Minix Neo X7 Quickshot v2 Rom by The Nitro Team
    Originally posted by leolas View Post
    In the next Rom version we will remove adblock by default, we didn't notice those problems while we tested it.
    leolas.
    Since it has an auto-update feature... the problem may not have been there at first and then was later blocked... probably due to some ads being served from that server being used.
      How to remove cwm fo ra clean install of quickshot
      Howdy,
      I installed quickshot v2 using cwm. However the previous firmware was the hybrid firmware from lewy. Im worried that it might not be a "good" install of quickshot. A symptom I found was that my sdcard memory was not accessible after install. I had to go into cwm and format it as just trying to mount would not work. I would like to do a clean install of quickshot to make sure everything is installed as it should be however I dont know how to get around the cwm bootmenu to do a install via the usb cable. Holding the reset button just causes the cwm menu to come up.
      Thoughts on how either verify my quickshot install is "good" partition size wise ans such or how to do a clean install?
      Doug
        Re: Minix Neo X7 Quickshot v2 Rom by The Nitro Team
        Originally posted by Knightmare View Post
        Howdy,
        Doug
        From lewy rom we suggest a clean instal from pc erasing idb, not from cwm. The easiest way to enter in loader mode is open terminal emulator and write:
        su
        reboot bootloader
        Afte write su supersu will ask about root permission, acept it.
        Then your pc must sound like a dong, install the drivers open rkandroidtool included with the Rom, erase idb, and run to flash the device.
        After the flash proccess finish, wait 5-10 minutes until you disconnect it from pc.
        And enjoy.
        leolas.
        My devices:
        Gearbest.com)
          Originally posted by rdsok View Post
          Minix's main website http://www.minix.com.hk/
          It was the 4th item returned in a Google search so I'm not sure why you had trouble finding it.
          thank you should have looked. what is the difference with using this rom, compaired to the minix x7 14012014 image. plus can some1 please advice me how to backup my image please.
            Thanks for all your help! You guys were right. The wireless dongle is spoilt. Will have to get a new one. Thanks once again. You guys have been immensely helpful!
              where is the keymap.xml of XBMC?
              I like to edit the mouse behaviour in XBMC. I cannot find keymap.xml. Looked everywhere..... CAn somebody tell?
              In fact I can not find XBMC at all....
                The Minix website that I linked you to earlier has the images of the ROM's... you can download a clean one from them.
                For backing up apps and data... I use Titanium Backup but it requires root access and the default ROM does not have that.
                For info about what this ROM ( Quickshot v2 ) has... see the first post for the list of features this one has and you will know most of the differences.
                  finless kernels
                  My apologies if i overlooked a previous post but I was wondering if i could use one of Finless 720p OC kernels. Currently my X7 is connected to a 720p screen and maybe this would then be the best combination.
                    hey guys,
                    we are doing some test to provide 720p kernels.
                    Here is a 720p cpu 1608 gpustock ddr 720 for those who want to try it. This one is actually flashed on my box and working as expected
                    IT MUST be flashed by using the pc method, just uncheck all but kernel and select this file.
                    EDIT: You must flash the small icons patch before flashing this kernel.
                    There are 10 types of people in the world: Those who understand binary, and those who don't...
                    If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
                      Hi. Thank you for this beauty. Took me ages to find good rom with smooth xbmc playback. I got mk 802 rk3188t and it's working like a charm. I think otg doesn't work but that's ok. I also bought pro version of flashing app. Thanks.
                      Sent from my GT-N7100 using Tapatalk
                        What level of know how is needed to complete this ?? I'm new to this and I am afraid of messing up my minix x7 am I better off getting more experience first or is it child's play???😎
                          I tried this and pretty much unstable. There are random drawn lines and screen flickers from time to time.
                            Originally posted by daemonium View Post
                            hey guys,
                            What's the problem if flash with tincore? youve promoted tincore guys and i like it.
                              and we love it But for now it must be flashed by pc, we will have a look later on why it's not working when flashed by quickflasher.
                                hey guys,
                                Thank You very much! Waiting for 1.8/798/720 kernel if possible I dont play with those low oc ones, but will try for sure, maybe I will get near same performance on 3D. Will inform you and maybe someone could provide another link?
