Minix Neo X7 Quickshot v2 Rom by The Nitro Team
did you try the BS player i use that over mx player i think it might work it does for me! and if you havnt changed your kernal to 1700 stock 720 than that is your problem for the slight lagMinix neo x7 custom quickshot V3.1 kitkat with cpu1700 video stock and oc ram 720 kernal
HTC Amaze 4g unofficial cyanogen mod 11 KitKat 4.4.4
ASUS Nexus 7 (original 2012 tegra 3) Cyanogen mod 12 Lollipop 5.0.2
Originally posted by neodoom View Postdid you try the BS player i use that over mx player i think it might work it does for me! and if you havnt changed your kernal to 1700 stock 720 than that is your problem for the slight lag
Can you give the link for that kernel?I cannot find it in the first posts.Thanks
Originally posted by failax View PostCan you give the link for that kernel?I cannot find it in the first posts.Thanks
Enjoy!There are 10 types of people in the world: Those who understand binary, and those who don't...
If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
yes the one you said in the pack i had the 1800 going but had a few random reboots with it since then using the 1700 stock gpu and 720 kernal made a big diffrenceMinix neo x7 custom quickshot V3.1 kitkat with cpu1700 video stock and oc ram 720 kernal
Originally posted by neodoom View Postyes the one you said in the pack i had the 1800 going but had a few random reboots with it since then using the 1700 stock gpu and 720 kernal made a big diffrence
Can't wait to try it :-)
I solved Windows 8.1 drivers problem installing Windows 7 in another partition.I bought a rii mini keyboard with touch pad, but maybe it was better an air mouse...
Re: Minix Neo X7 Quickshot v2 Rom by The Nitro Team
Originally posted by failax View PostJust changed kernel to 1700 ddr 720, but the micro lags are always there..
Scribbled on Galaxy Note 3.
Originally posted by ajamils View PostI tried different kernels but couldn't get the micro lag to go away completely. Switch to a different ROM with Minix version of XBMC and haven't had the same issue.
P.S. You have a PM..
There are currently 1673 users online. 1 members and 1672 guests.
