leolas.
Minix Neo X7 Quickshot v2 Rom by The Nitro Team
Re: Minix Neo X7 Quickshot v2 Rom by The Nitro Team
Originally posted by djla View Post
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Guest
In search for my best suitable Rom switched back to yours.
But I have a thing which the other Rom haven't.
In Mashup and Beyondxbmc (and nitro xbmc also) it can not resolve the url with180upload.
The captcha isn't loading and gives this error.
Mashup urlresolver error'url error' object has no attribute 'code'
On my tablet it's all working. So flashed an other Rom for the x7. And there it is working.
Can someone reproduce?Last edited by Guest; 20 February 2014, 10:50.
Originally posted by wackidth View PostIn search for my best suitable Rom switched back to yours.
On my tablet it's all working. So flashed another Rom for the x7. And there it is working.
Guest
Originally posted by kokoui View PostWhich rom you flashed? Also for the other rom you still use BeyondXbmc?
But the nitro xbmc edition is the same story.
I flashed nitro three times and downloaded again. So it's also not a bad flash or something like that.
The other Rom is Hardwareguru. And yes also Beyondxbmc.
Guest
Originally posted by kokoui View Postperhaps is the adblock app that blocks captcha. Can you remove the app and test it?
Will try when i get home.
Do you use Mashup and can you reproduce this for me?
Originally posted by wackidth View PostI did not activate adblock so I guess it's not working? Did not download hosts etc. Or is it working out of the box?
Do you use Mashup and can you reproduce this for me?There are 10 types of people in the world: Those who understand binary, and those who don't...
If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
Originally posted by litry View Post[Custom ROM] by The Nitro TeaM Quickshot V2
THe TeaM Nitro presents
***** ***** Quickshot v2 ***** *****
The Nitro TeaM (TNT) is formed : Litry , Tincore , Leolas , Skelton and Daemonium
Well, this time we want to offer the second version of Quickshot, it has some improvements and make the rom easier to use, we have worked hard on it and hope you enjoy it.
Changelog:
- Based on the stock rom 008 Minix , we have gutted it and we added everything that seemed useful for us.
- We have removed the overlay by default, we find it useless and it results in wrong identification of the device resolution in various applications. The kernel used is the Minix stock 1080p and we also provide overclocked kernels (patching the stock kernel) to be installed, all of them 1080p.
- Debloated, this time rather more than in the previous version.
- Rooted with the latest SuperSU installed.
- Updated and full working Busybox.
- All Google Apps updated to their latest version .
- Added init.d support. It was tested and works great.
- Added adb tcp (by wifi or ethernet) and adb is working from the start while you connect the OTG USB to PC.
- Now from terminal or adb you can use the nano editor to edit files .
- Some TCP tweaks
- Launcher-MOD , transparency and customizing launchers and background. Look at the wallpapers available, they are great.
- Pre-installed apps Es FileExplorer, Mxplayer, Firefox, Tincore KeyMapper, Reboot apk, xbmc-modded (minix based), Adaway, terminal emulator, Sony Walkman music player, youtube HD, etc ... All applications are installed as user, so if you want, you can uninstall them without problems.
- Added Quickflasher and KeyMapper from Tincore, great job done, later we will explain something more about those applications.
- Added some support for mele F10 and RiiMini i8 .
- Added a quick configurator to start .
- Replaced the framework cursor.
- Moded xbmc with some preinstalled addons and custom skin.
- CWM recovery installed automatically after first boot . Now you can make backups of your Rom, install updates from the cwm recovery or restore previous backups.
- From this version we have a new system ROM update , now just copy the files that we will provide to the sdcard or external sd for the update.
- We provide a large number of kernels with speeds for all people, from a simple oc, to a very aggressive oc, we will give you the choice , remember that very aggresive oc can generate more heat in the microprocessor and short the life of the device, do it with moderation and knowing what you do.
- OTA service from minix disabled.
- Some other little tweaks applied.
DOWNLOAD LINKS:
ROM:
To install from pc:
http://www.freak-tab.de/leolas/Quickshot/V2/QuickShot_V2.rar
To install from cwm:
http://www.freak-tab.de/leolas/Quickshot/V2/QuickShot_V2_cwm.zip
QUICKFLASHER PATCHES:
kernel:
1080p patched kernels pack:
http://www.freak-tab.de/leolas/Quick...ickshot-V2.zip
Some options:
Big icons:
http://www.freak-tab.de/leolas/Quickshot/V2/build.prop.no_overlay_big_icons_quickflasher.zip
Small icons:
http://www.freak-tab.de/leolas/Quick...ickflasher.zip
Overlay(not recommended):
http://www.freak-tab.de/leolas/Quickshot/V2/build.prop.overlay_quickflasher.zip
Install Airpin:
Airpin is only for Minix Neo X7 device, Minix have a license for this app, it will not be installed in other devices.
STOCK APPS FROM MINIX DELETED IN THIS CUSTOM:
http://www.freak-tab.de/leolas/Quickshot/V2/rockchip_apps.zip
STOCK APPS FROM ROCKCHIP DELETED IN THIS CUSTOM:
http://www.freak-tab.de/leolas/Quickshot/V2/Minix_apps.zip
Guest
In the next Rom version we will remove adblock by default, we didn't notice those problems while we tested it.
There are currently 2604 users online. 0 members and 2604 guests.
