MK918 2G/8G TVBOX RK3188-T
Originally posted by bbdroidas View PostI downloaded the rkremotecontrol from http://www.timingpower.com/rkremote-1 my tablet discovers the tv box, it connects, and as soon as I move my finder on my tablet, the tvbox reboots.
.Last edited by Cat; 11 February 2014, 06:32.
Thanks ollie, smbc is the way to go
Originally posted by ollie26 View Posthi, For your audio sync problem.... Audio Offset, click okay then adjust so it is in sync (mine is set to Ahead by: 0.150s) once you've found the correct setting click okay once more then scroll to the bottom and hit okay on " set as default for all videos
My contrast/brightness is okay, i did adjust via TV remote though.I am using XBMC - SPMC 12.4 (december 15 2013) Hardware Acceleration works through XBMC
Originally posted by chrisontab View PostYes, this works, although mine looks good at more like 0.250s offset!
Thanks for this suggestion ollie, problems with the brightness and picture quality were solved by using SPMC. I recommend everyone give this a go.
I will try that audio offset settings and see if its better. Thanks
I tried update_mk918_100k4100_beta0.1 ... It is quite fast KitKat ...
Antutu score 16,990 (versus 15,866 from update_cs918_203j2104_overseas_1) ...
Not rooted ... no additional software ... (XBMC, Chinese nonsense ...)
Problems with part of the application ... launchers and so on ...
Normally locked at 1.4Ghz (RK3188T mother****er...)
Not bad at all ... but what bothers me is Kitkat interface ...
Originally posted by gor View PostI tried update_mk918_100k4100_beta0.1 ...
I have "discovered" the Video app, which is the Rockchip one, looks like really nice hardware accelerated video, seems all nicely in sync with the audio. I cant get it to be called by xbmc (or sbmc) as an external player, which is a pain. Shame the app is so poor at browsing folders of files....
Originally posted by chrisontab View PostHi gor, thanks for the update. how is the video playback in the xbmc? Some of my .avi divx files are failing in the smbc version i have installed.
I need to try finless ROM 2.0 - 4.4.2 KitKat for AP6210 wifi - BETA ... I'll let you how it works...
tried Minix Neo X7 - finless 1.8 ROM with 720 kernel
rom is booted good ... but no wifi bt and enthernet works ...
rom is quick, no garbage but after five minutes is rebooted itself and again after 5 minutes ...
After that, I tried the original Minix neo X7 rom ver 008 of 01.01.2014 ...
This rom is also very fast stable working on our device ... playstore must be reinstalled ... rom constantly offering an OTA update that should not be accepted ... also does not work bt ...
stable worked more than one hour ...
Minix version of XBMC's also doing great ... problem with installing software from unknown sources ... other peripherals works ...
Originally posted by ollie26 View PostHey guys. Are any of the OC kernels working on those Roms? Some guys have got their CPU/GPU OC on the 3188T.
AP6210 wifi are needed in the kernel for wifi to work.
Someone else on Amazon said they used a Droidbox ROM - anyone tried them?
Here's the over clocked kernels by Sam http://www.freaktab.com/showthread.p...kernel-is-here
Originally posted by ollie26 View PostI have tried that T-R42 v2.0,ROM from lewy. It doesn't boot for me. Gets stuck in splash screen logo. Tried reboot and same thing.
Originally posted by ollie26 View PostHere's another batch for Finless ROMs http://www.freaktab.com/showthread.p...-2-0-1-9a-1-7)
im not brave enough to try over clocking this box - i havent opened up the case, but lots of people who have show pictures with not much in the way of a heat sink...
I'm looking for boring stability (and h/w video so its got good performance)
I was hoping the box would run at 1.6ghz as 1080p kernel/playback 1.42ghz doesn't quite cut it
SPMC Libmedia edt has h/w video working great at 720p.
What ROM are you currently using?
There are currently 1684 users online. 2 members and 1682 guests.
