Sent from my SAMSUNG-SM-N900A using Tapatalk
General AML S802 Device release discussions
Re: EM8 Amlogic S802 quad core 2Ghz + Octa core Mali 450: FIRST PRICE INFO!
Originally posted by otisrhw View PostNo your not the only one I just got this problem with gamepad enabler
Sent from my Nexus 5 using Tapatalk
Originally posted by Batfink32 View PostYeah, it seems no paid apps will install for some reason. I've been reading around the web and its maybe a kernel issue but I'm not sure. Something needs sorted though.
Originally posted by otisrhw View PostLooking through build prop now look for something obvious.
Originally posted by Batfink32 View PostI mentioned it earlier as well but looking at the max CPU in trickstermod, its set to 1.6ghz. I thought this Amlogic was 2GHz max? Is this how they've sorted out their overheating problem by throttling the CPU?
Sent from my mobile device. Please excuse any typos.
Originally posted by otisrhw View PostDon't know about the overheating thing but this install is software related and will be fixed I'm sure for now I use apk extractor on my phone and send to dropbox install from there. Also wondering about black market or aptoid
Originally posted by noderat View PostI would not recommend discussing any piracy apps here on freaktab.
Originally posted by otisrhw View PostYeah I know but when you need the stuff you paid for than that could be your only option or email devs and get apk
Originally posted by noderat View PostI wouldn't put it past good old hong Kong. First the rk3188-T chaos now more bait and switch crap. Bah.
Just get a good news from my customer, the tronsmart vega s89 can play Blu-ray ISO.
those iso file is really too big, i haven't got one to test, but my customer tell me ,it can.Looking for developers
Originally posted by Batfink32 View PostIt does go up to 2ghz in trickster although it won't stick. If you use the frequency lock that seems to work. Also, the minimum frequency is 96?!? I've bumped that up also which improves smoothness.
Originally posted by gene0915 View PostThis true? I always thought that was the big advantage AMLogic had over RK processors....that AMLogic embraced open source. Is the party over?
Also, all the DD/DTS pass through problems put to rest?
Nobody outside of hong kong has commented on 5.1 support and I don't trust anything resellers/manufacturers say.
Originally posted by noderat View PostTV boxes really shouldn't scale that low, those speeds its not even about heat it's about battery life. Perhaps the kernel its using was originally meant for the m802 for a tablet or phone?
There are currently 3053 users online. 1 members and 3052 guests.
