QX1 Quickshot v2 Rom by The Nitro Team
    Originally posted by jwnick View Post
    RKM Remote program does not see my device. How to fix?
    It probably isn't broke... I suspect you didn't install the standard rockchip apps that are a seperate download/install listed in the first posts of the thread.
      And I need to install all applications or just the RKGameControlSetting will be enough?
        I don't use it, I prefer a real kb/mouse instead... you may want to actually read the thread, I believe it's been mentioned.... or just try it... probably quicker than asking even
          Re: QX1 Quickshot v2 Rom by The Nitro Team
          Ehomemediacenter is the needed app for rkremote
          leolas
          sent from my phone.
          My devices:
          Gearbest.com)
            Originally posted by PolloLoco View Post
            I'm pretty sure that it's hardware dependent. It has to be built into your phone or tablet. It's possible that someday, someone will figure out another way to mirror, but I wouldn't count on it.
            Thanks for the answer. Let's hope someone can make it work!
            Imito QX1
            leolasROM-qx1-1.5 (30-10-2013)
            kernel_leolas_qx1_1080p_vsfsam_cpu1800_ddr720_gpu7 98_qx1-wifi
            XBMC XAF build (12.1)
            Tronsmart TS-01 airmouse
            Powered USB hub
              Hi!
              I installed this rom a couple of days ago, and it's working great, except one big issue. The device keeps shutting of randomly - sometimes just after a couple of minutes, other times after 10. I've read this thread, but the the only thing i found seems to be related to XBMC.
              When it shuts off, it tries to boot again, but won't. I have to unplug the power in order for it to work again.
              Any ideas? Could it help to reflash something, maybe just the kernel?
                Originally posted by slekvak View Post
                Hi!
                I'll quote the recommended setting found in the third post...
                -development options, we recommend that you activate Stay awake option, this makes the HDMI output not turning off when we take a while without using the device, the device remains on without entering the suspension mode.
                Another common area... power supply. Most of the PS's included aren't up to the job... get a better one that provides more amperage output.
                  iMito QX1
                  I try the root my imito qx1 but it doesn't seem the have a reset button, what do I do
                    The reset button is in the hole next to the micro-usb port
                      iMito QX1
                      But when I use a pin the press reset nothing happens.
                        It's unlikely that they didn't put a switch on it... so you need to try some more in case you are doing it wrong and/or contact the reseller you got it through if there really is a problem...
                        In any case, it isn't an issue related to any ROM
                          Hi, my QX1 works reasonably well but gets hot and shutdown. What is the best pack to install?
                            Try cpu1600 gpu stock ddr 720
                            leolas
                            sent from my phone.
                            My devices:
                            Gearbest.com)
                              leolas
                              sent from my phone.
                              I found the file 'kernel_leolas_qx1_1080p_cpu1608h_ddr720.img_quick flasher.zip' - the nearest suggested. I'll try with it.
                                How to Unroot Quickshot V2 ROM
                                Are there a way to remove root on Quickshot V2 ROM? I use a Video streaming service that does not run on rooted devices so I would like to unroot. I really like this ROM so I would preferr not to revet back to the stock ROM.
                                So, If someone could post how to unroot the ROM it would be much appreciated. If not, does anyone have a recomendation on an unrooted ROM for the QX1?
