NEW - Minix X5 - Finless 1.3 custom ROM
    Originally posted by seth29 View Post
    What cpu settings ur using petrus with this kernel
    Sent from my iPad using Tapatalk
    E/S Buffer read head : 1024
    Governor : interactive
    Min freq : 1008000
    Max Freq : 160800
    But I think I'll lower Minimum frequency and see if there is any differences.
    I tried to put it at this value to see if it prevents freezes. In fact It only froze once, when I paused a video for too long.
    Maybe it overheated, so lowering the min freq to 816000 or 504000 would be better.
    Edit : if you use Trickster Mod and are satisfied with the results, don't forget to tick "kernel settings" in the "apply on startup" menu, or you'll lose your settings on next rebboot.
      Originally posted by petrus View Post
      Sorry, we have to re-upload some amount of roms.
      It seems that [DELETED]'s only contribution to this site lately was to delete other dev files from the FTP.
      Sorry for the inconvenience. It's sad that some people only think about themselves.
      Can you say when download for the ROM Version 1.3 is fixed?
      I want to install it an a brand new Neo X5.
      At this time i have only the original ROM installed.
        I don't have trickster install only using nofrill cpu, for frequency settings
        Sent from my GT-I9300 using Tapatalk
          Re: NEW - Minix X5 - Finless 1.3 custom ROM
          Originally posted by philfrommancs View Post
          Not getting it here. .. I was finding the random volume increase really annoying on previous rom. Not had it once on bob's new release. So far everything has been flawless.
          sent by my rocket fuelled neatmonster... a Sasa masterpiece !!!
          Looks like I spoke to soon. ...
          Been getting the random volume display popping up on screen for the last two days. ..
            ya i wondered if only some units had this issue... like how some (mine before rma) are plagued with the reboots, but maybe that makes no sense for this bug. I just think it's weird how random it is, mine can definitely go days without doing it at all. I may go back to 013 and see if I can live without 1080 and 4.2.2. ok, time to stop before I get too off topic here.
            Sent from my NEO-X5-116A using CrappaLinks
              Can someone plz re-upload the rom?
                We are working on it. But be patient, we have a lot to re-upload.
                But it should be back online very soon.
                  The link is now available.
                    Wicked thanks.
                      Originally posted by george909 View Post
                      Mine didn't reboot when I was on finless 1.2b only reboots on 1.3
                      I have the same issue. I've had very stable work at 1.2b. But at 1.3, i've tried 720noair, 1080noair and some OC-kernels, nothing helps - my minix freezes after few hours. Moreover working temperature was higher at 1.2b, may be because it worked for weeks without reboots, at 1.3 minix is cold but frozen.
                        are you guys able to get last_kmsg? seemed to work for me on 4.1.1 based fw, but 4.2.2 just gives a bunch of strange characters. I would think that's your best bet to narrowing it down but I remember scratching my head trying to get anything useful out of it. Anyone know what the deal is with that?
                          deleted - tapatalk issue on my end
                            Google play - Error 403
                            Hello,
                            So I finally got around to installing this rom but for some reason I cannot download anything from the play store. I go through the association processes but then I just get Could not download "blah" error 403. This happens with both paid for and free apps. I tried all the usual fixes, deleting and re-creating the account, clearing all the caches. I even changed back to the old build.prop file but still the same thing. I also re-flashed the device making darn sure I did a nand but that also didn't help.
                            Does anyone know what else I can try?
                              Try setting correct time date as well :-)
                                Bugger, I should have remembered that one.
