Minix Neo X7 Quickshot v2 Rom by The Nitro Team
Re: Minix Neo X7 Quickshot v2 Rom by The Nitro Team
Originally posted by welcometopoland View PostThere are 10 types of people in the world: Those who understand binary, and those who don't...
If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
HDMI Passthrough
Originally posted by daemonium View Posti've posted a patch on this , waiting for the feedback now
HDMI Passthrough is still "not" working..
Can choose between Analog and SPDIF in XBMC.
And i also see "Error - no devices found" in sound options.
In the Sound devices it's show as: "RK29_RT5616 PASSTHROUGH"
Had a MK802IV a few weeks ago, that was ok and shown as "HDMI PASSTHROUGH", with XBMC working without patches..
I found another "nice" thing.. Playing a MKV from SDcard, gives me DTS 5.1 from MX Player!
Will try to load a DD or AC3 movie later on, maybe first tomorrow..
- Right track here, now we just need XBMC also!
thanks for your work so far!
Edit: i might think that SPDIF is working, i see it in all the right places.. Cant test as i'm using an B&O System 3..
Edit: i might think that SPDIF is working, i see it in all the right places.. Cant test as i'm using an B&O System 3..There are 10 types of people in the world: Those who understand binary, and those who don't...
Originally posted by alexnev View PostHi Team,
Thank you for the nice ROM! I'm toattal newbie for android and this ROM is my first custom ROM installed. SO far so good!
One minor observation: I noticed very poor perofrmance of class 10 8GB SDHC SD card under this ROM. Read speed was something like 17Mb/sec, write about 9 MB/sec. After I installed "SD card speed booster" app from play store performance was dramatically improved - read speed about 590 Mb, write about 9-10 MB/sec. App said something about battery setting and I think it also changes default cash block size.
Could you guys please take a look and optimize these settings by default to get a better performance.
Thank you for your ROM,
Alex
Originally posted by daemonium View PostI took libmedia.so from the 009 ota update and made a patch
Can you test it?
Just rename the file to quickshot-update.zip, put it in /sdcard and reboot.
The system will boot, you will see the bootanimation and the system will reboot into cwm recovery.
The patch will be applied. If the recovery doesn't reboot automatically, just reboot
on my testing this happened justo once, because i wrote quickshot-udpate instead of quickshot-update. please check the filenameThere are 10 types of people in the world: Those who understand binary, and those who don't...
Originally posted by daemonium View Poston my testing this happened justo once, because i wrote quickshot-udpate instead of quickshot-update. please check the filename
the system looks for the file /sdcard/quickshot-update.zip on every boot and if it finds it, then reboot into recovery and apply the zip.
Do you have quickshot v2 installed?There are 10 types of people in the world: Those who understand binary, and those who don't...
Originally posted by daemonium View PostI'm doing some test changing the cache value from 128 to 1024/2048/4096/8192 on two sdcards, class 2 and class 6.
The only value increased is reading speed, but the improvement is very little. Making the sdcard work this little faster will make no difference.
I need someone else to do the speed test.
Originally posted by tltester View PostI've played with increasing the cache value for internal SD (with Pimp My Rom app) and my SD was constantly ruined and required reformatting 3 times in month until I've removed the tweak. Now everything is fine again. I don't think it's worth the risks of data loss...There are 10 types of people in the world: Those who understand binary, and those who don't...
Originally posted by daemonium View Postthe system looks for the file /sdcard/quickshot-update.zip on every boot and if it finds it, then reboot into recovery and apply the zip.
yes it is ok to do that but your system is not working as expected. something weird happened. :SThere are 10 types of people in the world: Those who understand binary, and those who don't...
Originally posted by daemonium View Postyes it is ok to do that but your system is not working as expected. something weird happened. :S
I did also install from CWM..
Maybe Xbmc dosent see the New file? In justXBMC it does show something about a libhack? Some time ago i had that installed on another rom..
Maybe i'm wrong? Anyway to patch it manualy?
Just to be sure that the file is copyed correct..
There are currently 1771 users online. 0 members and 1771 guests.
