Minix Neo X7 Quickshot v2 Rom by The Nitro Team
Re: Minix Neo X7 Quickshot v2 Rom by The Nitro Team
Originally posted by vab.android View PostThere are 10 types of people in the world: Those who understand binary, and those who don't...
If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
Originally posted by SUNUN View Postsometimes Dolphin or Chrome automatically closing and i see my home screen why?
Originally posted by failax View PostI'm on stock rom, it is possible to flash zip file from recovery or I must use pc version (i'm not able at the moment to make work drivers pressing reset/power buttons, device is not recognized)?There are 10 types of people in the world: Those who understand binary, and those who don't...
Originally posted by rdsok View PostThis is a Quickshot v2 thread... not a general everything else help/support thread... you need to post that type of question in a forum that provides support for those programs.There are 10 types of people in the world: Those who understand binary, and those who don't...
Originally posted by failax View PostI'm one of those with windows 8.1 and drivers problems..I've tried all the methods I've found on forums.Have you a workaround to solve this problem?
ThanksThere are 10 types of people in the world: Those who understand binary, and those who don't...
Help please with Tinicore Quickflasher and 720 Kernel Pack: don't install...
After reinstalling again Quickshot V2 I always presents the same problem: I CAN NOT INSTALL kernel 720, because Tinicore Quickflasher I propose mandatory ONLY three files: other remotes, and small_icons big_icons / quickflasher.zip.
No other files can be selected! I may not scroll the directory
What can I do?
As an alternative to Quickflasher there is another program that I can use to flash the 720 kernel?
Or I have to mandatorily buy Quickflasher?
Originally posted by Thunderboltsteve View PostCan you not just flash a couple at a time then swap files to be flashed and do a couple more?
I can only point those three files. (other remotes, and small_icons big_icons / quickflasher.zip). ALWAYS. Even after a reboot of Quickflasher or Android ... I can not select other files ...
This is problem...
Originally posted by kRel View PostExcuse me... This is exactly what I want to know ....
This is problem...
Originally posted by Thunderboltsteve View PostI dunno pal, i always just use es file explorer to move zips into the quickflasher folder and remove the ones i'm not flashing. Always works for me
I deleted the three files and copied the kernel 720, but unfortunately if I start Quickflasher the file does not see it yet ...
Should I restart? Can you explain better?
ps
if I click on "Select your package" I do not have the ability to select any file ...
EDIT:
If i enter in the directory the file Quckflasher build.prop.no_overlay_big_icons_quickflasher.zip, is viewed by Quickflasher, but the fiile ...
But the file Quickshotv2_720p_kernelpack.zip is not seen by Quickflasher.
I might rename it "*****quickflasher.zip" ?Last edited by kRel; 02 April 2014, 15:38.
Originally posted by kRel View PostIf i enter in the directory the file Quckflasher build.prop.no_overlay_big_icons_quickflasher.zip, is viewed by Quickflasher, but the fiile ...
I downloaded it at least three times and I was told that is installed with Quickflasher ...
Where am I wrong?
PS
I installed "small icons" before....
There are currently 1708 users online. 0 members and 1708 guests.
