Minix Neo X7 Quickshot v2 Rom by The Nitro Team
Originally posted by leolas View PostAlmost all custom roms have root access, this Rom has root access, so you can use it to remap your gamepad.
If you make all steps to flash ok the Rom, there is a little possibility that something went wrong yet, I suggest to make all the steps again, disconnect external storages, like sdcards or usb, erase idb, flash, once the process finish, let it connected ti pc for a few minutes (5-10), if you have the device connected to TV you can wath how the system recovery makes some operations, after it will reboot automatically, then the Rom logo will splash, and after the android setup wizard will be launched, then you can power off the device, disconnect it from pc and power on it again to make the first boot.
Follow the wizard indications to select, language, WiFi, Google acount, etc...
After the wizard is complete, push the home button, select launcher and start to play.
leolas.
Originally posted by dakirba View PostOkej, I will try again this evening. So there is nothing wrong if I flash when the device is connected to tv with hdmi?
Originally posted by Gisbourne View PostI would actively encourage using a TV while flashing as you'll be more tuned into where you are in the process and it might prevent pulling the plug/resetting the box too early!
I can understand that, yes. I just wanted to exclude everything that could cause a problem, just to be sure that I'm doing everything right.
What about the usb drivers - I downloaded some drivers from stock rom. Do you prefer some other drivers?
Could you send me the link to the usb drivers that you use for flashing? I don't know, maybe this is causing the problems... Everything is possible in technology
YouTube live streaming issue
My compliments to the Devs for this ROM and their feedback in this thread.
I have a question regarding YouTube live streams: Whenever I connect to a live stream, the first few seconds of video streams in great quality/resolution.
After about 5 seconds of live video, it is as if the quality steps down to 144p and it stays like that. This happens regardless of the ROM or YouTube app (Stock 008, Finless 1.8, Quickshot 2, YouTube stock/HD). If I watch the same live streams via the same DSL connection on my i9100 phone or TF300 tablet out doesn't happen. Also watching the live stream in Chrome/Stock Browser doesn't cause the sudden 144p quality drop. Normal non-live videos are not affected; they stream in HD perfectly.
Any ideas?
Re: Minix Neo X7 Quickshot v2 Rom by The Nitro Team
Originally posted by picarddontoro View PostI installed this beautiful rom but unfortunately many texts are in Spanish!
Will correct this problem?
Thanks in advanced.
Sent from my LG-V500 using Tapatalk
Thanks in advanced.
Originally posted by LCBXX View PostMy compliments to the Devs for this ROM and their feedback in this thread.
Any ideas?
This ROM is amazing! So fast using the 720 memory. Thanks so much!
One question.. I just found the Minix Remote control APK and installed it (no airmouse right now, just stock remote). Everything is on the same network., but the problem is the Minix Remote app cant find my device. Does it work with QuickShot?
There are currently 2576 users online. 0 members and 2576 guests.
