Minix Neo X7 Quickshot v2 Rom by The Nitro Team
Originally posted by Piratis View Posthi after custom any kernels of quickshot v2 oc at the end of installation when finishesis not booting at minx neo x7 pls help
ThanksThere are 10 types of people in the world: Those who understand binary, and those who don't...
If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
Originally posted by jacknjill10101 View PostFirst off, great rom, everything is smooth and stable even beyond xbmc. Question is where is the brightness setting? Videos are dark, I've looked in screen settings and xbmc video output but no brightness.
Re: Minix Neo X7 Quickshot v2 Rom by The Nitro Team
Originally posted by jacknjill10101 View PostFirst off, great rom, everything is smooth and stable even beyond xbmc. Question is where is the brightness setting? Videos are dark, I've looked in screen settings and xbmc video output but no brightness.There are 10 types of people in the world: Those who understand binary, and those who don't...
Originally posted by rdsok View PostThat would be a TV/Monitor setting... not a device setting... for example a VCR, DVD or BluRay player also don't have brightness settings just as the Android Media PC's don't.
It is the only box I have that does this tho but it is the only box I have with that chipset.
I will take screenys next time it is on.To Infinity and Beyond.... XBMC
Originally posted by daemonium View Postwhat rdsok said is correct (as usually) , in addition i will say some people have tried a free app from playstore called "screen adjuster", give it a try.
Originally posted by rdsok View PostI knew my Android smartphones have/had a brightness... but none of the 4 Android Media PC's I've had did... but it doesn't surprise me that some could have it
Hey guys,
We've started a Youtube channel, check it out at https://www.youtube.com/user/thenitroteamtnt
We have a couple of videotutorials for now but there's more coming. Also one of them has english voice over. Working on english subs for the second one.There are 10 types of people in the world: Those who understand binary, and those who don't...
Originally posted by briant97 View PostAfter flashing small icons package everything is a bit to small to read across the room on my 50" Sony. What can I do because I want to run the 720 ddr kernel for improved performance.
last issue I have is wireless signal is not strong as it could be but all my other devices work fine. I have note 3 and note 10.1 and an ipad7 signal is about 2 bars in bedroom. The minix will connect but it takes time. some times have to reboot a few times or keep turning wifi on and off. it has the best antenna out of bunch but still fails to work as good. Sometimes just waiting a good 5 minites it kicks in
Originally posted by briant97 View Postlast issue I have is wireless signal is not strong as it could be but all my other devices work fine. I have note 3 and note 10.1 and an ipad7 signal is about 2 bars in bedroom. The minix will connect but it takes time. some times have to reboot a few times or keep turning wifi on and off. it has the best antenna out of bunch but still fails to work as good. Sometimes just waiting a good 5 minites it kicks in
You also need to find out what your x7 is getting for a download speed on your internet...
download/install Speedtest.net from the Play Store here******https://play.google.com/store/apps/d...dtest&hl=enI'd
I'd also suggest WiFi Analyzer******https://play.google.com/store/apps/d...er&hl=en******... this will let you see what WiFi channels are in use where you are as well as the amount of signal you are getting from the one you are connected to. Then you can move your wifi router to a clearer channel if needed and make certian you are getting as strong of a signal as you can.******
I greatly improved my wifi speed and signal strength by swapping channels.Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
There are currently 1852 users online. 0 members and 1852 guests.
