Minix Neo X7 Quickshot v2 Rom by The Nitro Team
Did stock minix rom had a mouse pointer before? Because I haven't use stock firmwar, i installed yours directly due to your very good results but i have trouble using the device with the stock minix remote. I tried to use tincore keymapper but it is too difficult for me, I manage to show a mouse pointer with tincore but wasn't able to do any clicks. is there any way to install any mouse pointer for this device?
Did further testing and I have to say TWO THUMBS UP. Awesome ROM Nitroteam has put together.
The ever present micro stutter in 1080p is still here. Maybe my eyes are fooling me or it is less in MX player.
I have yet to try the quickflasher to try the kernel CPU 1700 stock GPU DDR 720.
Hats off to all the hard work you guys did putting this together!
First of all thank you for a great ROM and sorry for my English.
I have a problem with WiFi, when I flashed the ROM it worked great, then I disabled it and activated ethernet, used it for several hours and decided to activate wifi again (disabled ethernet). Now when I try to activaye wifi it always says "Wifi is turning on..." and nothing happens. Does someone experienced that issue?
Re: Minix Neo X7 Quickshot v2 Rom by The Nitro Team
Try this, enter in settings, disable Ethernet, disconnect the lan cable, and reboot the device.
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Guest
Would it be possible to automatically set the framerate?
The micro stutter is gone on some movies at 24hz but some on 50p.
In Windows XBMC it will automatically change.
Originally posted by wackidth View PostWould it be possible to automatically set the framerate?
The micro stutter is gone on some movies at 24p but some on 50p.
Originally posted by lewys View PostThanks for reply but unfortunately it doesn't work, still Turning wifi on... when I'm trying to activate it.
Originally posted by leolas View PostSorry, nothing new, can you try to install an older app version?
leolas.
I have the same issue with the "Sochi 2014 on Ten" app (probably available Australia only).
Trying to stream video makes the X 7 crash.
I suspect that it used the same streaming protocol as the AFL and NRL apps, and they all crash for the same reason.
If anyone else is in Australia, could they also test video in the AFL and Sochi on Ten apps?
Could someone also please test video in the NRL app?
Just want to make sure they are consistent issues.
Originally posted by ptiper21 View Posthi. i have a streaming app that doesn't work with rooting devices. i wonder if there is any way to hide root for certain apps!I can understand apps that ask for root, but I can't understand apps that check that you are not root to allow you run them
Originally posted by ptiper21 View Postalso i would like to edit build.pro and change x7 to nexus 7 , like version 1 of this wonderfull rom. what do i have to change? thanks
From the reviews on the Play Store, it seems the Ten Sochi app doesn't work with a lot of devices.
Birddog
Originally posted by Birddog727 View PostHey, I just tested the Sochi app, and it wouldn't play any of the streams, and then crashed as well.
Birddog
There are currently 6217 users online. 3 members and 6214 guests.
