. MMC0 receive the message sd-No-Media from VOLD.[sd_mmc] <6>[ 5.648514] .235.. MMC0 receive the message No-Media from VOLD. waitTimes=0 [sd_mmc] <6>[ 5.702243] EXT4-fs (mtdblock8): re-mounted. Opts: (null) <6>[ 5.708209] EXT4-fs (mtdblock8): re-mounted. Opts: (null) <6>[ 5.708541] EXT4-fs (mtdblock8): re-mounted. Opts: (null) <4>[ 5.897521] rk fb use 3 buffers <6>[ 6.124971] EXT4-fs (mtdblock8): re-mounted. Opts: (null) <6>[ 6.131787] EXT4-fs (mtdblock8): re-mounted. Opts: (null) <6>[ 6.138470] EXT4-fs (mtdblock8): re-mounted. Opts: (null) <3>[ 6.144112] init: untracked pid 140 exited <3>[ 6.281523] init: untracked pid 279 exited <3>[ 6.361329] init: untracked pid 138 exited <3>[ 7.319043] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_hal.ver <3>[ 7.319227] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_driver.ver <4>[ 8.396854] vpu: power on <4>[ 16.451080] vpu: power off...done <6>[ 40.614091] request_suspend_state: wakeup (3->0) at 40553033132 (2016-01-06 15:47:57.162560630 UTC) <4>[ 40.971132] enter func vmac_open... <4>[ 40.971256] power on phy <4>[ 41.111096] Read the Ethernet MAC address from IDB:00:00:00:00:00:00 <4>[ 41.111139] eth_mac_from_RANDOM***********:E:67:9B:EC:8D:0 <6>[ 41.127635] vmac_mii_bus: probed <6>[ 41.128312] rk29 vmac rk29 vmac.0: PHY driver [Generic PHY] (mii_bus:phy_addr=0:00, irq=-1) <6>[ 41.128745] ADDRCONF(NETDEV_UP): eth0: link is not ready <4>[ 41.570761] enter func vmac_close... <6>[ 41.725184] acc_open <6>[ 41.727401] acc_release <4>[ 41.769114] enter func vmac_open... <4>[ 41.771221] power on phy <4>[ 41.911086] Read the Ethernet MAC address from IDB:00:00:00:00:00:00 <4>[ 41.911131] eth_mac_from_RANDOM***********:E:67:9B:EC:8D:0 <6>[ 41.931094] vmac_mii_bus: probed <6>[ 41.931740] rk29 vmac rk29 vmac.0: PHY driver [Generic PHY] (mii_bus:phy_addr=0:00, irq=-1) <6>[ 41.931946] ADDRCONF(NETDEV_UP): eth0: link is not ready <4>[ 43.839247] vpu: power on <3>[ 43.888035] init: sys_prop: permission denied uid:1001 name:media.cfg.audio.soundeffect <6>[ 43.931709] PHY: 0:00 - Link is Down <3>[ 45.141768] init: sys_prop: permission denied uid:1003 name:service.bootanim.exit <6>[ 45.933807] PHY: 0:00 - Link is Up - 100/Full <6>[ 45.934132] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready <4>[ 47.841138] vpu: power off...done <6>[ 53.721730] EXT4-fs (mtdblock8): re-mounted. Opts: (null) <6>[ 53.736552] EXT4-fs (mtdblock8): re-mounted. Opts: (null) <6>[ 53.748799] EXT4-fs (mtdblock8): re-mounted. Opts: (null) <6>[ 53.761027] EXT4-fs (mtdblock8): re-mounted. Opts: (null) <6>[ 53.774783] EXT4-fs (mtdblock8): re-mounted. Opts: (null) <6>[ 53.788541] EXT4-fs (mtdblock8): re-mounted. Opts: (null) <6>[ 53.877495] EXT4-fs (mtdblock8): re-mounted. Opts: (null) <6>[ 53.898793] EXT4-fs (mtdblock8): re-mounted. Opts: (null) <6>[ 53.909379] EXT4-fs (mtdblock8): re-mounted. Opts: (null) <6>[ 53.920285] EXT4-fs (mtdblock8): re-mounted. Opts: (null) <6>[ 53.931236] EXT4-fs (mtdblock8): re-mounted. Opts: (null) <6>[ 53.942124] EXT4-fs (mtdblock8): re-mounted. Opts: (null) <7>[ 56.041093] eth0: no IPv6 routers present <3>[ 74.577018] init: sys_prop: permission denied uid:10079 name:sys.glibgui <3>[ 86.228560] init: untracked pid 2355 exited <3>[ 86.461728] init: untracked pid 2358 exited <6>[ 516.046054] binder: 661:661 transaction failed 29189, size 92-0 <4>[ 530.974757] vpu: power on <4>[ 534.981133] vpu: power off...done <4>[ 546.388942] vpu: power on <4>[ 550.391149] vpu: power off...done root@manta:/ #
You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoLast edited by MAT03ru; 01-07-2016, 03:26.
I do not hope that the answer dear Wasser, our requests from the forum 4pda. I leave at least a link to my post in the forum 4pda - Firmware, TV Box on a chip Rockchip RK3188
Dear wasser.
This rom is the best. My TV box is TN09 ver 2.1 1335. The version 1.0.4 works great without error. Antutu 5.7.1 score in 1080p x 60hz is around 21000. After some tweak, it boosts to 25000. Youtube 11.16.xx works great. Most games including Asphalt 8, GT racing, Modern Combat 4, etc. run well without getting hot. Dead Trigger, Shadow Gun are very smooth. Thank you so much.
However some games like Nova 3, MC 5, Unkilled are playable but rather laggy. As the box doesn't get hot while playing those heavy games, I believe it can run at higher Cpu gpu ram frequencies. So could you please please please make OC Kernel for the Rom 1.0.4 (As you once did to your 4.2.2 Rom).
From bottom of my heart, thank you so much.Last edited by bopbun123; 05-01-2016, 09:15.
There are currently 2406 users online. 6 members and 2400 guests.
