Release is not ready?When?
Minix Neo X7 Quickshot v2 Rom by The Nitro Team
Originally posted by dwane3 View PostRelease is not ready?When?There are 10 types of people in the world: Those who understand binary, and those who don't...
If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
Quickshot v2 and XBMC Gotham
For people who have XBMC Gotham... Did you do anything special to get this working smoothly? My video seems choppy... definitely choppy w/ 1080p and sometimes even w/ 720p. are you using one of the overclocked kernels (if so which?) or just the regular Quickshot v2 ROM? Any settings in xbmc itself i might need to tweak?
also, this is probably a dumb question but i am pretty new to all of this... My tv is just a small 23 inch tv. so really, i wont be able to tell the difference between 720p and 1080p on it. would i get a benefit in video playback and performance if i used the 720p ROM instead of the 1080p? also, if i used the 720p rom, what happens if i play a 1080p movie?
I use 720p kernel from oc kernel pack. Kernel with ram oc only - @720. All 720p video files with dts or ac3 with passthrough on xbmc 13rc1 gotham working just fine on my 37x10y Panasonic hd ready plazma tv. Full hd - 1080p movies works fine and looks the same as 720p. I have a problem with one movie -*Monsters, Inc . 1080p. DTS audiotrack. Movie is lagy after half minute . The same movie play fine on beyound xbmc - frodo build and on mx player or rk stock player. I dont know why gotham have problem with that video file. When i off passthrough in Gotham xbmc animation on movie is like shoud be.
All other my movies play smoothly in gotham and have less buffer on start. I'm waiting for final build of xbmc. Btw i use confluence customizable mod so it looks almost like beyound.
Other issue is that in Gotham xbmc i can only write some texts only using mouse. Like when i search something on youtube addon etc. Minix remote is no full suported in rc1 xbmc for texting, all other tjongs can be done in xbmc by stock remote. O use stock remote for navigation and mouse only for write text on virtual keyboard.
Originally posted by thisisvlad View PostFor people who have XBMC Gotham... Did you do anything special to get this working smoothly? My video seems choppy... definitely choppy w/ 1080p and sometimes even w/ 720p. are you using one of the overclocked kernels (if so which?) or just the regular Quickshot v2 ROM? Any settings in xbmc itself i might need to tweak?
I haven't used any of the Gotham beta or RC releases of XBMC... I use Beyond XBMC v3.4 which is still based on a Frodo build. Everything is usually smooth as silk with the exception just after startup when add-ons etc are getting updated it sometimes is a bit choppy, but that is to be expected I think.
When you mention video... you didn't mention what source you are using.... Internet and network sources can be choppy and nothing at all is wrong with the XBMC build you are using... lags on certain network setups and anytime streaming from online sources are not how you judge it .... Always use a local source for this type of testing... anything else adds too many other possible causes of a lag or choppy video.
There are a few things to look at if you are using WiFi and are on a network or streaming from the internet... but since this wasn't mentioned I won't go into it again unless this info is mentioned.... or just read back through the thread, I'm sure I've "harped" about it before
Originally posted by rdsok View PostI'm running a slightly OC'd kernel... the CPU 1608h and DDR at 720 ...
There are a few things to look at if you are using WiFi and are on a network or streaming from the internet... but since this wasn't mentioned I won't go into it again unless this info is mentioned.... or just read back through the thread, I'm sure I've "harped" about it before... no buffering, but still somewhat choppy.
i'll try using the kernel you recommended... this was from the 720p pack? the one named "kernel_cpu1608h_gpustock_ddr720.img_quickflasher. zip"?
also, did you need to change any settings in xbmc itself? any of the video settings or anything? i saw some instructions about updating advancedsettings.xml here (http://minixforums.com/threads/how-t...minix-x7.2360/). should i do this?
Originally posted by thisisvlad View Postat first i used a SMB share over WiFi which was pretty bad with lots of buffering.. now i am doing FTP over Ethernet, so much better... no buffering, but still somewhat choppy.
I use 1080p kernels only.... all from the original kernel pack. I really doubt that your issue is going to be kernel caused one... I do feel it's an important step to find which kernel works best on your system... but video choppiness, stuttering etc isn't going to tell you that... just general performance will. Most users seem to go with the fastest OC they can that their system doesn't lock up or act strangely... I'm a tech and do it differently... I only go as fast as I need to see the system operate quickly and smoothly. The more you OC the more strain you place on the CPU/GPU which shortens it's lifespan. So I OC judiciously instead of going for all I can get.
Beyond XBMC already has most if not all of the different tweaks for it.... so I haven't needed to mess with my advancedsettings.xml... and I'm not running a Gotham build on my Neo x7 either.... so I would see different things ( ie issues or problems ) than you in that area. So others in the XBMC forum area will be better suited to answering your questions that I am.
So... my recommendations.
Take the worst playing video you have... move it to your device to use for testing. This eliminates other possible causes and tests just your device and the XBMC you are running only. If they are playing smoothly on your device... you know you need to look into networking things and can quit worring about the device and/or software.
I'd probably start with selecting your kernel before doing the above... ie only OC as much as needed for the device to work smoothly without causing odd issues or lockups.
I wouldn't be surprised that the advancedsettings.xml could use a few tweaks... I'm just not the one to ask which ones. I'm also relatively new to XMBC...
Originally posted by rdsok View PostYou may have network issues.... as I said... only take local media, not network connected media as a valid test source... Once you know your vid's play smoothly locally, then ( if it's needed and things are still choppy ) go into seeing what you can do to address any possible network issues you may have.
Thanks for the tips! i will try this. So, i didnt realize that youb are using the 1080p kernel. is there any advantage/disadvantage to me using the 720p kernels?
I use "justXBMC" app and only issue i have is sometimes it make a short freeze for few seconds, but thats FW related as ive read. using 1080p kernel.
Is "Gotham" any better then the modded working older versions?Android devices: Minix X7 (gone) , Minix X8-H , MK808b Plus
Video Out: Benq W1000+ 1080p Projector
Audio Out: HDMI -> Yamaha RX-V467B + 5.1 Yamaha Speakers
Remote: Rikomagic MK702 II, Minix NEO M1
Storage: NAS Zyxel NSA325v2
Originally posted by thisisvlad View PostThanks for the tips! i will try this. So, i didnt realize that youb are using the 1080p kernel. is there any advantage/disadvantage to me using the 720p kernels?
Originally posted by killeriq View PostDo u use some SMB share from Android to PC, or only SMB from PC to Android? I wonder which apps works good for you , i havent been able to find a good working one. Either it doesnt show anything, or is asking for password in windows ...
Is anyone else having problems with the official Minix A2 remote?
Is the actual hardware of the remote so unstable or is it caused by software or maybe even by this ROM?
Almost every day when I watch a movie and when it's time to hit the pause - It just doesn't respond. Only way to get it back to life is to unplug the usb-dongle, remove batteries, re-attach them and then it works for a while. Sometimes the Gyro movement gets laggy, it doesn't register every push etc. Really annoying.
Also this remote seems like a battery hog - 2*AAA batteries every month and a half. Normal behaviour?
I'm close to throwing this piece of garbage to the trash already and buy a real mouse and keyboard. Does anyone have idea if this works with Minix with all the swipe thingies (zoom etc) included?
Logitech Wireless All-in-One Keyboard TK820
There are currently 1652 users online. 1 members and 1651 guests.
