Minix Neo X7 Quickshot v2 Rom by The Nitro Team
    Re: Minix Neo X7 Quickshot v2 Rom by The Nitro Team
    Originally posted by FestivusOz View Post
    @Daemonium (and team).
    I am in the right thread now. Thank for creating the scripts to undo the Mele and the other air mouse stability removal script. And the advice was appreciated. After running the script its definitely a keeper.
    Thee feedback for your information is as follows for Tronsmart TSM-01:
    After 4-5 days I have not had a single force shut down. However the mouse cursor still drifts or becomes erratic. I notice this more in 2 scenarios:
    1. When web browsing (any browser)
    2. Under system load i.e. tTorrents running, ES Explorer, Browser, BXBMC
    On 1704/GPU_Stock/720 the system still works like a breeze however I occasionally get shutdowns in BXBMC an tTorrents Per Flumpster's advice I will revert to Stock/Stock/720 and monitor.
    Thanks TNT for your continued dedication and support.
    Thanks for the feedback , we suspect that library was the reboot problem with certain remotes origin. But we didn't had a melepro or tsm-01 to test so the feedback is greatly appreciated
    When a massive io (in-out) operation is made, like when a torrent is finished and writing the file, or checking the file hash, etc... usually the device experiment a little freeze state, only 1-2 seconds, but this is normal. Check if your problems are in those situations.
    Originally posted by Thunderboltsteve View Post
    Just wanted to say a massive thanks, was put onto this forum and rom by somecooltech on youtube and delighted! Only question i have is there a way to reallocate the internal storage? I have a 32gig sd set up as the nand flash so wondered if i could reallocate the entire internal storage to the 16 gigs spare as opposed to the 4gig as standard? I noticed finless saying he has a patch for that, is it simple enough? If it isn't it's no big deal i'd just like to utilise the storage as much as possible. Thanks again guys, top effort!
    No kernel changes are needed, only parameter file needs to be changed, but if you change it, you will lost all in the internal nand, we wanted to stay in stock partitions sizes as much we can, but in next version we will provide some options. 4, 8 or 12Gb.
    leolas
    sent from my phone.
    My devices:
    Gearbest.com)
      Dear Nitro Team! I have a question. In some games as TempleRun, EternityWarior... I can't click on screen by mouse, i use HardwareGugu, btw, in Quickshot can i do that???
      Sent from my NEO-X7-216A using Tapatalk
        yes on both roms, with the help of tincore keymapper. look for tincore keymapper on playstore
        There are 10 types of people in the world: Those who understand binary, and those who don't...
        If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
          Tincore c
            Thanks...i will try son after buy keyboard..
              THX
              Hello,
              i am a new user of this rom, and i love it. All works great, no problems after 72 hours. Thank you for this great job
              Greetings Paperboy
                Originally posted by coverworld View Post
                Hello,
                Greetings Paperboy
                i'm glad to see you like it
                  Odp: Minix Neo X7 Quickshot v2 Rom by The Nitro Team
                  Originally posted by leolas View Post
                  Can you check in accessibility options? There is an option for mouse wheel to zoom.
                  leolas
                  sent from my phone.
                  On stock i just need click roler and move left or right to zoom in-out.
                  Like u said there is a option on configuration to ON zoom with mouse roller. Now need click roler and rotate up-down to use zoom in-out. It works almost the same. Thank you Leolas for help. I feel like noob, but happy. Now have full functionality rom. Now need spdif full working passthrough, maybe on v3 quick shoot rom Hdmi working fine.
                  Wysłane z mojego Nexus 7 przy użyciu Tapatalka
                    hey no one borns with all learned, like you I asked, and some people gave me the answers, and everyday I learn someone new from someone
                    leolas
                    sent from my phone.
                    My devices:
                    Gearbest.com)
                      Friends, where to get boot.img for 720p_kernel on this ROM?
                        Or just go to accessability settings and turn mouse wheel zoom on. Then you can use mouse wheel as a hybrid mouse pointer in tincore. App detects zoom as click, tested it on several games and it works just fine. So you do not need any keymapper, well atleast for the menus
                          R: Minix Neo X7 Quickshot v2 Rom by The Nitro Team
                          Hy guys, just one question....I am curently on Finless 1.8. It is some risk to flash this( size of the system img) ?...
                          And if not, can i flash 720p from finless with this rom?
                          Inviato dal mio GT-I9000 utilizzando Tapatalk
                            When I flash ROM, everything runs good until INF0: start test device. I get the following errors:
                            ERROR: Test device failed
                            ERROR: Run failed
                            What am I doing wrong here??
                              You don't need a special boot.img for 720p in this rom
                              No problem I think, I think we have the same partitions size . We suggest to install our 720p patched kernels in the rom, but you can install Bob Kernels too.
                              ERROR: Run failed
                              Did you come from a KitKat rom?
                              leolas
                              sent from my phone.
                              My devices:
                              Gearbest.com)
                                Is there an update coming soon to room
                                Kit Kat example
