MK918 2G/8G TVBOX RK3188-T
    Originally posted by ollie26 View Post
    Wasser KitKat ran much smoother in android and xbmc but no Ethernet nor Bluetooth. Also some audio problems with sound loss and crackling. ROM only works on our box with his Old 1080p kernels.
    Have you tried the finless ROM 2.0 - 4.4.2 KitKat for AP6210 wifi - BETA, or a his kernel with wasser KK...
      No, only fw I've used is jellybean and KitKat Wasser. Neither Lewy2001? Wouldn't boot. Kernel problem I think.
        su am display-size 1080x1920 gives me error exec failed for display
        What error gives ? Is busybox installed (from Play market) ?
          No I don't have busybox. Thanks!!
            @Liam
            To run the command, download a terminal emulator from the play store.
            then type in:
            Su
            How do I reverse this? My desktop sometimes flips sideways and some play back is poor in xbmc. Thanks
              @Liam
              Try use
              su
              am display-size 1920x1080
              instead
              P.S.
              reset to default -
              su
              am display-size reset
                Try use
                su
                instead
                P.S.
                reset to default -
                su
                Ahhh thanks! Why did not spot that lol.
                Well I reset to default and then 1920x1080 and now I have huge black borders each side vertically. I have a full HD 1080p TV.
                  Its strange. In my fullHD tv its no borders on screen. I set screen scale to maximum (its 100%) in "screen" -> "screen scale" settings on my box, and change "picture size" option on TV to "Just scan"
                  Dont forget to check if HDMI mode settings on box is 1920x1080 (it may accidentally change after reset to defaults).
                  p.s. I think that display-size 1920x1080 is not proper for this box - its portrait display orientation... Proper settings is display-size 1080x1920.
                    Got one, DOA
                    Originally posted by arfarf View Post
                    Just got one of these boxes and it wouldnt boot past the "ANDROID" screen. I reflashed it with RK Batch Tool 1.7 and RockChipDrivers 3.5 on windows 8.
                    Working nicely, apart from needing a lot of apps and customisation. Thanks for all the info on this thread.
                      MK918 and droimote server problem
                      I have also one of these boxes and I have uploaded a number of high detailed photographs at http://yadi.sk/d/0sDRcMF8HPfkw
                      For many days I am trying to use the droidmote server that I have bought, but only the mouse does work, and the gamepad dysfunctions as I have posted in the droimote forum ( http://www.videomap.it/forum/viewtopic.php?f=11&t=1355 ) .
                      Is anybody here that has this box and has bought droidmote server to confirm that there is a problem on controlling the games?
                      I am thinking of flashing with a newer image, but I see that there is not 100% complete image yet.
                      What do you suggest me to do?
                      Thank you
                        @Chrisontab
                        http://pan.baidu.com/wap/link?uk=125...964885&third=0
                        fast link for download, if anyone's interested...
                        This Is the latest firmware for this device I think.
                          Welcome, this is a result of the joint work ...
                            @Chrisontab
                            Probably ... now when it passed the Chinese New Year ... can be expected to appear soon new stock ... as sales started to grow vigorously ...
                            The big problem is RK3188T chip ... which is its specifications away from 1.6-1.8 GHz ... now justified revolt calms customers with new software ... and oc kernel ...
                            what will be... we will see ...
                              Mine is rooted
                              Firmware isnt rooted
                              I re-flashed with the stock firmware linked above and it was already giving me root.
                                Droidmote
                                Hi bbdroidas, I plan to install droidmote later today and will report back on how it works. The newest firmware found by ollie26 is what I am running. It looks like exactly the same box as me, but I havent opened the case. I did at least have that "Wi8.com" sticker on the side
                                I hope droidmote works, because the remote is very limited! Anyone else tried it on this box?
