Hi guys,
I flashed Quckshot V2 over android 4.4.2 by wasser via CWM. That is not a good idea apparently, since it was stuck on boot screen since. So I tried the PC tool, but onfortunately this gives me an error message too.
I checked wasser's thread on info about partition sizes, but I didn't see any, so I assumed CWM should work...
What should I do now?
EDIT: I can't connect to PC now anymore, I hear the "connect" sound (Windows 7) but then after a second or two, it diconnects autmatically...
Edit: never mind, for some reason I succeeded in the next attempt. Turns out if you hold the power button for some time it will connect properly again.
