Minix Neo X7 Quickshot v2 Rom by The Nitro Team
Originally posted by SUNUN View Posti use installed in this rom youtube
Originally posted by ajamils View PostHow do I go back to stock from this ROM? Is it just matter of flashing official ROM just like this one?
Also, does it have the Wifi display working?
If I recall it has a wifi display on the status bar also... I just didn't like the idea of using their overlay and prefer a true 1080p instead.
Error on install 720 kernel...
So ...
I have successfully installed the kernel in 1080. Before installing I did a factory reset, a wipe system, wipe cache and Dalvik.
I was unable to install the recovery from 720p ... always gave me the error: The package has not been installed. I also re-downloaded the package and tried a new install with the second kernel package 720.
I have flashed patches with small icons quickflasher before using 720p kernel.
I do not understand ... solutions?
Re: Minix Neo X7 Quickshot v2 Rom by The Nitro Team
I flashed the ROM and then flashed small icon pack via quickflasher but I am unable to flash 720 kernel as quickflasher does not see it even though it is in the same directory as other zip files.
Do I need to install kernel via recovery?
Scribbled on Galaxy Note 3.
Originally posted by ajamils View PostI flashed the ROM and then flashed small icon pack via quickflasher but I am unable to flash 720 kernel as quickflasher does not see it even though it is in the same directory as other zip files.
Scribbled on Galaxy Note 3.There are 10 types of people in the world: Those who understand binary, and those who don't...
If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
Originally posted by ajamils View PostSo I need to purchase PRO version? That does not sound like an optimal solution just to flash one zip. Can I do it in recovery?
Originally posted by rdsok View PostDon't be so daft... remove the one's you aren't using/flashing... just leave 3 in at any one time.
Originally posted by ajamils View PostI removed all zips. Only one is in the folder and it still does not see it. I will restart Minix and see if that works.
There are currently 3234 users online. 0 members and 3234 guests.
