MK918 2G/8G TVBOX RK3188-T
      For administrator...
        Any update on a ROM for this device from Finless?
            Originally posted by gor View Post
            hi guys as if I am relatively new to the forum and then buy this tv box thinking it was a cs918 bad that I barely noticed and longer qualify to seller on aliexpress, not so bad that there is only so many roms as I would, on mine when I put it to 1080p and more warming in the XBMC video cuts about 2/3 times during reproduction in a movie and it brings XBMC source does not work for me
            in the thread several guys tried several roms with not very good results but not tell me if I'm wrong or not
            and here is the original thread
            Update on 2th April, some developer said this rom have some kernel problem. please hold to flash this rom, till the developer to find the problem, and fix it.   […]
            Please comment if I am right or not, or if it's an proven, I have something
            luck
              hola, this is very interesting. looking a the thread, it seems lots of problems with no sound or not booting. I will wait until its properly working!
              my best suggestion is to install "Beyond XBMC". i dont think it matters what ROM you are running, it plays videos the best (local and streaming).
                Re: MK918 2G/8G TVBOX RK3188-T
                if they say it does not work well but
                from what I understand is that the
                install on devices that are not what
                recomindan only saw two comments
                were from those who suggest a
                package saying he would bie the
                question is one of those who has the
                mk918 the installed
                Enviado desde mi GT-S5830 usando Tapatalk 2
                  at least the sound if
                    He says it *should* work, not that he has tested it.
                      problem with xvid display on TV
                      Thanks first for your info’s. I have since last month a MK918.System seems good on the screen but following the test done till now, i have two problems. First when i want to see a divx , the images are not fluid ( sacade) 24 frame (test done with some media player and same problem. The second problem is when i use Skype, video is not suported .// Android version: 4.2.2 // Version du noyau 3.0.36+ sgq_V_104j2#36 // Vendor software version 203j2 //. Perhaps answers can be found somewhere ? If you can help me?Thx
                      If you like know your model here is a link
                      http://blog.geekbuying.com/index.php/2014/01/25/whats-the-difference-between-t-r42-mk918-cs918-q7-quad-core-tv-box/comment-page-1/#comment-148388
                        Try Beyond XBMC
                        Ive not used skype, so cannot comment on that
                          QUOTE=chrisontab;166288]Try Beyond XBMC
                          Ive not used skype, so cannot comment on that[/QUOTE]
                          I have tested divx video with MX player , VLC ,XBMC and it's the same . The video is not constant on the screen , you can see that the video is not constant on the same speed output ( 24 frame video in EU ).Already tested with a stick of a friend and same effect.
                            Which XBMC? Have you used Beyond XBMC? I found that to be much better on the couple of divx files I had, which wouldnt play at all in other versions of XBMC.
                              finally dared to install the rom, I will can not until Saturday time north america, is good only is the reproduction of video nothing more that would be the Kermel can make several attempts kermels difententes from rom the manufacturer to which are tested in the original thread, so I understand some are much better, sorry not completely understand English, please comment on the sound and some screenshots could badly do
                              Thanks and good luck.
                                new version
                                http://www.bee-link.com/en/data/article/1388485395640616952.0%20中文.pdf
                                更新日期:2014.02.12
                                update_mk918_204j2104_overseas
                                客户:中性海外版
                                base:update_cs918_203j2104_overseas
                                链接:pan.baidu.com/s/1mg3CaCw
                                修改:
                                1. 支持新BL-S4
