Minix Neo X7 Quickshot v2 Rom by The Nitro Team
Originally posted by SUNUN View PostAdded some support for mele F10 if this mean F10 Pro too and what you add?
Thanks to arijafari from Androidpc.es who tested it with a melee f10 pro. We dont have this remote, but he tested it and no reboots in 4 days
Originally posted by SUNUN View Postwhich of this pack download and what kernel install for stable work for true 1080p screen resolution?REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Solve reboots problems with mele f10 and other remotes: in the first message.Last edited by litry; 05 March 2014, 15:03.There are 10 types of people in the world: Those who understand binary, and those who don't...
Thank you for buying me a beer
Originally posted by SUNUN View PostPls I need your help which kernel to choose?There are 10 types of people in the world: Those who understand binary, and those who don't...
If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
Originally posted by Phycopat View PostHello.
I'm pretty sure that AC3 was working for me then i did use Quickshot, my sound was through HDMI and with out the patched libmedia.so...
Only thing i had to do was to chose the hdmi passthrough, last setting in device manager and then play through MXplayer..
XBMC was a little tricky, had to use a libmedia hacked version aka JustXBMC or SPMC..
Cant test that now, i'm pt on HardwareGuru 04..
Any one have cwm patch? Its not xbmc problem for sure. I think Libmedia is not patched properly.
Re: Minix Neo X7 Quickshot v2 Rom by The Nitro Team
Originally posted by SUNUN View PostYes I reed but cant understand wich kernel from 1080 pack to chooseThere are 10 types of people in the world: Those who understand binary, and those who don't...
Originally posted by SUNUN View PostPls can you tell me if this rom support NTFS or EXFAT?Originally posted by SUNUN View Postcan you tell me game mode and mic and dyanmic now works in mele f10 pro with this firmware?
The patch only solve reboots and freezes problems with that remote.
Leolas.
Sent by my phone.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
AC3 no working on mxplayer, stock rkvideoplayer and xbmcHelp...
Audio is ATSC A/52A (AC-3). 386kbits/sec,5.1 48kHz
Many samples with dts, dd ac3 etc
TEST TOOL Ac3 Dolby Digital 5.1Ch Sound Test 448,0 kbits/sec: http://www.wooferbasstest.com/downlo...1ch-sound-test
My last one sample: American Hustle 2013 BluRay 1080p FLiCKSiCK_SAMPLE.mp4 with 2 audio stream AAC stereo 2.0 and dolby digital ac3 5.1 - easy to find on torrents
My configuration:
Minix firmware is Quick Shot by The Nitro Team ver2, 720p oc kernel is 1704cpu_gpu_stock_720ddr.
Minix neo x7 is connected with hdmi cable to the Panasonic Viera TX-P37X10 37in Plasma TV. Minix neo x7 is connected with toslink optical cable to LG HT903TA reciver. Both cables are ok.
My home theater receiver LG HT903TA have THX certificate. It supports: Dolby Digital, dolby prologic II and DTS. When audio is passthrough to reciver I can see logo what type of audio stream is decoded: DTS or Dolby Digital so i know passthrough is working, but:
*DTS works ok and give real 5.1 sound
*AC3 give no sound - silence only
In Android audio settings, choose Rockchip SPDIF pass through. On xbmc go system then:
* audio output settings: optical /coaxial,
* speakers configuration: 5.1
* dolby digital ac3 : capable reciver
* dts: capable reciver
* aac: capable reciver
Audio output device Android audiotrack or android audiotrack (PT)
Passthrough audio device:
error no devices found on minix xbmc version
android audiotrack (PT) on beyound 3.3 beta by Flumpster
libmedia hack by stafstrom enabled on SPMC libmedia with updated long mouse click function 2013-12-15 like this
I was try with diferent libmedia as:
*libmedia-quickshot-update.zip
*libmediaNeoX7Fw007Patched.zip
*libmedia_007_patched.zip
All have the same size 395,34KB after unzip, so i think are the same libmedia.so. I was rebooted after swapping files. It all works the same on xbmc minix, beyound, spmc libmedia edition, rockchip stock video player & mxplayer. So no ac3 audio is not player or reciver issue.
When i put the audio-video sample with usb pendrive direct to reciver usb port and make it play i can hear real 5.1. Audio on all dolby digital ac3 samples play just ok then. Reciver decoded it easy, dolby digital or dts logo lights on dvd player. Problem is when whant use external source like my minix neo x7.
I'm thinking to change for 007 stock fw and try root and cwm by myself, then put libmedia & librkffplayer.so both patched for 007fw. Maybe it dont work in 008fw based rom like quick shoot v2?Last edited by Fedur; 06 March 2014, 14:29.
FEDUR: ive done also so much testing and no success
Phycopat advice me some steps few pages back , but i havent had time to test those.
About the libmedia.so size - size is the same , but i did file content check and they have some differences...after ive changed it , i was able to see "hacked" in XBMC sound settings.
Leolas: about the 1080p resolution with small icons - desktop UI is fine size, but why are the webpages so BIG? like 640x480? when i do that on the phone or tablet i can see more as on my FullHD projector.
Any fix for that?Android devices: Minix X7 (gone) , Minix X8-H , MK808b Plus
Video Out: Benq W1000+ 1080p Projector
Audio Out: HDMI -> Yamaha RX-V467B + 5.1 Yamaha Speakers
Remote: Rikomagic MK702 II, Minix NEO M1
Storage: NAS Zyxel NSA325v2
There are currently 3328 users online. 0 members and 3328 guests.
